Old Jul 26, 2009, 10:14 PM
edragon is offline
Find More Posts by edragon
United States
Joined May 2008
problem--New elogger v3, osd, gps
I just bought an elogger v3 with osd expander and gps expander from Towerhobbies. I installed the software on my computer and setup the osd display. When I hooked everything up on my FPV funjet with a camera and wireless transmitter, I can see the video fine but the OSD shows a bunch of error messages. Then, I plugged the elogger into my computer to re-setup the osd, but the software locks up when I tried to open the OSD setup page.
Update:
I've learned that whenever the OSD is plugged-in, the software will lock-up. After I remove the OSD, I was able to record some data, like watts, amps, gps position, etc.
edragon is offline Find More Posts by edragon
Old Jul 27, 2009, 12:04 AM
edragon is offline
United States
Joined May 2008
Nevermind. I got it to work. Mostly. I'm not sure what went wrong. Now I need to figure out why the GPS shows over 5000 ft alt, when I am at sea level.
Old Jul 30, 2009, 04:44 PM
billpa is online now
Find More Posts by billpa
billpa's Avatar
Joined Nov 2003
edragon, glad you got the system to work.
Yes, there is a problem we have with GPS when the GPS thinks it is below sea level, and starts reporting negative numbers, which is probably the case when you are right at sea level. We have attempted to reproduce this problem here (at sea level!) but have never been able to. Does this problem persist for you?
Regards,
Bill, for Eagle Tree
billpa is online now Find More Posts by billpa
Site Sponsor
Old Aug 19, 2009, 08:59 PM
edragon is offline
United States
Joined May 2008
Bill,
The GPS says 5000 feet alt when I was at home. But, when I got to the flying field, it says a negative number. After I throw my plane into the air, the altitude number looks good.
Sometimes, when I'm flying the GPS altitude is slow to update. For example, the GPS altitude wouldn't change for 2 seconds even though my plane is in a dive. I assume the other GPS data is slow also.
Discussion blackstork osd gps problem dukenuke FPV Talk 17 Mar 08, 2010 03:36 AM
Help! Black Stork OSD Gps problem? need help littlepiston FPV Talk 22 Jan 22, 2010 02:05 AM
Help! No RPM Reading on new Elogger V3 lilredrex Eagle Tree Systems 3 Apr 30, 2009 01:08 PM
Sold EagleTree 5Hz GPS Expander Module for eLogger V3! $100 shipped! edge5foamy Aircraft - General - Miscellaneous (FS/W) 2 Jan 13, 2009 08:44 AM
Discussion Problems with 5Hz GPS Expander V3 and eLogger V3! Geni Eagle Tree Systems 7 Aug 14, 2008 12:08 AM
