Go Back   RC Groups > Boats > Scale Boats
Old Jul 26, 2009, 10:38 AM   #1
5 copies for my mother...
patmat2350's Avatar
Baywatch Lifeguard Boat
I've been wanting to get started on this for some time, so I'll just do it now, and fit it in between other jobs.
The LA County Fire Department includes the Lifeguard division, which is the real Baywatch. Pam Anderson need not apply.
The Baywatch fleet is comprised of multipurpose rescue boats in a few variations... but they all appear to be twin prop diesel powered deep vees with a third diesel to run a fire pump. Crew is two highly qualified lifeguards-- these guys are swimmers, paramedics, firemen, and Coast Guard-approved for boat handling and towing. I started a thread on the boats themselves here:
http://www.rcgroups.com/forums/showthread.php?t=530370
... but this thread will cover my build.
  • Name: abaywatchandflag.jpg
Description: These are all images "borrowed" from the Web. These are all images "borrowed" from the Web. 85.6 KB · Views: 68
  • Name: 12.jpg
  • Name: apic12.jpg
patmat2350 is offline Find More Posts by patmat2350   Reply With Quote
Old Jul 26, 2009, 10:44 AM   #2
patmat2350's Avatar
I'm most interested in in LACOFD #12- a nice 32 footer with a 12 ft beam for which I have a lot of pictures. The boats were built by Seaway Boats in Long Beach. As they were unwilling to release plans, I've worked something out instead: Started with lines taken from a Dumas Trojan, which has a very similar hull forward, and then tweaked the rear from a tumble-home design to the right form of the Seaway boat. Then working from a couple hundred photos, laid in the inner structure. It's close.
Model will be 1:12 scale, 32 inches long.
  • Name: lifeguard.gif
  • Name: a_8067.jpg
Description: Don't stare too long... Don't stare too long... 58.2 KB · Views: 68
  • Name: aImg_8109.jpg
Description: Me doing research in Marina del Rey. Me doing research in Marina del Rey. 59.7 KB · Views: 99
Old Jul 26, 2009, 10:51 AM   #3
patmat2350's Avatar
Being a simple deep vee hull with almost flat panels (the original is built of plywood), the hull construction goes quickly. I started cutting frames from 1/8" lite ply on Wednesday, and here on Sunday I'm applying glass. The real work is ahead of me!
  • Name: a_1397.jpg
Description: Dumas style- build on a flat sub-deck, then add the cambered shape on top later. Dumas style- build on a flat sub-deck, then add the cambered shape on top later. 62.9 KB · Views: 42
  • Name: a_1398.jpg
Description: A few stringers will do. A few stringers will do. 69.8 KB · Views: 46
  • Name: a_1399.jpg
Description: Shaping the chine stringers, which are laminated 1/8" square basswood strips. Shaping the chine stringers, which are laminated 1/8" square basswood strips. 78.0 KB · Views: 49
  • Name: a_1400.jpg
Description: Starting the diagonal planking. Bottom planks are feathered into the chine, and cross over the keel. Way easier than trying to use sheets. Don't forget to edge-glue the planks for strength. All CA here. Starting the diagonal planking. Bottom planks are feathered into the chine, and cross over the keel. Way easier than trying to use sheets. Don't forget to edge-glue the planks for strength. All CA here. 91.8 KB · Views: 45
  • Name: a_1401.jpg
  • Name: a_1402.jpg
Description: Just need a little filling and smoothing. Just need a little filling and smoothing. 51.3 KB · Views: 74
  • Name: a_1403.jpg
Description: And then the glass goes on. And then the glass goes on. 75.2 KB · Views: 84
Old Jul 26, 2009, 09:35 PM   #4
from downunder Downunder
col_426's Avatar
That looks really nice, Pat. I have trouble fitting just one build in-between the rest of life, and you are tackling (at least!) two complicated builds at once. Makes me feel depressed....sigh. I really enjoy watching you work though, and seeing the masterpieces you create.
Phillip
col_426 is offline Find More Posts by col_426   Reply With Quote
Old Jul 29, 2009, 11:32 AM   #5
Baywatch
Hi Pat
Are you going to carve a figure of Pam Anderson to go with your boat ?
Richard J OMal is offline Find More Posts by Richard J OMal   Reply With Quote
Old Jul 29, 2009, 12:50 PM   #6
Mopar Musclecar fanatic
xx29l9's Avatar
Originally Posted by Richard J OMal
Hi Pat
Baywatch had boats? I must have been distracted....
xx29l9 is offline Find More Posts by xx29l9   Reply With Quote
Old Jul 29, 2009, 01:34 PM   #7
patmat2350's Avatar
Please read the first note.
Old Jul 30, 2009, 02:05 AM   #8
Off Topic
Hello Pat this is the rustbucket I am a friend of UMIs up here in Portland .
I look over your sight tonight. YOU Brought back some old memorys to me . For in 2000 I sent in a story about the DDG USS SULLIVANS . That I did in RC ( Scale ship modler )
I was lucky enought to have it on the front cover . To this day i still have the ship but it now has a flight 2 in back and I up dated the ship to the USS Bluckely DDG 84. I did not know you were part of the mag. Never did get a chance to say thankyou at the time. NOT sure if you were with the Mag at that time. Never got a chance to say thank you to any body that was part of it . To bad we lost the Mag I allways enjoyed seeing it.
Sorry GUYS for being off topic but I just wanted to to pat a long over due Thank you. DON That Portland Rustbucket
Rustbucket is offline Find More Posts by Rustbucket   Reply With Quote
Congratulations SimpleM!
