Old Jul 25, 2009, 12:21 PM
randall1959 is offline
Find More Posts by randall1959
Joined Feb 2004
What's the difference between an esc with bec and one without?
I was wondering what the difference was and if I use a non bec esc what will I need in order to make it work?
randall1959 is offline Find More Posts by randall1959
Reply With Quote  (Disabled)
Old Jul 25, 2009, 12:26 PM
Challenger 413 is offline
Find More Posts by Challenger 413
Challenger 413's Avatar
Dickinson, Tx.
Joined Sep 2004
One has an onboard BEC in either "linear" or "switcher" fashion. The ones with out a BEC are geared more towards higher voltage setups, 4S and above voltages.
If your doen't have a BEC, you will either need to use a Rx battery or an add on BEC...
Challenger413
Challenger 413 is offline Find More Posts by Challenger 413
Old Jul 25, 2009, 12:34 PM
Joined Feb 2004
Ah ok.....Thanx. I found a 60 amp BP esc for like fifteen dollars shipped but it comes without a bec. I guess I'll either sell it or go shopping for a bec then.
Old Jul 25, 2009, 01:07 PM
Dickinson, Tx.
Joined Sep 2004
What size plane, what size servos, what size pack (voltage) are you planning on using?
The ESC's that have on board "linear BEC" are OK when used with 3S pack voltages and am using (4) small 8 to 9 gram servos and you have the ESC set up with great cooling airflow over both sides of the ESC. If you are using larger servos or the ESC is going to be mounted where it is getting little or some cooling, do yourself a favor and install an add on BEC.
If the onboard BEC trips off due to high heat, you will lose all servo control for at least 2 to 5 seconds, until it cools down and resets. Could lead to a bad crash...
Challenger413
Old Jul 25, 2009, 01:20 PM
Joined Feb 2004
There aren't any problems with cooling as the plane is an open framework model I designed for aerial photography. I'm also only using three servos, one each for rudder and elevator and one to trip the shutter on the camera. I'm also using an Esky gyro for rudder dampening. I'm using standard size servos on this rig too. I recently upgraded to a larger motor and wanted an esc that was more than up to the task and found a BP MKII 60 amp esc on ebay for fifteen bucks shipped. The bec I found was only six dollars shipped so I'm good to go now.
Thanx for enlightening me on what a non bec esc actually is. I figured there was something else I'd have to buy. Lift isn't an issue cause this thing will lift a brick I've also got some 4000ma 3s lipos coming so now I just gotta wait for Mr postman to bring the goodies
Discussion what is the difference between regaular esc's and marine esc's kremecheze Racing Boats - Electric 1 Aug 29, 2008 10:09 PM
Discussion What's the difference between the Thunderbird and Phoenix ESC rick88ss Castle Creations 4 Jan 11, 2008 12:16 AM
what's the difference between a buddy box and a trainer cord? omega blood Radios 5 Apr 12, 2003 06:35 AM
What's The Difference between Cells? CheChe156 Power Systems 3 Feb 13, 2002 05:26 PM
What's the difference between F3J and AMA Thermal Duration & a short story... tempest411 Electric Sailplanes 4 Oct 18, 2001 01:20 PM
