| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||
#31 |
TOPMODEL Schweiz
Avidox AG Standbachstrasse 24 8370 Sirnach Switzerland Tel +41 71 971 23 43 Fax +41 71 971 23 89 www.top-model.ch www.topmodell.ch info(et)topmodell.ch info(et)avidox.ch TRACER (= DARA by Flair and very similar to Club20 pylon racer MAMBA) description: The TRACER (#2132) is a fast classy CLUB-20 pylon racer just under 1 m of wing span. Top speeds of 120 mph are achieved already with a hot 2.5 cc engine. This agile plane can also be set up with rudder if desired. kit content: glass fuselage with yellow finish yellow coloured glass fiber canopy obeche sheeted foam wing stab and vertical fin made of wood engine mount linkages and rods small parts construction plan technical data: R/C: elevator, ailerons, throttle optional wingspan: 920 mm length: 780 mm motor: 2.5 – 5.5 cc speed engine weight: from 1100 g kit price: 258 SFr (Swiss currency) engine/pipe/prop recommendations:
#32 |
RC-Tronics-Topp-Rippin OHG
Weststrasse 39 58638 Iserlohn Germany TEL +49 2371 9728 97 FAX +49 2371 9728 96 www.rc-tronics-topp-rippin.de http://stores.shop.ebay.de/Rc-Tronics-Topp-Rippin rippintopp(et)aol.com rippin-topp(et)aol.com Alpha-Jet mini description: Alpha Jet “mini”, the dream of many jet freaks. This is a very fast semi-scale jet coming with good aerobatic capabilities. Fantastic rolls, large loops or fast & low dives are pure fun, combined with great low speed qualities. kit content: fuselage and engine cowling are made from glass and finished with white gel coat semi-symmetric wing airfoil CNC-cut foam core + obeche sheeted + glass reinforced wing (one-piece design, compression-mold) balsa wooden stab and fin units transparent cockpit canopy decal set small parts construction plan technical data: R/C: elevator, ailerons, throttle optional wingspan: 1.005 mm wing area: 21.5 dm^2 length: 1.115 mm motor: 3.5 – 5 cc weight: 1.200-1.500g kit price: 149 € engine/pipe/prop recommendations:
#33 |
Matney's Models
10765 Victory Road Erie, MI 48133 USA Tel: 734-848-8195 Fax: 734-848-8195 (pause) then 5* http://www.matneymodels.com/ info2005(et)matneymodels.com AJ-2 - QM15 pylon racer Just as its bigger QM40 brother has shown in the new millenium, the QM15 size AJ-2 has proven to be one of the smoothest flying QM aircraft available. With its T-tail design & clean lines, it flies like it is on rails! The kit features a hand-laid fiberglass fuselage made of the highest grade epoxy available. If you're looking for a competitive, yet unique aircraft, the AJ is exactly what you are looking for. specifications: R/C: elevator, ailerons, throttle optional wingspan: 42 inches wing area: 350 sq in motor: 2.5 to 5.5 cc speed engine weight: 2.5 lbs basic kit content: Hand laid epoxy-glass fuselage, foam wing cores and plans. kit price: $80 Matney Models AJ-2 QM 15 thread: http://www.rcuniverse.com/forum/m_37...tm.htm#3723918 engine/pipe/prop recommendations:
#34 |
Weststrasse 39 58638 Iserlohn Germany TEL +49 2371 9728 97 FAX +49 2371 9728 96 www.rc-tronics-topp-rippin.de http://stores.shop.ebay.de/Rc-Tronics-Topp-Rippin rippintopp(et)aol.com rippin-topp(et)aol.com F-102 "Delta Dagger" description: The F 102 Delta Dagger is a superlative delta type jet fighter. Excellent flight characteristics and a wide speed range are main features. This jet model is very fast and offers sound aerobatic capabilities. Superb rolls, large loops and low high-speed dives are a pleasure - but the delta configuration offers great low speed capabilities too. kit content: kit with white gel coat finished glass fuselage and engine cowl (= tail jet nozzle) CNC-cut foam core + obeche sheeted + glass reinforced wing (one-piece design, compression-mold) leading edges already glued and sanded already laid in servo cables milled servo hutches ailerons slotted wooden parts transparent cockpit canopy small parts construction plan technical data: R/C: elevator and ailerons mixed, throttle optional wingspan: 1.000 mm wing area: 22.5 dm^2 length: 1.200 mm motor : 6.5 to 20 cc speed engine weight: from 1800 g kit price: 199 € engine/pipe/prop recommendations:
#35 |
Roedelmodell GbR
Bernd & Petra Doerfler Lausangerweg 4 86874 Mattsies Germany Tel: +49 82 68 - 713 Fax: +49 82 68 – 715 www.roedelmodell.de info(et)roedelmodell.de techsupport(et)roedelmodell.de bestell(et)roedelmodell.de KOBRA "Revival" (full composite ARF) description: Already 20 years ago the Kobra has been designed specifically for high performance 2-stroke glow engines up to 2.5 cc. The actual version (#01 186 0) reflects a super strong full composite speed plane incorporating more aerodynamic refinements. The lightweight construction and the used airfoils promote docile behaviour over the entire speed range but also allow for low landing speeds. Compared to many today's electric powered prop driven speed planes the nitro powered Kobra offers unique jet-like appearance. The kit quality is exceptional good. specifications: R/C: elevator, ailerons, throttle optional wingspan: 900 mm length: 790 mm wing airfoil: RG 12 stab airfoil: NACA 63 motor: 2.5 cc speed engine kit content: epoxy-glass one-piece fuse/wing featuring fairings for the tail booms epoxy-glass vertical stabiliser 2 x epoxy-glass tail boom with vertical tail canopy either transparent or made of carbon fiber epoxy-glass engine firewall CNC cut mounts for the R/C asssembly epoxy-glass servo covers (CNC cut) small parts (linkages etc) kit price: 219 EUR engine/pipe/prop recommendations:
#36 |
Horrido aircombat team
Potocká 3 623 00 Brno Czech Republic Ing. Patrik Svída 664 34, Rozdrojovice 200 Czech Republic tel.: +42 602 791 285 fax: +42 547 250 174 http://www.svida.cz/horrido/index.php?id=71 http://shop.svida.cz/index.php?main_...68b4ef9b783663 email: patrik(et)svida.cz Avia B-35 (full composite) description: The Czech fighter plane Avia B-35/B-135.1 from the times before World War II is model for this composite plane of aircombat class. It was constructed at the very begin of WWII by czech designers. After Munich agreement was the whole project of Avia stopped. You can read more about history of Avia B-35 on the web page devoted to the real plane (Czech). The model was developed for memory of czech aircraft history. For R/C combat the model is designed for use with 2,5 ccm (0.15) glow fuel engines or AC electric motor. It was completely designed in 3D software. The main components of moulds were worked by CNC 3D machine. This process saved shapes of composit parts in very details. The hole construction was thought through in the last detail for reaching the least flying weight, the best firmness and very good flying characters. Avia model is streamed to be sport plane more then copy of original. It is speed and dexterous plane especialy for quick and adrenaline flying. You should follow recommended driving combinations. For hobby use it is possible to mount in to it a weaker and lighter engine and battery. specifications: R/C: elevator, ailerons, throttle optional scale: 1:12 wingspan: 900 mm length: 700 mm wing area: 12.7 dm2 / 186 sq inch motor: 5 cc rear exhaust speed engine pure weight of empty model: 250 g / 8.81 ounces kit content: this full composite kit includes all parts for both electric and glow fuel engine versions kit price: ca 130 EUR construction manual: http://www.svida.cz/horrido/avia/avia_b-35_manual.pdf engine/pipe/prop recommendations:
#37 |
There was a question what to do if one of the kit makers or distributors won't ship outside the EU.
If you have a buddy in Germany then it'll be easy to ship several Speed Cobras to the US or Canada. The “Deutsche Post (DHL) Company“ for instance offers insured shipping to Zone 3 states (that includes also USA and Canada) in a box sized up to 60x60x120 cm. Following Pythagoras' theorem you get a C diagonal length of 134 cm. In case of the COBRA made by Fliegerland that means you would be able to pack at least 4 complete kits into one 60x60x120 cm shipping box! calc:
893.50 EUR grand total (four Cobras shipped insured to US or Canada) equalling ca. 320 US$ per kit shipped This kind of shipping usually takes 4 to 6 weeks from Europe to North America. The 128 cm long Cobra is a very large speed plane. So in case of smaller speed planes of about 1 meter of wing span you could pack approximately 10 kits (of different makers if you like) into one 60x60x120 cm shipping box! For instance the little ME-163 Komet by TOPP-RIPPIN is one of the hottest small speed planes available worldwide – and it is not expensive. Powered by only the JETT .35 BSE FIRE or the OPS .29 RIRE it is faster (at least 180 mph with a 6x8 speed prop) than any Weston V50 powered Magnum or JETT .50 powered Diamond Dust. Just give it a try – you won't be disappointed.
#38 |
Hey I-L-J I have a Beretta 21 that I have not built. You said the plane has "The ailerons are built as elastic-flaps!" Can you clarify? not sure what you mean and the instructions I have only show regular hinges.
Thanks for your posts again. Wie kann jemand in Amerika ein Freund in Deutschland, würde Schiff einige Geschwindigkeit Cobra Modelle der USA? |
#39 | ||
Elastic does mean that the hinge for the ailerons or elevators is made of ARAMID or NYLON (or other suitable textile) over the entire length of the flap. The hinge line ( = center of rotation) mostly is located at the top side of the wing surface. In case of a composite wing it is necessary to carefully carve the outside glass fiber or carbon fiber layer down to the flexible hinge material. To enable downward movement of the flap the bottom side of the wing surface below the hinge line must be V-slotted. You may also add a lip at the bottom side that covers the gap. I believe only Berettas made in year 2007 or later feature elastic flaps. Quote:
Register for free at http://www.rc-network.de/forum/register.php (the German RCgroups equivalent) Start a thread in English at the “Motorflug“ sub-forum http://www.rc-network.de/forum/forumdisplay.php?f=18 and ask for someone who would help you to ship that 60x60x120 cm box by DHL over the pond. If that German potential helper is a long-time registered RC-Network user with hundreds or thousands of posts then he is well integrated to the forum community and thus trustworthy. Remember: Germany is a small country. Many forum folks do know each other personally... To make the transfer public to the German forum users you should keep your thread alive until the speed plane kits arrived at your home in US or Canada. Please use the tracking number of the insured DHL shipping and visit your local USPS office. So you will be informed about the status quo of the shipping... Last edited by I-Love-Jets; Aug 04, 2009 at 08:36 AM. Reason: adding pic |
#40 |
MikesRC
Screamin Demon Delta
One of the easiest ways to get in to high speed aircraft is with a delta. The Screamin Demon delta is a 32" span quick and easy building kit that is capable of well over 150mph with many of the high performance sport and pylon engines available in the .40-.50/7.5-8.5cc range. It has been clocked at over 170mph with a Sport Jett .50!
Yet, for all its speed and capability the aircraft is easy to fly, tracks true, and slows way down for landing or when you need a break. In addition, it is an amazing flier on a wide range of sport engines from a good Schneurle .25 on up. With a strong .32-.35 engine and the lighter wing loading that results, you'll see 120mph top speeds and turns so tight you'll wonder how it stays together. But - with a pair of carbon fibre spars locking everything together, no worries. Any sport .40 - .46 will give you a wild ride. Construction is conventional balsa/ply supported by two pultruded carbon fibre tubular spars. Builder is required to glass key areas for strength and durability. Covering - conventional films or fabric. Available from www.MikesRC.us. Wing span: 32" Wing area: 475 sq in. Weight: 2.3 - 3.0 pounds Engine size: .25 - .35 (.25 case) .40 - .60 (.40 case) Construction: Laser-cut ply and balsa parts, tubular carbon fibre spars Last edited by mjd; Aug 04, 2009 at 06:35 PM. |
#41 |
Big Bruce Racing has this coming out soon.
http://auspylon.com/modules.php?name...iewtopic&t=104 Last edited by JFisher304; Aug 09, 2009 at 12:33 PM. |
#42 |
SAVEX GFK Modell
Pastýřská 8 Plzeň – Koterov Czech Republic TEL +42 377464229 or +42 602289554 http://www.savex.cz/ savex(et)volny.cz Me - 110 Bf G2 Gold edition (premium full composite ARF) description: This detailed combat-scale model of the famous WW2 battle plane is made of glass/CF composite technology (glass and carbon strings). There are very refined integrated elastic hinges at all control surfaces. To be powered by either glow or electric motors. This beautiful plane can also be used without engine as a slope soarer (PSS). Two colour schemes are available. The surface features many scale details such like metal sheets, cloths etc. http://www.savex.cz/vrtu.php?id=7&lang=en technical data: scale: 1:11.3 weight: from 1000 g wing span: 1440 mm length: 1050 mm engines: 2 x 2.5 cc up to 2 x 5.5 cc wing airfoil: RG15 kit price: 399 € engine/pipe/prop recommendations:
#43 |
AIRWORLD MODELLBAU
Hans-Dieter Reisert Henschelstr. 11 63110 Rodgau Germany TEL: +49 6106 79228 FAX: +49 6106 79731 www.airworld.de info(et)airworld.de RC INTERNATIONAL DeHavilland DH-88 Comet (full composite premium ARF) description: The D. H. 88 Comet was specifically developed in 1934 for the London/Melbourn air race by Sir Geoffrey DeHavilland. It is one of Britain’s most famous aircraft. The
The original’s advanced elliptical wing plan-form and the sophisticated nacelle arrangement, necessary to accommodate the two motors and retractable undercarriage legs, lend themselves to our proven all-moulded epoxy glass construction of all components, enabling incredible lightness and strength, together with a surface finish and detail accuracy with all control surfaces already hinged for you. Grosvenor House comes ready finished in its striking red livery with distinctive markings, Black Magic and the Rubin British Racing Green aircraft are available on special request. This scale aircraft may also be flown as a PSS soarer. specifications: scale: 1:6.5 weight: from 3300 g wingspan: 2060 mm length: 1400 mm engines: 2 x 6.5 to 2 x 8.5 cc side exhaust (or hot .60s in a .40 case) kit price: 545 € kit content: full fiberglass construction one-piece fiberglass wing with pre-formed engine nacelles and pre-installed ailerons fiberglass tailplane fiberglass sandwich fuselage with integrated vertical stabilizer/rudder clear canopy accessories: pneumatic retractable undercarriage scale main wheels set video: http://www.airworld-usa.com/videos_8/DH_88250k.wmv engine/pipe/prop recommendations:
#44 |
generic-fly
Pia-Sylvia Pakusa Am Detershof 4 26655 Westerstede Germany tel +49 4488 763967 fax +49 4488 763968 www.generic-fly.de info(et)generic-fly.de office: Mon, Tues, Thur 7.30 am to 4.30 pm CET Wed, Fr 7.30 am to 1.00 pm CET BLIZZARD (full composite speed delta) description: This full composite high-speed delta plane is not suited for faint-hearted pilots. Already a hot 6.5 cc engine will turn this pusher delta into a challenging “rocket”. However, especially when using a 10 to 15 cc ducted fan engine a catapult is highly recommended for safe and relaxed take-offs. As for proper tank installation, a 50 cc hopper tank next to the engine firewall is highly recommended in addition to the main tank situated near to the COG. specifications: wingspan: 880 mm length: 1050 mm engine: 6.5 to 20 cc side or rear exhaust speed engine weight: from 2200 g kit price: 175 € engine/pipe/prop recommendations:
#45 |
STEINMODEL AIR COMBAT PRODUCTION
PAVEL STEIN SUCHOHRDLY 301 669 02 ZNOJMO 2 CZECH REPUBLIC Tel +420 777 116 659 http://www.steinmodel.cz email: info(et)steinmodel.cz http://www.hobby-factory.com/catalog...tp68917f9lnr22 http://www.mero.co.at/03c34699790ad8...9790c0d24c.php KAWASAKI KI-61 II KAI "Hien" (ARC aircombat fighter) description: This kit includes a glassfiber fuselage of excellent quality. There are many details taken over from the original fighter plane such like engine exhaust pipes, air ducts etc. The wing consists of a foam core sheeted with obeche wood. Furthermore the kit contains CNC cut parts as well as accessories. This ARC only requires about 15 hours of working time of an intermediate experienced person to get finished. Our Kawasaki KI-61 is the perfect plane for ambitious R/C aircombat competition or just for fun speed. specifications: R/C: elevator, ailerons, rudder optional, throttle optional scale: 1:12 wingspan: 1030 mm length: 800 mm motor: up to 5.5 cc speed engine kit price: 110 € kit content: - epoxy glassfiber fuse with white surface finish - transparent canopy - obeche sheeted foam wing - CNC cut parts (wing tips, horizontal stab etc) - engine mount - decal set - instruction manual engine/pipe/prop recommendations:
| Thread Tools | |
| Question Graupner speed props - where to buy ? | i3dm | Power Systems | 2 | Jun 30, 2008 06:37 AM |
| Discussion Cheaper 5g/9g Servos and where you buy them | Hytram | Australia | 28 | Jun 05, 2007 08:25 PM |
| Discussion batteries... which ones to get and where to buy them? | soholingo | Hand Launch | 24 | Jun 01, 2006 02:33 PM |
| Carbon Fiber Spinners and Landing Gear. Where to buy them? | Joe Elston | Sport Planes | 2 | Aug 30, 2002 04:03 AM |
| Up 'n Go - Where to Buy Them??? | green66 | Electric Sailplanes | 4 | May 20, 2002 07:08 PM |
