| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||
#16 |
RC-Tronics-Topp-Rippin OHG
Weststrasse 39 58638 Iserlohn Germany TEL +49 2371 9728 97 FAX +49 2371 9728 96 www.rc-tronics-topp-rippin.de http://stores.shop.ebay.de/Rc-Tronics-Topp-Rippin rippintopp(et)aol.com rippin-topp(et)aol.com ME 163 Komet mini - the small “Kraft-Ei“ description: This is a semi-scale copy of the legendary WW2 Messerschmitt ME 163 rocket powered interceptor, also called "the Kraftei". This model’s speed potential is remarkable depending on the engine used. Besides that it is very agile. kit content: kit with white gel coat finished glass fuselage and engine cowl CNC-cut foam core + obeche sheeted + glass reinforced wing (one-piece design, compression-mold) transparent canopy wooden parts (tail fin etc) small parts construction plan technical data: R/C: elevator + ailerons mixed, throttle optional wingspan: 995 mm wing area: 20.5 dm^2 length: 585 mm motor: 3.5 to 5.5 cc weight: ca. 1.000 g kit price: 106 € engine/pipe/prop recommendations:
#17 | ||
OAKDALE AIRCRAFT
http://www.oakdaleaircraft.com/phenom.htm rahlberg(et)oakdaleaircraft.com Phenom delta specifications: wingspan: 35-3/4" length: 28" airfoil: 5.5% modified 6 digit NACA wing area: 600sq. in. wing loading: 18oz.sq. ft. airframe weight: 36oz. power: .40 - 1.20 sized rear exhaust speed or ducted fan engines fuel tank: 10-15oz. kit content: fully molded ARF kit available in primer gray or colored (TBA) molded fiberglass fuselage vacuum bagged molded wings and fins. pre-installed formers molded motor/tank fairing and pushrod fairings. hardware package: - heavy duty hinge points - carbon fiber control horns - motor fairing mounting hardware - pushrod fairing hardware - servo mounting screws - fuel tank tray with hardware - complete instruction manual. ARF kit price: 159.00 US$ required accessories: flight servos: (2) Elevon servos 100+oz.in.torque standard case throttle servo: standard case BB servo 40+ oz. in torque. battery: 5 cell 6V. NiMh 1100 mAH elevon mixing required, dual rates and expo highly recommended. video of an OS .50 SX powered PHENOM (approx 130 mph top speed):
#18 |
RC-Technik
Michael Dieterle Lichtensteinstr.27 71088 Holzgerlingen Germany Tel. +49 7031 603166 modellmotorentechnik(et)yahoo.de http://www.modellmotorentechnik.de/eingang.html STILETTO 21 description: This is our Stiletto 21 made by Jet and Speedmodels from The Netherlands. This semi-scale speed plane is easy to fly once air-born. However – there is a tendency to torque roll during take-off. For that this plane is not suited for the speed beginner. The landing gear has been omitted for improved aerodynamics. The construction features a glass fuselage featuring fully cowled engine and fully enclosed tuned pipe for superior high-speed aerodynamics. kit content: epoxy glass fuselage (different colours available) epoxy glass belly ( = tuned pipe cowl) balsa sheeted foam wing CNC cut wing spar CNC cut wooden parts (stab and vertical fin, leading edges, wing tips, servo mounts, firewall etc) technical data: R/C: elevator, ailerons, throttle optional wing span: 1150 mm motor: 3.5 to 5.5 cc FIRE or RIRE speed engine weight: from 1250 g engine/pipe/prop recommendations:
#19 |
Last edited by I-Love-Jets; Sep 14, 2009 at 09:00 AM. Reason: shop doesn't exist any longer |
#20 |
Weststrasse 39 58638 Iserlohn Germany TEL +49 2371 9728 97 FAX +49 2371 9728 96 www.rc-tronics-topp-rippin.de http://stores.shop.ebay.de/Rc-Tronics-Topp-Rippin rippintopp(et)aol.com rippin-topp(et)aol.com MIRAGE 2000 - semi scale, prepared for retracts description: The Mirage 2000 is a superlative delta type jet fighter. Like the original the R/C MIRAGE 's unique design is paired with excellent flight characteristics and a wide speed range. It is very fast and offers sound aerobatic capabilities. Superb rolls, large loops and low high-speed dives are a pleasure - but the delta configuration offers great low speed capabilities too. content: kit with white gel coat finished glass fuselage and engine cowl (= tail jet nozzle) CNC-cut foam core + obeche sheeted + glass reinforced wing wooden parts (tail unit, etc) transparent cockpit canopy small parts construction plan prepared for retracts technical data: R/C: elevator and ailerons mixed, retracts, rudder optional, throttle wingspan: 1.200 mm length: 1.310 mm motor: 10 cc to 20 cc speed engine weight: 2.500 - 3.500 g kit price: 299 € engine/pipe/prop recommendations:
#21 |
Matney's Models
10765 Victory Road Erie, MI 48133 USA Tel: 734-848-8195 Fax: 734-848-8195 (pause) then 5* http://www.matneymodels.com/ info2005(et)matneymodels.com RIVETS - QM15 pylon racer This quarter midget kit of a classic Formula 1 aircraft is a past QM15 World Record holder. Designed by Dave Latsha, the kit features all hand laid glass work, made with the highest grade epoxy available. Super smooth flying and super quick. If you're looking for a unique speed project, consider the Rivets! specifications: R/C: elevator, ailerons, rudder, throttle optional wingspan: 42 inches wing area: 350 sq in motor: 2.5 to 5.5 cc weight: 2.5 lbs basic kit content: Hand laid epoxy-glass fuselage, foam wing cores and plans. kit price: $80 engine/pipe/prop recommendations:
#22 |
Weststrasse 39 58638 Iserlohn Germany TEL +49 2371 9728 97 FAX +49 2371 9728 96 www.rc-tronics-topp-rippin.de http://stores.shop.ebay.de/Rc-Tronics-Topp-Rippin rippintopp(et)aol.com rippin-topp(et)aol.com F-16 mini description: The General Dynamics F 16 US Super-Fighter represents a modern jet with aesthetic curves and excellent flight characteristics. This fast semi-scale jet model features well balanced aerobatic capabilities. It is made for performing fantastic rolls, large loops and low speed dives. But the low-speed and stall qualities are pleasant as well. For that the mini F-16 impresses with a large speed range and perfect flight characteristics, she is absolutely easy to fly! kit content: kit with white gel coat finished glass fuselage and engine cowl (= tail jet nozzle) CNC-cut foam core + obeche sheeted + glass reinforced wing (one-piece design, compression-mold) wooden parts (tail unit, etc) transparent cockpit canopy small parts construction plan technical data: R/C: elevator, ailerons, throttle optional wingspan: 806 mm wing area: 19.5 dm^2 length: 1.095 mm motor: 3.5 – 5.5 cc weight: 1.300-1.600 g kit price: 149 € engine/pipe/prop recommendations:
#23 |
BIT-Modellbau
Heinz Heber Am Wolfsberg 6 54634 Bitburg – Erdorf Germany Tel: +49-6561-7217 Fax: +49-1805-482 026 9329 http://www.bitmodell.de/modelle.htm Blizzard The Blizzard is a non-expensive speed plane as fast as an arrow! Top speeds of about 180 mph have been clocked in the past. Not only suited for the advanced pilot because it can be landed slowly. specifications: R/C: elevator, ailerons, throttle optional wingspan: 950 mm motor: 3.5 to 8 cc FIRE or RIRE speed or ducted fan engine weight: from 1500 g kit content: glass-fuse with integrated engine cowl, tail-unit fairing, obeche sheeted and sanded foam wing and foam V-tail, engine firewall, leading + trailing edge for wing and tail, construction manual with sketches. kit price: 71 € engine/pipe/prop recommendations:
#24 |
Weststrasse 39 58638 Iserlohn Germany TEL +49 2371 9728 97 FAX +49 2371 9728 96 www.rc-tronics-topp-rippin.de http://stores.shop.ebay.de/Rc-Tronics-Topp-Rippin rippintopp(et)aol.com rippin-topp(et)aol.com COMET TWIN (prepared for retracts) description: The COMET TWIN is a premium-class model plane! The elegant twin-powered COMET TWIN is an absolute eye-catcher. It comes with excellent flying characteristics also well suited for RCI style aerobatics. The Comet Twin - while being downright fast - always remains docile for such a twin-type of plane. The engine nacelles are located nearby the fuselage to keep the moments low in case of an engine failure. Prepared for installing retracts. content: kit delivered with white gel coat finished glass fuselage + pair of glass engine pods CNC-cut foam core + obeche sheeted + glass reinforced wing (compression-mold) leading edges already glued und sanded already laid in servo cables milled servo hutches sanded ailerons ready to fit tail unit prepared for retracts fuse bottom shell included transparent cockpit canopy cabin frame small parts construction plan technical data: R/C: 6 - 8 servos wingspan: ca. 1.800 mm length: ca. 1.410 mm motor: 2 x 10 ccm to 2 x 15 ccm weight: ca. 3.500 g kit price: 299 € engine/pipe/prop recommendations:
#25 |
RC-Technik
Michael Dieterle Lichtensteinstr.27 71088 Holzgerlingen Germany Tel. +49 7031 603166 modellmotorentechnik(et)yahoo.de http://www.modellmotorentechnik.de/eingang.html STINGER 40 description: This is our Stinger 40 made by Jet and Speedmodels from The Netherlands. It is a very reliable, easy to fly speed and pylon training model. Landing gear has been omitted for improved aerodynamics. The construction features a glass fuselage and a very strong wing. It doesn't have bad flying attitudes: Characteristics are tame (slow landing speed) and very stable during the entire speed range. kit content: glass fuselage (different colours available) balsa sheeted foam wing wing spar wooden parts (leading edges, wing tips, firewall etc) stab and vertical fin made of CNC cut wood technical data: R/C: elevator, ailerons, throttle optional wingspan: 1550 mm length: ca. 1150 mm motor: 6.5 to 8 cc (or a hot .60 in a .40 case) weight: ca. 2000 g kit price: 199.- € engine/pipe/prop recommendations:
#26 |
X-Treme Composite
OFFICE : 11/6 Hatairadjh Rd., Minburu, Minburi, Bangkok 10510, Thailand. FACTORY : 256 Moo 5, Ladtakien, Kabinburi, Prachinburi 25110, Thailand. www.xtremecomposite.com tel: +66(0)2518-2067 to 9 fax: +66(0)2517-9318 xtreme(et)minicrafthobby.com http://www.xtremecomposite.com/pricelist_usd.asp http://www.xtremecomposite.com/distributor.asp http://www.throttlestore.com/ http://www.sussex-model-centre.co.uk/ Ashley II description: ARTF Sport GRP Moulded Pylon Racer The Ashley-II is a full composite pylon racer. All the models components, i.e. fuselage, wing, tailplane and wheel fairings, are supplied as ready-made moulded items, painted in the mould, with a high-gloss finish. The high aspect ratio of wing and stab, promoting high-speed turns, is typical for modern R/C pylon racers. The model is capable of very high airspeeds. At the same time the aerodynamic layout of the Ashley-II gives the model pleasantly stable flying characteristics, and any R/C pilot with average flying skills will not find it difficult to control. kit content: One-piece wing, fuselage, bellypan and tailplane supplied as pre-painted GRP mouldings (orange, yellow, blue or red colour scheme available). Wheels, small items, decal sheet, linkage hardware pack. specifications: wingspan: 1490 mm length: 890 mm wing area: 23.4 dm.sq. R/C: elevator, ailerons, throttle optional motor: 3.5 to 5.5 cc FIRE or RIRE or FISE speed engine weight: from 1200 g building tips: http://www.rcuniverse.com/forum/m_47...tm.htm#5208039 engine/pipe/prop recommendations:
#27 |
Matney's Models
10765 Victory Road Erie, MI 48133 USA Tel: 734-848-8195 Fax: 734-848-8195 (pause) then 5* http://www.matneymodels.com/ info2005(et)matneymodels.com AJ-2 - QM40 pylon racer The latest high performance QM40 design from Matney Models has proven to be one of the smoothest flying QM aircraft available. With its T-tail design & clean lines, it flies like it is on rails! The kit features a hand-laid fiberglass fuselage made of the highest grade epoxy available. If you're looking for a competitive, yet unique QM40 design, the AJ is exactly what you are looking for. This aircraft meets all current AMA 422 QM40 specifications. specifications: R/C: elevator, ailerons, throttle optional wingspan: 55 inches wing area: 405 sq in motor: 6.5 to 8 cc (or a hot .60 in a .40 case) weight: 4.0 lbs basic kit content: Hand laid epoxy-glass fuselage, foam wing cores, landing gear and plans. kit price: $130.00 AJ-2 Q40 build thread: http://www.nmpra.org/phpBB3/viewtopic.php?f=12&t=1677 engine/pipe/prop recommendations:
Last edited by I-Love-Jets; Aug 25, 2009 at 05:26 AM. Reason: adding pics and link |
#28 |
Weststrasse 39 58638 Iserlohn Germany TEL +49 2371 9728 97 FAX +49 2371 9728 96 www.rc-tronics-topp-rippin.de http://stores.shop.ebay.de/Rc-Tronics-Topp-Rippin rippintopp(et)aol.com rippin-topp(et)aol.com Mustang P-51D description: The classy Mustang P-51D – a semi-scale model featuring stunning flight performance! content: fuselage and engine cowling are made from glass and finished with white gel coat fast semi-symmetric wing airfoil (Ritz) CNC-cut foam core + obeche sheeted + glass reinforced wing (one-piece design, compression-mold) balsa wooden stab and fin units transparent cockpit canopy small parts construction plan technical data: R/C: elevator, ailerons, throttle optional wingspan: 1.000 mm wing area: 18.2 dm^2 length: 873 mm motor: 3.5 – 5.5 cc weight: from 1000g kit price: 169 € engine/pipe/prop recommendations:
#29 |
Matney's Models
10765 Victory Road Erie, MI 48133 USA Tel: 734-848-8195 Fax: 734-848-8195 (pause) then 5* http://www.matneymodels.com/ info2005(et)matneymodels.com ME-109A - QM15 pylon racer The ME-109A QM15 kit is a replica of the famous ME-109 german fighter, which in its day was one of the fastest aircraft in the skies. Construction is very basic and straight forward. It is easy to fly and land, making this a great choice to help beginners seeking to become involved with pylon racing. The semi-kit features a high quality, light weight epoxy-glass fuselage, along with precision cut wing cores. Over the years, the Matney Models ME-109 has seen its share of trophies fast time awards. specifications: R/C: elevator, ailerons, throttle optional wingspan: 42 inches wing area: 350 sq in motor: 2.5 to 5.5 cc weight: 2.5 lbs basic kit contents: Hand laid epoxy-glass fuselage, foam wing cores and plans. kit price: $80 engine/pipe/prop recommendations:
#30 |
Weststrasse 39 58638 Iserlohn Germany TEL +49 2371 9728 97 FAX +49 2371 9728 96 www.rc-tronics-topp-rippin.de http://stores.shop.ebay.de/Rc-Tronics-Topp-Rippin rippintopp(et)aol.com rippin-topp(et)aol.com ME-163 Komet - the “Kraft-Ei“ description: This is a semi-scale copy of the legendary WW2 Messerschmitt ME 163 rocket powered interceptor, also called "the Kraftei". This model’s speed potential is remarkable depending on the engine used. Besides that it is very agile. kit content: kit with white gel coat finished glass fuselage and engine cowl CNC-cut foam core + balsa sheeted + glass reinforced wing transparent canopy wooden parts small parts construction plan Attention: The fuselage is molded from old molds. For that small, but hardly visible surface irregularities are present. - Thus the kit price has been reduced! technical data: R/C: elevator and ailerons mixed, throttle optional wingspan: 1.400 mm wing area: 35 dm^2 length: 840 mm motor: 10 - 20 cc rear exhaust speed engine weight: from 2000 g kit price: 140 € engine/pipe/prop recommendations:
RCGroups member RocketRob does make 9x10 CF props for his Komet, so you may contact him... Last edited by I-Love-Jets; Aug 25, 2009 at 02:20 PM. Reason: adding info |
| Thread Tools | |
| Question Graupner speed props - where to buy ? | i3dm | Power Systems | 2 | Jun 30, 2008 06:37 AM |
| Discussion Cheaper 5g/9g Servos and where you buy them | Hytram | Australia | 28 | Jun 05, 2007 08:25 PM |
| Discussion batteries... which ones to get and where to buy them? | soholingo | Hand Launch | 24 | Jun 01, 2006 02:33 PM |
| Carbon Fiber Spinners and Landing Gear. Where to buy them? | Joe Elston | Sport Planes | 2 | Aug 30, 2002 04:03 AM |
| Up 'n Go - Where to Buy Them??? | green66 | Electric Sailplanes | 4 | May 20, 2002 07:08 PM |
