Go Back   RC Groups > Aircraft - Fuel - Airplanes > Pylon Racing
Old Jul 25, 2009, 10:04 AM   #1
150 to 200 mph+ speed planes => Where to buy them? --- An overview
Hello!
Below listed are fast nitro powered R/C planes that are commercially available.
Each comes with a glass fibre fuselage (some are full-composites) and each is capable of at least 150 mph top speed.
This list of speed planes does not include actual Q40 or F3D pylon racers because these are covered already in other threads.
Depending on which high-performance engine you choose these planes will be REALLY fast and may be applied even for FAI F3S speed competition. In F3S usually purpose built speed ships are applied that are not available commercially...
Please note:
All listed top speed mph numbers display realistic FAI-compliant top speeds derived through the 200 m long speed trap (average of both directions to eliminate the wind factor). That means that speed results of the same plane during the same flight, being recorded with a high-quality radar gun (Stalker Pro) or by audio Doppler shift, will be higher...
If you require OPS or NOVAROSSI speed engine related info, please visit
The OPS engine thread
or
The NOVAROSSI / REX aero engines thread
Please only use bubble-free fuel tanks for speed planes (TETTRA, JETT) to ensure trouble-free engine operation:
http://www.centralhobbies.com/Fuel/fueltnk2.html
http://www.jettengineering.com/accy/tank.html
Especially for speed engines larger than 6.5 cc the application of an in-flight R/C mixture control is highly recommended, such like the Perry VP-IMC-05:
http://www3.towerhobbies.com/cgi-bin...?&I=LXDG65&P=7
http://www.perrypumps.com/prod03.htm
In case of a non-throttle venturi speed carb a fuel shut-off device is necessary, e.g. the Perry VP-RSV-04 Remote Smoke Valve:
http://www3.towerhobbies.com/cgi-bin...&I=LXDG64&P=ML
As for strong and safe carbon fiber speed props (hand-laid continuous strand) suitable for the “big-block” 10 to 15 cc speed and ducted fan engines, please ask RCgroups member RocketRob for tips.
I-Love-Jets is offline Find More Posts by I-Love-Jets   Reply With Quote
Old Jul 25, 2009, 10:19 AM   #2
ACCENT ARF – a purpose designed speed plane
TOPMODEL Schweiz
Avidox AG
Standbachstrasse 24
8370 Sirnach
Switzerland
Tel +41 71 971 23 43
Fax +41 71 971 23 89
www.top-model.ch
www.topmodell.ch
info(et)topmodell.ch
info(et)avidox.ch
description:
The ACCENT GFK (#1505) is a true speed plane – very hard to find these days!
The refined design does allow either electro or nitro power (two different engine cowls are included). For exceptional strength this ARF is a full composite construction, reinforced with Kevlar and carbon fiber. The finish is multicoloured. Depending on the type of engine output the ACCENT's speed spectrum just begins at 160 mph. However the landing speed is tame actually.
ACCENT – the speed plane to go berserk!
kit content:
glass fuselage (kevlar/carbon fiber reinforced) with multi-coloured finish
white coloured glass engine/pipe cowl
full composite wing and stab (each carbon fiber reinforced) with multi-coloured finish
all mountings for wing and stab already built into the fuselage
wooden parts
small parts (linkages etc)
construction plan
technical data:
R/C: elevator, ailerons, throttle optional
wingspan: 1150 mm
length: 870 mm
motor: 3.5 to 8 cc
weight: from 1200 g
kit price: 498 SFr (Swiss currency)
engine/pipe/prop recommendations:
  • Name: Accent_1.jpg
  • Name: Accent_2.jpg
  • Name: Accent_3.JPG
  • Name: Accent_4.JPG
  • Name: Accent_5.jpg
  • Name: Accent_6.JPG
  • Name: Accent_7.JPG
Old Jul 25, 2009, 10:31 AM   #3
Sunshine Modell und Hobby GmbH
Haus Lohe 2,
59457 Werl
Germany
Tel.: +49-2922-5172
Fax: +49-2922-83914
info(et)sunshine-modellbau.de
http://www.wega-sunshine.de/
Messerschmitt ME 163 B 1a Komet - Das Kraftei, Kit #15400 (fastest version)
http://shop.wega-sunshine.com/index....7f1c158&pgNr=1
model description:
Dr. Alexander Lippisch designed the first rocket-propelled aircraft of the world in 1941/42.Our Me-163 kits are offered in 3 variations, scaled 1:5, 1:6 and 1:7. We have also a sport scale version.
The sport scale model #15400 comes with excellent all round flight characteristics. Thanks to the special airfoil it is suitable for extreme speeds.
All of our Komets maintain stable flight characteristics during gliding. Therefore stalling is not to be feared and uncritical landings are ensured.
kit content:
glass-fuselage, glass engine cowl, glass fuselage back cover, balsa sheeted foam wings, transparent canopy, wooden parts, plan and parts-list.
specifications:
R/C: elevator and ailerons mixed, throttle optional
wingspan: 1350 mm
length: 810 mm
weight: from 2500 g
motor: 10 - 20 cc FIRE or RIRE speed / ducted fan engine
kit price: 139 € (regular kit #15400) or 299.90 € for the full composite kit #15400.1
  • JETT .60 LX FIRE 10 cc (upright) + fully enclosed MACS #1160 tuned pipe + APC 8.75x9.25W pylon or APC 8.75x9.5NN pylon or APC 8.8x9.75 pylon prop
    => max top speed of about 180 mph
  • NOVAROSSI REX R61F SPEED FIRE 10 cc (upright) + fully enclosed MACS #1160 + home-made carbon fiber copy of the APC 8.75x9.25W pylon or APC 8.75x9.5NN pylon or APC 8.8x9.75 pylon prop
    => max top speed of about 200 mph
  • OPS .60 super SPP FAN RIRE (#8045) 10 cc (upright) + fully enclosed MACS #1160 tuned pipe + home-made carbon fiber copy of the APC 8.75x9.25W pylon or APC 8.75x9.5NN pylon or APC 8.8x9.75 pylon prop
  • OPS .60 super SPP VAE RIRE (#8040) 10 cc (upright) + fully enclosed MACS #1160 tuned pipe + home-made carbon fiber copy of the APC 8.75x9.25W pylon or APC 8.75x9.5NN pylon or APC 8.8x9.75 pylon prop
    => max top speed of about 205 mph
  • OPS .67 super SPP FAN RIRE (#8261) 11 cc (upright) + fully enclosed MACS #1160 tuned pipe + home-made carbon fiber copy of the APC 8.75x9.25W pylon or APC 8.75x9.5NN pylon or APC 8.8x9.75 pylon prop
  • OPS .67 super SPP VAE RIRE (#8251) 11 cc (upright) + fully enclosed MACS #1160 tuned pipe + home-made carbon fiber copy of the APC 8.75x9.25W pylon or APC 8.75x9.5NN pylon or APC 8.8x9.75 pylon prop
    => max top speed of about 210 mph
  • OPS .80 super SPP FAN RIRE (#8501) 13 cc (upright) + fully enclosed MACS #1190 tuned pipe + home-made carbon fiber copy of the APC 10x10, shortened/rebalanced to 9x10”
  • OS .91 VR-DF 15 cc (upright) + fully enclosed MACS #1190 tuned pipe + home-made carbon fiber copy of the APC 10x10, shortened/rebalanced to 9x10”
  • OPS .90 "BIMETAL" SPP FAN RIRE 15 cc + fully enclosed MACS #1190 tuned pipe + home-made carbon fiber copy of the APC 10x10, shortened/rebalanced to 9x10”
  • OPS 1.20 SPP FAN RIRE 20 cc (#86115) + fully enclosed MACS #1190 tuned pipe + home-made carbon fiber copy of the APC 10x10, shortened/rebalanced to 9x10”
Maiden-video of a OS .91 VRDF powered Sunshine-Wega #15400 Komet, driven by a 9x10” carbon fiber prop (start watching at minute 4):
SacRats First Annual Electric Fly In Flight Senses (9 min 56 sec)
Another flight:
http://www.vimeo.com/5283571
The corresponding thread:
http://www.rcuniverse.com/forum/m_8788369/tm.htm
For the ME 163 airframe a (self-) detachable dolly is mandatory.
advantages:
  • the angle of attack during rolling will be increased (AOA of 6-8 degrees does work perfectly)
  • sufficient prop clearance for the 9x10” CF prop is generated
  • better top speed
Sunshine Model Company for instance do sell an aluminium dolly (#15308) for their #16500 Me163 that potentially will also fit the #15400 kit.
http://shop.wega-sunshine.com/index....12c6636a8f4758
RCGroups member RocketRob does make 9x10 CF props for his Komet, so you may contact him...
  • Name: ME163 by Sunshine Wega + OS .91 VR-DF_1.jpg
  • Name: ME163 by Sunshine Wega + OS .91 VR-DF_2.jpg
  • Name: dolly for ME-163_1.jpg
  • Name: dolly for ME-163_2.jpg
  • Name: dolly for ME-163_3.jpg
  • Name: CF speed props 9x10 for ME-163_1.jpg
  • Name: CF speed props 9x10 for ME-163_2.jpg
Old Jul 25, 2009, 11:49 AM   #4
RC-Technik
Michael Dieterle
Lichtensteinstr.27
71088 Holzgerlingen
Germany
Tel. +49 7031 603166
modellmotorentechnik(et)yahoo.de
http://www.modellmotorentechnik.de/eingang.html
BERETTA 21
description:
This is our Beretta 21 made by Jet and Speedmodels from The Netherlands and designed in the early 1990s. She is the ultimate speed plane for the 3.5 cc class. Hand launches are easy to manage.
The construction features a glass fuselage featuring fully cowled engine and fully enclosed tuned pipe for superior high-speed aerodynamics. The ailerons are built as elastic-flaps!
kit content:
epoxy glass fuselage (different colours available)
epoxy glass engine/tuned pipe cowl (different colours available)
CNC cut wing spar
CNC cut wooden parts (stab and vertical fin, leading edges, wing tips, servo mounts, firewall etc)
technical data:
wing span: 1000 mm
motor: 3.5 to 5.5 cc FIRE or RIRE speed engine
weight: from 1200 g
kit price: 145.- €
  • Name: Beretta21_0.JPG
  • Name: Beretta21_1.JPG
  • Name: Beretta21_2.jpg
  • Name: Beretta21_2_.jpg
  • Name: Beretta21_3.jpg
  • Name: Beretta21_4.jpg
  • Name: Beretta21_5.jpg
  • Name: Beretta21_6.jpg
  • Name: Beretta21_7.jpg
  • Name: Beretta21_8.jpg
  • Name: Beretta21_9.jpg
  • Name: Beretta21_10.jpg
  • Name: Beretta21_11.jpg
Old Jul 25, 2009, 12:04 PM   #5
RC-Tronics-Topp-Rippin OHG
Weststrasse 39
58638 Iserlohn
Germany
TEL +49 2371 9728 97
FAX +49 2371 9728 96
www.rc-tronics-topp-rippin.de
http://stores.shop.ebay.de/Rc-Tronics-Topp-Rippin
rippintopp(et)aol.com
rippin-topp(et)aol.com
MIRAGE 2000 mini
description:
The Mirage 2000 is a superlative delta type jet fighter. Like the original the mini MIRAGE's unique design is paired with excellent flight characteristics and a wide speed range. It is very fast and offers sound aerobatic capabilities. Superb rolls, large loops and low high-speed dives are a pleasure - but the delta configuration offers great low speed capabilities too.
kit content:
kit with white gel coat finished glass fuselage and engine cowl (= tail jet nozzle)
CNC-cut foam core + obeche sheeted + glass reinforced wing (one-piece design, compression-mold)
wooden parts (tail unit, etc)
transparent cockpit canopy
small parts
construction plan
technical data:
wingspan: 850 mm
wing area: 19.5 dm^2
length: 890 mm
motor : 3.5 - 5 cc
weight: from 1000 g
kit price: 149 €
  • JETT BSE .35 FISE 5.5 cc (tilted) + Jett-Stream tuned muffler (available with the exhaust outlet facing the pusher propeller, see pic ) + APC 9X6 pusher prop (#LP0906P) for training and APC 10x7 pusher prop (#LP1007P) shortened/rebalanced to 8x7 for speed
    => max top speed of about 150 mph
  • Name: MIRAGE mini by TOPP-RIPPIN_1.jpg
  • Name: MIRAGE mini by TOPP-RIPPIN_2.JPG
  • Name: MIRAGE mini by TOPP-RIPPIN_3.JPG
  • Name: MIRAGE mini by TOPP-RIPPIN_4.JPG
  • Name: MIRAGE mini by TOPP-RIPPIN_5.jpg
  • Name: MIRAGE mini by TOPP-RIPPIN_6.jpg
  • Name: MIRAGE mini by TOPP-RIPPIN_7.jpg
Old Jul 25, 2009, 12:29 PM   #6
Last edited by I-Love-Jets; Sep 14, 2009 at 09:06 AM. Reason: shop doesn't exist any longer
Old Jul 25, 2009, 12:40 PM   #7
Fliegerland
Sinsheimer Str. 2
69181 Leimen - St. Ilgen
Germany
http://www.fliegerlandshop.de
Telefon: +49 6224 82675
Telefax: +49 6224 54438
info(et)fliegerlandshop.de
MAMBA (very similar to Club20 pylon racer DARA by Flair)
kit # FL-1000 content:
- glassed fuselage (white)
- glass fiber canopy
- one-piece wing (foam) featuring glass reinforced balsa sheeting
- wing prepared for Robbe Servo-Lock #1
- control surfaces already cased and sanded
- leading edges and tips of wing and stab are already sanded
- epoxy-glued wing + stab, ready for the finish
- balsa horizontal stab and balsa vertical stabiliser
specifications:
wingspan: 920 mm
length: 830 mm
weight: from 1100 g
motor: 2.5 – 5.5 cc speed engine
kit price: 149.95 €
The construction manual for the Mamba short kit.
  • Name: Mamba By Fliegerland_1.jpg
  • Name: Mamba By Fliegerland_2.jpg
  • Name: Mamba By Fliegerland_3.jpg
  • Name: Mamba By Fliegerland_4.jpg
Old Jul 25, 2009, 12:57 PM   #8
Weststrasse 39
58638 Iserlohn
Germany
Fletscher
description:
The FLETSCHER is a speed plane universally applicable - ranging from “tame to super hot“. Also usable as a quick aerobatic trainer!
kit content:
small parts
construction plan
technical data:
wingspan: 1.280 mm
airfoil: symmetrical
length: 1.060 mm
motor : up to 8 cc (or a hot .60 in a .40 case)
weight: 1.800-2.600 g
kit price: 140 €
  • Name: Fletscher by TOPP-RIPPIN_1.jpg
  • Name: Fletscher by TOPP-RIPPIN_2.JPG
Old Jul 25, 2009, 01:18 PM   #9
Matney's Models
10765 Victory Road
Erie, MI 48133
USA
Tel: 734-848-8195
Fax: 734-848-8195 (pause) then 5*
http://www.matneymodels.com/
info2005(et)matneymodels.com
Napier - classic QM40 Pylon Racer
description:
This highly competitive QM40 design by Kevin Matney is all CAD designed, and features a hand-laid fiberglass fuselage made of the highest grade epoxy available. If you're looking to go FAST and turn left, then this kit is for you. The beautiful model pictured (pic#1) was on display at the April 1997 Toledo Expo and won a second place ribbon for Best Finish as well as a second place ribbon in Sport Mono Plane. .
This aircraft meets all current AMA 422 QM40 specification.
specifications:
R/C: elevator, ailerons, rudder, throttle optional
wingspan: 54 inches
wing area: 405 sq in
motor: 6.5 to 8 cc (or a hot .60 in a .40 case)
weight: 4.0 lbs
basic kit contents:
Hand laid epoxy-glass fuselage, foam wing cores, landing gear, and plans.
kit price: $130.00
Napier build thread:
http://www.rcuniverse.com/forum/m_67..._1/key_/tm.htm
  • Name: Napier by Matneymodels_1.jpg
  • Name: Napier by Matneymodels_2.jpg
  • Name: Napier by Matneymodels_3.jpg
  • Name: Napier by Matneymodels_4.jpg
  • Name: Napier by Matneymodels_5.jpg
  • Name: Napier by Matneymodels_6.jpg
  • Name: Napier by Matneymodels_7.jpg
Old Jul 25, 2009, 01:48 PM   #10
X-treme Composite
OFFICE : 11/6 Hatairadjh Rd., Minburu, Minburi, Bangkok 10510, Thailand.
FACTORY : 256 Moo 5, Ladtakien, Kabinburi, Prachinburi 25110, Thailand.
tel: +66(0)2518-2067 to 9
fax: +66(0)2517-9318
www.xtremecomposite.com
xtreme(et)minicrafthobby.com
http://www.xtremecomposite.com/pricelist_usd.asp
http://www.xtremecomposite.com/distributor.asp
http://www.wildharerc.com/products/lr1racer/
http://www.throttlestore.com/planes/...l.aspx?lang=EN
http://www.sussex-model-centre.co.uk...d.asp?id=28455
Speed Cat (distributed by Graupner) identical to Wildhare LR-1 and The Racing Devil
description:
ARTF Sport GRP Moulded Pylon Racer
The Graupner Speed Cat is a pylon racer of all-GRP construction. All the models components, i.e. fuselage, wing, tailplane and wheel fairings, are supplied as ready-made moulded items, painted in the mould, with a high-gloss finish. The impressive features of the Speed Cat are its beautifully harmonious lines and the distinctive apple cheeks, which give the model an interesting semi-scale appearance. The model is capable of very high airspeeds. At the same time the aerodynamic layout of the Speed Cat gives the model pleasantly stable flying characteristics, and any RC pilot with average flying skills will not find it difficult to control.
kit content:
Building instructions in German, English and French. One-piece wing, fuselage, tailplane and wheel fairings supplied as pre-painted GRP mouldings. Pre-formed aluminium undercarriage unit, two foam rubber wheels, accessories for glow motor power such as fueltank, motor mount and plastic spinner, small items, decal sheet, linkage hardware pack.
specifications:
wingspan: 1010 mm
length: 860 mm
wing area: 18.8 dm.sq.
tailplane area: 3.2 dm.sq
motor: 3.5 to 5.5 cc FIRE or RIRE or FISE speed engine
weight: from 1200 g
kit price: ca. 170 €
building tips:
http://www.rcuniverse.com/forum/fb.asp?m=3934670
video:
Speed Cat (LR-1) with JETT BSE .35 FIRE and APC 8x7 prop.
According to Doppler audio shift the fastest pass is 175 mph (downwind from minute 2:48 to 2:55. Headwind passes always are about 140 mph)
LR1 190 MPH (6 min 15 sec)
  • Name: Speed Cat aka LR-1 aka Racing Devil_1.jpg
  • Name: Speed Cat aka LR-1 aka Racing Devil_2.jpg
  • Name: Speed Cat aka LR-1 aka Racing Devil_3.jpg
  • Name: Speed Cat aka LR-1 aka Racing Devil_4.jpg
  • Name: Speed Cat aka LR-1 aka Racing Devil_5.jpg
  • Name: Speed Cat aka LR-1 aka Racing Devil_6.jpg
  • Name: Speed Cat aka LR-1 aka Racing Devil_7.jpg
  • Name: SpeedCat JETT35BSE - 175 mph downwind from minute 2-48 to 2-55.JPG
Old Jul 25, 2009, 02:21 PM   #11
Fliegerland
Sinsheimer Str. 2
Germany
Cobra (very similar to Simprop's famous Speed Cobra speed plane)
kit # FL-1010 content:
- glassed fuselage (white) featuring smooth transitions to wing and stab
- wing prepared for Robbe Servo-Lock #2
- balsa sheeted horizontal stab (foam) – already sanded
The construction manual for the Cobra short kit.
specifications:
wingspan: 1220 mm
length: 1280 mm
weight: 2500 to 3000 g
motor: 13 - 20 ccm FIRE or RIRE speed / ducted fan engine
kit price: 209.95 €
description:
The COBRA is the standard beginner speed plane over here in Europe for people loving hot 13 to 15 cc rear exhaust engines. Because the fuse is very spacious, it is easy to install a large tank. However it comes with a quite fat wing and tail airfoil making a powerful 10 cc FIRE or RIRE engine (OPS, ROSSI, PICCO, JETT) already too weak for reasonable top speed...
Only with a strong 13 cc or larger ducted fan engine such like
- OS .91 VR-DF
- OPS .80 and .90 and 1.20 DF
- ROSSI R90 DF or larger
- PICCO P90 DF
- K&B .82 DF or larger
- ANGSTREM 91 DF
- Nelson/BVM .91R
the Cobra airframe can be brought to true 190 mph. The best propeller that is able to handle that relative high amount of drag is the APC 10x10“ prop, cut down to 9“ diameter. As you can imagine more prop pitch leads to lower terminal speeds of the Cobra. Same applies to smaller and larger prop diameter than 9“ in this special case.
Attention:
It it very dangerous to apply the regular grey plastic APC 10x10 prop with these ducted fan engines. Many of these 10x10 standard APC props failed already on the ground during test runs! – Fortunately nobody has been hurt so far.
For safety reasons over here people therefore make hand laid continuous strand carbon fiber copies of that standard plastic APC 10x10 sport prop (pics below). These 9x10 CF "APC" props are widely used by the Speedcobra pilots. RCGroups member RocketRob for instance does make 9x10 CF props...
The setup of the green/black Cobra is:
  • OS .91 VR-DF
  • BVM tuned pipe (custom made "fuse-top" style header that can also be ordered from MACS Producs http://www.macspro.com/headers_rear.asp ; tuned pipe length is about 30 cm between glow plug and middle of the pipe belly)
  • fuel: 20% oil, 15% nitro
  • above mentioned 9x10" CF propeller
  • BVM R/C in-flight mixture control
Cobra video (OS .91 VR-DF + Angstrem muffled tuned pipe + 10x10" APC carbon copy:
Cobra von Fliegerland (1 min 10 sec)
To conclude:
Over here in Europe this plane is very famous especially for the speed beginners preferring the “big block“ 13 cc to 20 cc ducted fan engines. Due to its size and harmless flying characteristics it is an ideal speed trainer. This plane is hard to stall during landing – very low speed touch downs are possible. But the stock Cobra cannot break 200 mph, as proven during past EURO Speed-Cups. Nowadays you will hardly find Cobras used for F3S Speed Cup competition. Other special speed plane designs (purpose built) are considerably faster - with the same engine and a speed prop sized smaller and pitched more aggressively.
  • Name: Cobra by Fliegerland_1.jpg
  • Name: Cobra by Fliegerland_12.jpg
  • Name: CF speed prop 9x10 for Cobra_1.jpg
  • Name: CF speed prop 9x10 for Cobra_2.jpg
  • Name: CF speed prop 9x10 for Cobra_3.jpg
Old Jul 25, 2009, 02:27 PM   #12
Old Jul 25, 2009, 02:39 PM   #13
RC-Technik
Michael Dieterle
Lichtensteinstr.27
71088 Holzgerlingen
Germany
STINGER 21
description:
This is our Stinger 21 made by Jet and Speedmodels from The Netherlands. This beautiful speed plane is easy to fly. Landing gear has been omitted for improved aerodynamics. The construction features a glass fuselage and a very strong wing. It doesn't have bad flying attitudes: Characteristics are tame (slow landing speed) and very stable during the entire speed range. The Stinger 21 flies like it is on rails!
kit content:
obeche sheeted foam wing
CNC cut wing spar
technical data:
wing span: 1180 mm
weight: from 1200 g
kit price: 149.- €
  • Name: Stinger 21_1.jpg
  • Name: Stinger 21_2.jpg
  • Name: Stinger 21_3.jpeg
  • Name: Stinger 21_4.JPG
Old Jul 25, 2009, 03:00 PM   #14
TOPMODEL Schweiz
Avidox AG
Standbachstrasse 24
8370 Sirnach
Switzerland
www.top-model.ch
www.topmodell.ch
info(et)avidox.ch
SHARK 40 – classic pylon racer (formerly by FLAIR)
description:
The SHARK 40 (#1228) is a typical classic pylon racer: It features an elliptical wing geometry, a large wing chord and an engine cowl with classy “cheeks”.
But the Shark 40 is not only made to go straight fast and turn left on the pylon course, it is also well-suited for general speed flying just for great fun!
Shark 40 – a true timelessly elegant yet sharp racer!
kit content:
glass fuselage with white finish
white coloured glass engine cowl
stab and vertical fin made of wood
engine mount
linkages and rods
small parts
construction plan
technical data:
wingspan: 1160 mm
length: 1120 mm
weight: 2150 g
kit price: 258 SFr (Swiss currency)
  • Name: Shark40 by Flair_1.jpg
  • Name: Shark40 by Flair_2.jpg
Old Jul 25, 2009, 03:24 PM   #15
Matney's Models
10765 Victory Road
Erie, MI 48133
USA
Tel: 734-848-8195
Zoomer
The Zoomer is sort of a cross-breed between a Q-500 and a Formula 1. Designed for an event called "Animal 500", this no-hold barred speed design is incredibly popular with sport flyers and speed fanatics alike. It is fully aerobatic, very smooth and precise, and it slows down nicely for a gentle, smooth landing. The Zoomer is available with your choice of wing! The tapered wing is designed for high speeds and racing. Also available with our 12% thick semi-symmetrical and 15% thick full-symmetrical Sport wings - constant chord - for improved slow speed and better aerobatic capabilities. The semi-kit features a high quality, light weight epoxy-glass fuselage, along with precision cut wing cores. If you're looking to go fast or fly an aerobatic sport plane that really grooves, then this kit is for you.
This aircraft is NOT legal under AMA 428, 424 and most other Q-500 competition rules
specifications:
wingspan: 50 inches
wing area: 500 sq in
weight: 4.5 lbs
basic kit contents:
epoxy-glass fuselage, foam wing cores, and plans
kit price: $95.00 (for each wing version: tapered 12% - race; 12% - semi sym or 15% - full sym)
Zoomer build thread:
http://www.rcuniverse.com/forum/m_64..._1/key_/tm.htm
engine/pipe/prop recommendations for the 12% wing:
  • Name: Zoomer by Matneymodels1.jpg
  • Name: Zoomer by Matneymodels2.jpg
  • Name: Zoomer by Matneymodels3.jpg
  • Name: Zoomer by Matneymodels4.jpg
  • Name: Zoomer by Matneymodels5.jpg
  • Name: Zoomer by Matneymodels6.jpg
  • Name: Zoomer by Matneymodels7.jpg
  • Name: Zoomer by Matneymodels8.jpg
  • Name: Zoomer by Matneymodels9.jpg
Question Graupner speed props - where to buy ? i3dm Power Systems 2 Jun 30, 2008 06:37 AM
Discussion Cheaper 5g/9g Servos and where you buy them Hytram Australia 28 Jun 05, 2007 08:25 PM
Discussion batteries... which ones to get and where to buy them? soholingo Hand Launch 24 Jun 01, 2006 02:33 PM
Carbon Fiber Spinners and Landing Gear. Where to buy them? Joe Elston Sport Planes 2 Aug 30, 2002 04:03 AM
Up 'n Go - Where to Buy Them??? green66 Electric Sailplanes 4 May 20, 2002 07:08 PM
Bored? Want to fight?
Join the RCGroups clan!
