Old Jul 23, 2009, 11:09 PM
russainred95 is offline
Find More Posts by russainred95
flying = good for my eyes
russainred95's Avatar
Spokane, Washington
Joined Jan 2007
Mini-HowTo
Aquacraft EP1 Outboard Motor-- Theory on How to take apart
Hello all,
UPDATE: If you buy your outboard from the online store you should have the shaft puller included already.
I would like to make a mini-how-to without having to go through the process of drilling holes in your outboard Ep1. This is supposed to work in theory, because i already took apart mine (by drilling a hole) so i have no way of going back and testing it.
Step #1-
Remove plastic cover from your outboard motor, and remove the brushed motor which is attached by 2 hex screws.
Step #2-
Next remover the propeller, the propeller shaft(this can bend very easily so check if yours is straight), and the 2 bearings that hold the propeller shaft.
Step #3-
Clean out all the grease.
Step #4-
Now take your outboard unit and look directly where the main motor was inserted. You should see the second part of your brass coupler. INSIDE of it there will be a thread where you can insert a bolt. Find a bolt and screw it right into your coupler. The idea is to screw it in and use this bolt to pull the main shaft out, with the bearings. In theory nothing will break because of the way it is attached.
However, how you use to remove the shaft with the bolt, is up to you. I would simply put a few nuts on your bolt, which are wide enough so that it will hold on to the motor mount allowing you to unscrew the nut and slowly pulling the main shaft and bearings out. A picture in paint should give you an idea of how this can be done.
russainred95 is offline Find More Posts by russainred95
Old Jul 24, 2009, 02:10 AM
Flying Barry is offline
Find More Posts by Flying Barry
Australia, NSW, Sydney
Joined Jan 2007
russainred95,
It all great info but i would put this into the "Racing Boats - Electric" rather than here in the Racing Boats - Internal Combustion.
Barry
Flying Barry is offline Find More Posts by Flying Barry
Old Jul 24, 2009, 11:09 AM
Spokane, Washington
Joined Jan 2007
Originally Posted by Flying Barry
russainred95,
Barry
Thanks for catching that. I couldn't figure out where this would go... LOL
I'll request mod to move...
Old May 24, 2011, 06:38 AM
rc_boat_lover is offline
Find More Posts by rc_boat_lover
Joined Dec 2010
How do I take the swinging part of it (is it called the transom)
rc_boat_lover is offline Find More Posts by rc_boat_lover
Discussion HELP, JST female connector, how to take apart? lovespicyfood Batteries and Chargers 14 Jan 26, 2011 12:24 AM
Question How to take apart a brushless motor? shah Power Systems 10 Jul 12, 2009 09:30 PM
How to take apart the HS-50? robert harik Hitec/Multiplex USA 1 May 17, 2004 12:01 PM
Still need info on how to retime a motor with an Astro Super Whattmeter Joe Elston Electric Plane Talk 8 May 19, 2001 11:42 PM
how to take apart astro 020 brushless? BillH Electric Plane Talk 3 May 05, 2001 11:39 PM
