| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||
#61 | |
But then again, every thing may transfer over, I don't really know. |
#62 | |
Heli Crasher
#63 |
You could try calling horizon or emailing them, i'm sure they will be willing to help you.
#64 | |
Dave, Are the mSR's going right to shops when they get to port or will they be held back until the September release date/schedule? Seems that if they are on the way now they might be available earlier than expected. ![]() Jared |
#65 | |
Heli Crasher
#66 | |
Horizon Hobby
#67 | |
#68 | |
Horizon Hobby
David |
#69 | |
Heli Crasher
#70 |
Now you can start thinking about some scale fuselages for this micro heli, better if they come from E-Flite. Definitely a lot nicer to have a single rotor Jet Ranger in this size. I guess it may be arriving around November to Ecuadorian soil.
Cheers, Carlos A. Cordova QUITO - ECUADOR |
#71 | |
#72 | |
Maybe its just the manufacturer and not the motor...? If taken care of and not abused, I am willing to bet these mSR's will be just fine, PLUS reliable manufacturer is worth paying a little more for in my opinion |
#73 | |
Hover-skate-airsoft-golf
In a way youre right about the fact that walkera brushed motors has fueled many 4-3B fliers to go brushles but I also agree with whilybird about the fact that if the technology is there, why not use it? Brushless to me means no more replacement motors (as long as they contain bearings instead of bushings that is). I also like to think that my heli would have a longer life span before I get fed up of it. Walkera brushed motors meant that you had to replace a part (the motor) of the heli the more you flew it regardless whether if you have had no crashes on it. Usually when you give up on a heli its because you need to replace a part and cant be bothered with it anymore so it ends up on the shelf to gather dust never to resurrected again. |
#74 | |
n00b pilot
OTOH, I have a 4#3B that went through a motor in maybe 50 flights. After that, I put a BL kit on it. If you ask around, you'll find this a common sentiment. |
#75 |
I meant to do that!
Walkera brushed motors use copper strips for the brushes, not actual brushes. These strips lose tension as they are subjected to heat. When they lose tension, they lose contact with the armature and that's that. This has been one of my biggest gripes with Walkera for a long time. It's not like they made a mistake once and are correcting it. They use this same cheap design on most of their small motors.
There are good brushed motors. Even Helimax uses good carbon brushes in their crappy Axe CX coax. These are the same motors Walkera uses in the 4#3B, 4-3Q, 5G6-1, and UFO #5; but with copper strips. Of course the Axe CX motors last much, much longer. |
