Espritmodel.com Heli Air
Old Jul 23, 2009, 11:45 AM
AR Racing
Jena67's Avatar
Italy, near Milan
Joined Mar 2005
1:5 race bike from AR Racing!
AR Racing will participate at the 1:5 RC Bike World Championship with
the new ARS race bike.
This bike was developed in cooperation with Hugo Binder from Germany.
Our new ARS bike ist the result of merging Hugos race proven frame
concept with the durability of AR Racing bike design.
Some of the features of this new bike concept are (in comparison to most
other known bikes):
- optimized battery position: following the 1:1 bike theory of the ideal
CG position and mass centralization
- higher CG for higher turn speeds at same lean angle
- weight balance: more weight on the front wheel
- longer swing arm matching the proportions of real bikes
- friction optimized drive train with main gear/sprocket unit
- light and flexible rear frame
- easy access to all components for quicker maintenance
The AR Racing Factory Team will participate at the worlds 2009 in
Leipzig with 4 pilots, in the superbike (3) and the stockbike (1) class.
In the attached pictures you can see the superbike model close to a pre production model 95% similar to the one we will sell.
We plan to start the first production batch after summer holidays.
Ciao
Jena67 is offline Find More Posts by Jena67
Old Jul 23, 2009, 01:16 PM
Classic minis rock!!
UK, Bristol
Joined Jan 2007
Well cool antonio, looks good and very different to!
Hope it does well at worlds!
Lee.
lee1980 is offline Find More Posts by lee1980
Old Jul 23, 2009, 04:58 PM
Dez82's Avatar
Warwick - UK
Joined Feb 2006
I first saw this at Nuremberg, looking forward to seeing it in action at the worlds, not long now!
Dez82 is offline Find More Posts by Dez82
Old Jul 23, 2009, 11:49 PM
ฺBangkok, Thailand
Joined Jun 2009
Very cool Antonio! Good luck at the Worlds!
reefhobby is offline Find More Posts by reefhobby
Old Jul 24, 2009, 02:47 AM
Risknreward's Avatar
Joined May 2009
Good Luck the bikes look sharp
Risknreward is offline Find More Posts by Risknreward
Old Jul 24, 2009, 11:59 AM
JAM
MaxAmps CMO
JAM's Avatar
Nine Mile Falls, WA
Joined Jun 2004
Very interesting for sure. I can't wait to see more on this. I like the use of a standard Li-Po pack. This will give users a wider variety of pack choices. We will be sure to add this to the website for packs that will work with it as soon as you have the full specs out.
Jason
JAM is offline Find More Posts by JAM
Old Jul 24, 2009, 03:56 PM
dan duesentrieb's Avatar
germany
Joined May 2004
ARS pictures
Hi,
here some more pictures of the new ARS bike. The plastic parts are rapid prototyping parts, later they will be injection moulded and black.
The new battery position makes the handling of the bike more responsive and more precise than you know from the usual bikes with low batteries.
Every driver at the worlds is invited to try it out after the competition.
ciao,
Hugo
dan duesentrieb is offline Find More Posts by dan duesentrieb
Old Jul 24, 2009, 04:38 PM
AR Racing
Jena67's Avatar
Italy, near Milan
Joined Mar 2005
Here are some 3D drawings.
As you can see a peculiarity of this design is the possibility to remove the motor and the esc together unscrewing 4 M4 screws.
Really easy maintenance!
The swing arm shaft is directly fixed to the upper frame plate for maximal torsional rigidity.
The shaft itself isn't rotating to keep the rotating masses at the minimum.
More info later...
Old Jul 24, 2009, 04:41 PM
TroyM's Avatar
Gold Coast, Australia
Joined Jul 2006
do you have any problems with motor/esc overheating with the restricted airflow though the bike ?
TroyM is offline Find More Posts by TroyM
Old Jul 24, 2009, 04:49 PM
AR Racing
Jena67's Avatar
Italy, near Milan
Joined Mar 2005
As you can see we have made the right lover frame plate in aluminum to dissipate motor heat, the ESC is in a perfect cooling position as long as you open a window in the front part of the body, right behind the front wheel
The airflow is really good.
No heating problem so far....
Ciao
Old Jul 25, 2009, 04:08 AM
Torrance's Avatar
Joined May 2009
the bike looks great. good luck during the worlds. i look forward to a great battle!
Torrance is offline Find More Posts by Torrance
Old Jul 26, 2009, 04:07 AM
TT-Tom's Avatar
Germany
Joined Jul 2006
Great job Hugo!!
I have seen the bike in action at our last training session and it is fast too!!
It will be a great battle in Leipzig!
TT-Tom is offline Find More Posts by TT-Tom
Old Jul 26, 2009, 09:50 AM
BACKEMFNRG's Avatar
Canada, ON, Acton
Joined Oct 2003
Fantastic. So many new bikes, its great to see. Good luck at the worlds!
BACKEMFNRG is offline Find More Posts by BACKEMFNRG
Old Aug 04, 2009, 12:05 AM
germany
Joined May 2004
worlds result
The worlds have been lot of fun and we learned a lot in our first year of participation.
We are proud that we were able to make the 9th place in the superbike class, where AR-Racing pilot Thomas Kriener was the best german driver.
Thanks to all competitors for the fair races and the open minded exchange!
Best,
Hugo Binder
AR Racing Factory Team Manager
Old Aug 04, 2009, 10:42 AM
Post Falls, ID United States
Joined Feb 2004
Great job, its not easy to go to a big race with a new bike.
I was wondering why the bike has a long wheelbase from the side views in the photos?
Chris
Chris Nicastro is offline Find More Posts by Chris Nicastro
Discussion 1:5-scale bike racing in Vegas, anyone? Guidoracer Motorcycles 14 Mar 20, 2009 01:35 AM
Molzer Mowery 1/5 Scale Bike ?? CRAZYNUT Motorcycles 17 Nov 10, 2005 11:43 AM
Modded 1/5 nitro bike with .21! mollycbr123 Motorcycles 18 Mar 08, 2005 08:21 PM
Nuova Faor 1:5 scale bike novaman Cars - Cars and Parts (FS/W) 15 May 16, 2004 08:51 PM
full home made 1/5 scale bike papo Motorcycles 1 Feb 17, 2004 06:58 PM
