Old Apr 09, 2003, 10:48 AM
LESLIEx317537 is offline
Find More Posts by LESLIEx317537
Inbox is almost full
LESLIEx317537's Avatar
Long Island, New York
Joined Nov 2002
Astro Micro Gearbox (8.0 g, 3.3:1) for Astro Flight 010 Brushless Motor
I was wondering if this new Astro Flight Micro Gearbox can be easily fit to a Tiger Moth. - http://www.aeromicro.com/Astro010GB2.htm
Also does it use this motor? - Motor
It is expensive, but looks like if you had that in a Moth and went full throttle into pavement, nothing would break. I mean the current GWS gearbox with Astro is still Plastic and wears and can break.
I want my Moth to last for a long time on the same equipment.
LESLIEx317537 is offline Find More Posts by LESLIEx317537
Old Apr 09, 2003, 11:06 AM
Tres Wright is offline
Find More Posts by Tres Wright
Live to ride... and fly!
Tres Wright's Avatar
Forney, TX
Joined Mar 2002
Hey Leslie-
I couldn't get your "motor" link to work, but the gearbox mounts to the standard direct drive 010 motor. It's a lot of thrust for a Tiger Moth, but it would work. You'd have to figure out a motor mount as the 010 does not have one. That's one of the nice things about using the GWS box, it has a mount built in.
==but looks like if you had that in a Moth and went full throttle into pavement, nothing would break==
If you ran full throttle into the pavement, I would expect that it would indeed break. The motor might survive, but the gearbox more than likely would not. At a minimum it would probably bend the shaft. This gearbox would definitely be more durable than a GWS box, but on the other hand it's cheap to fix or replace a GWS box. As for looks, the AF polished aluminum box wins hands down!
Tres Wright is offline Find More Posts by Tres Wright
Old Apr 09, 2003, 11:29 AM
Joined Nov 2002
Thanks Tres,
So the Aluminum gearbox doesn't have a hole for the stick to mount onto?
Also is it lighter than the GWS plastic setup or heavier?
Old Apr 09, 2003, 01:35 PM
Sal C is offline
Find More Posts by Sal C
Giddy up!
Sal C's Avatar
Woodridge, Illinois
Joined May 2000
Re: Astro Micro Gearbox (8.0 g, 3.3:1) for Astro Flight 010 Brushless Motor
Originally posted by LESLIEx317537
...It is expensive...
I only paid $25 for mine from Azarr...
Sal C is offline Find More Posts by Sal C
Old Apr 09, 2003, 03:30 PM
MKH is offline
MKH
Find More Posts by MKH
MKH
Ohio
Joined Mar 2000
[B]Thanks Tres,
Also is it lighter than the GWS plastic setup or heavier? [/B
This gearbox looks to be a firewall mount. I think the 'mount on a stick' design is pretty exclusive to GWS gearboxes, at least from what I've found. I think the Astro unit may be a few grams less than the GWS boxes, until you add the prop adapter, then it's a few grams more. Looks like a super unit for those that can use the 3.33 ratio, and want something more robust. I need higher ratios and stick mounting, so I use the GWS boxes from Aeromicro.
Marcus
MKH is offline Find More Posts by MKH
Help! New 3 in 1 for Rotofly jayb79 Micro Helis 0 May 14, 2006 03:59 PM
Replacement 3 in 1 for aerohawk ariesmars Micro Helis 10 Oct 26, 2005 12:03 AM
looking for a 3-in-1 for my heli need it quick littlepiston Aircraft - Electric - Helis (FS/W) 2 Apr 02, 2005 08:36 PM
Use the 3 in 1 for Gyro and Mixer only? jnatran Micro Helis 7 Aug 27, 2004 09:31 PM
Astro Micro Gear Box (8.0 g) GoEFlight Parkflyers 11 Mar 27, 2003 12:03 AM
