This thread is privately moderated by CyberJay, who may elect to delete unwanted replies.
Old Jul 22, 2009, 09:41 PM
CyberJay is online now
Find More Posts by CyberJay
Rsetiegerd Uesr
CyberJay's Avatar
USA, AR, Cave Springs
Joined Apr 2005
Kangke 25% Monocoupe 90A
My first gas/electric conversion. My first giant scale. Before this my largest plane was a 55" Eflite T-34, so this is a big step up. So far I've been getting 9 minutes of flight and putting between 4000 and 5000mah back into the pack when charging as a 5s2p 10,000mah pack.. So I bet I can get 15-20 minutes of conservative flight. Not that I'd really want to do that, but I could!
AUW: 17lbs 4oz.
Static test:
1500 watts with a 19x8 prop.
2000 watts with a 19x10 prop.
Kangke USA:
1/4 Scale Monocoupe 90A
Turnigy:
AerodriveXp SK 63-64 230Kv outrunner
Sentilon 100A HV ESC
19x10 Beechwood light electric prop
Spektrum:
DX9 transmitter
AR9350 AS3X receiver
(2) DSMX satellites
SPMA9605 flight pack energy sensor
Hitec:
(4) HS-7966HB servos (ailerons, elevator, rudder)
(2) HS-475HB servos (flaps)
Caste Creations:
CCBEC Pro
Pulse:
Ultra 10s1p 5000mah 35c LiPo (5s1p x2)
CyberJay is online now Find More Posts by CyberJay
Old Jul 26, 2013, 05:25 AM
Guidobove is offline
Find More Posts by Guidobove
Joined Jul 2013
Hello Cyberjay,
I bought the same configuration as yours. I have one problem left.... I don't know if I have to center the motor mount on the firewall or if I have to move it from the centerline (2° right thrust) and how much must I move it?. Can you please help me out? My mailadres : guido.bove@pandora.be
I am living in Belgium Europe.
Kind regards
Guido Bové
Guidobove is offline Find More Posts by Guidobove
Old Jul 26, 2013, 06:23 AM
Rsetiegerd Uesr
CyberJay's Avatar
Joined Apr 2005
Originally Posted by Guidobove View Post
Hello Cyberjay,
Kind regards
Guido Bové
I centered it, and I thought it came out looking fine. I used two washers under the left hand motor mounts to get the right thrust.
Good luck with it, I like this plane.
-J
Old Jul 27, 2013, 08:20 AM
Joined Jul 2013
-J
Thanks a lot J !!!!
Old Nov 07, 2015, 10:14 AM
3.14 is offline
Find More Posts by 3.14
Joined Nov 2015
I am about to pull the trigger on this plane, I will be going brushless. I would appreciate any advice you can offer.
3.14 is offline Find More Posts by 3.14
Reply With Quote  (Disabled)
Old Nov 10, 2015, 08:08 AM
Rsetiegerd Uesr
CyberJay's Avatar
Joined Apr 2005
I'm not sure what to say beyond what's in the pics. There's tons of room, so no problem mounting stuff. I had to mount everything as far forward as I could in order to get the CG right without adding lead.
Good luck with it.
-J
Old Nov 10, 2015, 08:16 AM
3.14 is offline
Joined Nov 2015
Good luck with it.
-J
I am going with a very large motor, either the E-Flite Power 360 or the 180.
http://www.horizonhobby.com/eflm4360a
http://www.horizonhobby.com/power-18...95kv-eflm4180a
Discussion 1/4 scale Kangke Monocoupe 90A conversion karl k Giant Electric Planes 14 May 18, 2008 06:51 PM
Found Kangke 1/5 Monocoupe 90A ARF Yardbee Aircraft - Fuel - Airplanes (FS/W) 0 Oct 18, 2007 02:50 PM
Wanted Kangke Monocoupe 90a Stewby Aircraft - Fuel - Airplanes (FS/W) 3 Nov 01, 2006 09:59 PM
Wanted Wanted: Kangke Monocoupe 90A/60 Fusealage sgillmore Aircraft - Fuel - Airplanes (FS/W) 0 Jul 04, 2006 11:33 PM
Wanted Kangke Monocoupe 90A/60 Fuselage sgillmore Aircraft - Fuel - Airplanes (FS/W) 2 Mar 02, 2006 07:39 PM
