This thread is privately moderated by what the helli, who may elect to delete unwanted replies.
Old Jul 22, 2009, 02:20 PM
what the helli is offline
Find More Posts by what the helli
Trader Rating: 12
Crashing! It's what I do best!
what the helli's Avatar
USA, TN, Cookeville
Joined Mar 2009
Trader Rating: 12
For Sale
CNC 4 Axis Hot Wire Foam Cutter
This is cutter is one that was bought new by copperhead aviation a few years ago (now owned by OMP)
to build their EPP foamy planes like the extra stiffy
This is a foamlinx model
FC3920 - 4 Axis Automatic hot wire CNC Foam Cutter
FC3920
currently it is set up to cut:
39" Long
20" high
32" wide----This can be changed
There are two dowel pins set in the table to set jigs in
Also a stiffing cage that helps ensure repeatable accurate cuts
This is the setup they used for manufacturing.
I bought the machine from copperhead so I am the second owner of the machine and it works great.
BUT the computer really needs updated. I was making files on my laptop,
then moving them to the cutting machine as it would error if I tried to make the files on it.
Foamworks and Cadworks are installed on it.
You will also get
3 Large slabs of EPP foam 39" x 49" x 6" and 2 small pieces
also some extra cutting wire
variac power supply
This is to big to ship so I am willing to drive half a day to meet someone. Beginning point is Cookeville TN 38506
Machine is $5499 new and you don't get:
Software, EPP foam, 4 axis controller board, CNC Power supply, Variac power supply, computer and monitor, table, or stiffening cage. All of which I am including
$2500 May be willing to take up to half in trade, for??? Just tell me what you got
what the helli is offline Find More Posts by what the helli
Old Aug 01, 2009, 10:14 AM
Trader Rating: 12
USA, TN, Cookeville
Joined Mar 2009
Trader Rating: 12
Offers, trades, or questions all are welcome
Old Aug 22, 2009, 08:20 PM
Trader Rating: 12
USA, TN, Cookeville
Joined Mar 2009
Trader Rating: 12
Still for sale
Discussion CNC hot wire foam cutter Kroko The Builders Workshop 0 Jul 22, 2009 02:54 AM
For Sale CNC Hot Wire Foam Cutter northropn9m Aircraft - General - Miscellaneous (FS/W) 0 Sep 26, 2008 11:29 AM
Found CNC hot wire foam cutter Geode Aircraft - General - Miscellaneous (FS/W) 0 Mar 03, 2008 11:32 PM
Found CNC Hot Wire Foam Cutter Geode Aircraft - General - Miscellaneous (FS/W) 0 Mar 03, 2008 04:12 PM
Wanted CNC Hot Wire Foam Cutter Geode Aircraft - General - Miscellaneous (FS/W) 1 Oct 19, 2007 09:46 AM
