Old Jan 20, 2013, 05:42 AM
mark_snipz is offline
Find More Posts by mark_snipz
Joined Sep 2012
Hitec Aurora.
I've just checked the endpoints and that's ok Tx end.
The ESC shows no signs of being damaged, externally, and it programs from Normal to Auto modes fine.
Is there any other programming available with this stock ESC, it doesn't make start-up beeps like the one that comes with my Radian Pro?
I'm going to stick up a vid in a but to show what happens...
mark_snipz is offline Find More Posts by mark_snipz
Old Jan 20, 2013, 05:58 AM
Joined Sep 2012
Prob with DG1000 motor (0 min 19 sec)
Old Jan 20, 2013, 05:59 AM
Gerry__ is offline
Find More Posts by Gerry__
Bye Bye VP Aug 2010 - Aug 2012
Gerry__'s Avatar
United Kingdom, London
Joined Jan 2005
Originally Posted by mark_snipz View Post
Hitec Aurora.
It's not reporting the number of cells? Sounds like it's stuck in programming mode.
Gerry__ is offline Find More Posts by Gerry__
Latest blog entry: Foamie Resurrection
Old Jan 20, 2013, 06:22 AM
ChrisJ800 is offline
Find More Posts by ChrisJ800
Tassie Electric, Heli, Glider
ChrisJ800's Avatar
Hobart, Australia
Joined Oct 2002
Are all 3 wires connected from the ESC to the motor? Could be that one wire is not connecting as 2 only can cause that juddering.
ChrisJ800 is offline Find More Posts by ChrisJ800
Old Jan 20, 2013, 06:30 AM
Gerry__ is offline
Gerry__'s Avatar
Joined Jan 2005
He says he's tested all the wires with a meter. I'm with you though, it shows all the signs of a connection problem.
Old Jan 20, 2013, 06:43 AM
Joined Sep 2012
Nope, just one beep or a two tone beep to indicate which mode it's in.
How would I get it out of Programming mode? Would a programming card help here? If so which one is suitable for this stock ESC?
The world of sailplanes is an old one for me but these new fangled electronics is proving quite a learning curve!
Old Jan 20, 2013, 07:13 AM
Cubcrazy is online now
Find More Posts by Cubcrazy
Scale Foam Flyer
Cubcrazy's Avatar
United States, AR, Cabot
Joined Oct 2007
It is definitely behaving like the wiring to the ESC is not right. It may read on the meter..but not be able to carry the current. A meter will pick up an ohm reading even if just one strand of the wire is connected. Are you running that mixer? It could have just died. Plug in a spare ESC for comparison.
Source: I'm an Aircraft Electronics Specialist for a living.
-Cub
Cubcrazy is online now Find More Posts by Cubcrazy
Latest blog entry: GWS Funny Park
Old Jan 20, 2013, 07:52 AM
Joined Sep 2012
No Mixer, and I've tried it on different switches and sliders on the Tx.
I'm going to pull apart the motor/ESC again to double check the current. If that's not the problem then I'm off to the model shop tomorrow to pick up another ESC (snow allowing!).
Old Jan 20, 2013, 12:11 PM
Joined Sep 2012
Defo not the connections, after a bit of digging online it seems that a break in connection causes the motor to stutter back and forth...this isn't the case here as the motor rotates once.
I've ordered a new ESC so will see if that sorts things out.
Old Jan 24, 2013, 06:55 PM
lassehellsten is offline
Find More Posts by lassehellsten
lassehellsten's Avatar
Sweden, Gävleborg County, Gävle
Joined Aug 2012
Winter in Sweden
Took my DG 1001 for ride today
DG1001 RC winterflying with skis (3 min 31 sec)
Cheers Lasse
lassehellsten is offline Find More Posts by lassehellsten
Old Jan 24, 2013, 10:11 PM
studioRS is offline
Find More Posts by studioRS
Klassische Bilder
studioRS's Avatar
Northern Vermont
Joined Jul 2010
http://www.youtube.com/watch?v=S_NOxeKLwpM
Cheers Lasse
Lasse!!! You are the man! Love it, great video thanks!
studioRS is offline Find More Posts by studioRS
Old Jan 25, 2013, 12:36 AM
Joined Aug 2012
Yes it was a great feeling. 1 hour later I flew a VERY realistic simulator built from a real cockpit from a J-35 Draken, a Swedish old jet fighter.
Thanks Lasse
Old Jan 26, 2013, 04:53 PM
east6008 is offline
Find More Posts by east6008
east6008's Avatar
Morell, PEI, Canada
After a busy season flying my DG 1000, I made a clip of some improvements,
and my experience.
Review of DG 1000 glider, with retractable power (4 min 28 sec)
This is an under-rated model, I bought second one before they go extinct
east6008 is offline Find More Posts by east6008
Old Jan 26, 2013, 05:16 PM
Gerry__ is offline
Gerry__'s Avatar
Joined Jan 2005
and my experience.
http://www.youtube.com/watch?v=w54VKNS_1ck
I agree, most underrated. Great tip on feathering. I'll do that to mine and also put more black on the underside as my eyes are are ageing fast.
Old Jan 30, 2013, 09:59 PM
TomTerrific is online now
Find More Posts by TomTerrific
United States, CT, Waterford
Joined Jul 2012
Cheers Lasse
Hi Lasse-
Great Video... Very Joyous. I'm on my 4th viewing...
Take Care,
Tom
TomTerrific is online now Find More Posts by TomTerrific
Discussion Hobbycity's New Cessna 182 RTF 5Ch with Lighting & Flaps EPO anthodenn Parkflyers 1 Oct 22, 2008 03:09 PM
For Sale GWS 350c-b with props and ST models 350 with props wmrcer Aircraft - Electric - Power Systems (FS/W) 10 Dec 01, 2005 12:57 PM
FS: Todds Models Tiny RTF Al P Aircraft - Electric - Airplanes (FS/W) 4 Dec 11, 2002 01:38 PM
FS: NEW GWS ZERO RTF outfit with JR Computer Radio Etonic Aircraft - Electric - Airplanes (FS/W) 1 Nov 03, 2002 10:15 AM
Wanted! RTF HLG with bagged wing jimmy6819 Aircraft - Sailplanes (FS/W) 0 Oct 09, 2002 03:45 PM
