Old Dec 07, 2012, 03:14 AM
ChrisJ800 is online now
Find More Posts by ChrisJ800
Tassie Electric, Heli, Glider
ChrisJ800's Avatar
Hobart, Australia
Joined Oct 2002
A quick google australia search brings up:
http://www.revmaxhobbies.com.au/shop...uct-flyer.html
http://www.modelsports.com.au/produc...roduct&id=1807
Frontline is showing out of stock but have you asked them to get it in for you?
Other option is to buy European version which comes without the cheap TX but has a mixer control to get the motor up/down to work on your own basic TX. So if you already have a TX it saves you getting another one!
ChrisJ800 is online now Find More Posts by ChrisJ800
Old Dec 07, 2012, 08:19 AM
wavekatcher is offline
Find More Posts by wavekatcher
FAA is Sofa King We Todd Did
wavekatcher's Avatar
Svalbard and Jan Mayen, Svalbard
Joined Mar 2011
Originally Posted by Tomcatdriver14 View Post
Does anyone happen to know if this model is still produced,... I am trying to track one down here in Aus, but so far no joy,...
Not sure if this will help you down under, but I got mine @ Towerhobbies.
wavekatcher is offline Find More Posts by wavekatcher
Old Dec 13, 2012, 04:23 PM
TomTerrific is online now
Find More Posts by TomTerrific
United States, CT, Waterford
Joined Jul 2012
Very nice flying day for December in Connecticut.
Had 3 flights with two of them about 35 minutes each. Twice the DG spec'd-out and needed some aggressive action to bring it down... first with the spoilers up, then added the engine up & prop windmilling, and finally some the rudder to instigate some slow spiraling down too.
Boy, there is nothing like finding and riding a thermal!
TomTerrific is online now Find More Posts by TomTerrific
Old Jan 19, 2013, 06:20 AM
mark_snipz is offline
Find More Posts by mark_snipz
Joined Sep 2012
Took mine out last week, no probs. Tried again today and the motor pops up, beeps, rotates the prop slowly and then cut out. Retract and then try again and the same thing happens.
If you wait a few seconds the BEC beeps then the motor will rotate the prop slowly and then cut out.
Any ideas folks?
mark_snipz is offline Find More Posts by mark_snipz
Old Jan 19, 2013, 06:26 AM
ChrisJ800's Avatar
Hobart, Australia
Joined Oct 2002
Have you tried with a different battery?
Old Jan 19, 2013, 06:42 AM
Gerry__ is offline
Find More Posts by Gerry__
Bye Bye VP Aug 2010 - Aug 2012
Gerry__'s Avatar
United Kingdom, London
Joined Jan 2005
Any ideas folks?
Google ESC recalibration and recalibrate.
Gerry__ is offline Find More Posts by Gerry__
Latest blog entry: Eflite Gee Bee Racing
Old Jan 19, 2013, 10:13 AM
Joined Sep 2012
Battery fine.
Went thru the calibration procedure thus, made sure motor was up then:
1. turned on tx with throttle stick down. moved to full on.
2. plugged in battery on the DG1000, got a beep, then pulled throttle back down.
3. tried then bringing throttle up and....
No joy. I get one turn and the same beep after about 5 seconds.
Old Jan 19, 2013, 11:29 AM
Gerry__ is offline
Gerry__'s Avatar
Joined Jan 2005
Battery fine.
How many volts in the battery?
Old Jan 19, 2013, 11:52 AM
Joined Sep 2012
12.61v (using a 1600ma Overlander)
Old Jan 19, 2013, 11:55 AM
Gerry__ is offline
Gerry__'s Avatar
Joined Jan 2005
OK, I think someone else had this and it ended up that he had to reverse the throttle channel. BUT TAKE THE PROP OFF BEFORE PROCEEDING FURTHER.
Sorry for the caps, but we don't want any accidents.
http://www.rcgroups.com/forums/showt...&pp=25&page=52
Could also be a poor connection: http://www.rcgroups.com/forums/showt...&pp=25&page=51
Old Jan 19, 2013, 01:30 PM
Joined Sep 2012
Still no good I'm afraid.
Reversed the servo TX end but that just resulted in the same one rotation at the other end of the stick.
Checked the wiring, taking off the motor and fishing out the esc but all looks fine.
I can also program the esc from Normal to Auto and back but still get the same problem.
Strange!
Old Jan 19, 2013, 01:52 PM
Gerry__ is offline
Gerry__'s Avatar
Joined Jan 2005
Strange!
You need to check the wires with a meter. That's the only way to eliminate them. A visual inspection isn't enough.
Old Jan 19, 2013, 04:49 PM
Joined Sep 2012
Blimey...that was fiddly. All the wires check out ok.
What's odd is that, as mentioned, everything was fine last time I flew..the last landing was perfect and it's had no knocks in transportation or storage.
Annoying as I've got some keychain cams and wanted to get some footage of the snow!
Old Jan 20, 2013, 03:37 AM
Flypoppa is offline
Find More Posts by Flypoppa
Me a long time ago
Flypoppa's Avatar
London N.E. UK
Joined Jan 2007
I recon your ESC is bricked. Is it the original? Mine only lasted a few flights and then it smoked. Yes it was playing up in flight so I landed, and then there was smoke coming from the ESC.
Flypoppa is offline Find More Posts by Flypoppa
Old Jan 20, 2013, 04:07 AM
Gerry__ is offline
Gerry__'s Avatar
Joined Jan 2005
What Tx are you using?
Discussion Hobbycity's New Cessna 182 RTF 5Ch with Lighting & Flaps EPO anthodenn Parkflyers 1 Oct 22, 2008 02:09 PM
For Sale GWS 350c-b with props and ST models 350 with props wmrcer Aircraft - Electric - Power Systems (FS/W) 10 Dec 01, 2005 11:57 AM
FS: Todds Models Tiny RTF Al P Aircraft - Electric - Airplanes (FS/W) 4 Dec 11, 2002 12:38 PM
FS: NEW GWS ZERO RTF outfit with JR Computer Radio Etonic Aircraft - Electric - Airplanes (FS/W) 1 Nov 03, 2002 09:15 AM
Wanted! RTF HLG with bagged wing jimmy6819 Aircraft - Sailplanes (FS/W) 0 Oct 09, 2002 02:45 PM
