Old Apr 24, 2012, 03:47 PM
Gerry__ is offline
Find More Posts by Gerry__
Bye Bye VP Aug 2010 - Aug 2012
Gerry__'s Avatar
United Kingdom, London
Joined Jan 2005
Originally Posted by Philb75 View Post
I get a single beep.
When the motor returns to it's down position it beeps once after about five seconds.
BE CAREFUL! TAKE THE PROP OFF BEFORE YOU START MESSING WITH THIS ON THE BENCH> Sounds like the throttle channel is reversed. Are you using the mixer board? If you are, remove it and plug ch3 directly into the ESC, with the pod deployed. With the motor up, you can reverse Ch3 and see if you can get the ESC to arm.
Gerry__ is offline Find More Posts by Gerry__
Old Apr 24, 2012, 04:14 PM
Philb75 is offline
Find More Posts by Philb75
United Kingdom, Wales, Bridgend
Joined Apr 2012
Thanks Gerry. I'll let you know how it goes!
Philb75 is offline Find More Posts by Philb75
Old Apr 27, 2012, 09:58 AM
Philb75 is offline
Joined Apr 2012
Ok. so finally got chance to try this...
Ch3 is reversed according to the instructions.
I was getting nowhere and then thought I'd check something else.
I had assumed that the wire from the servo was white, red and black (as per the other servos) and the ESC was the red, brown and orange. But no. Having swapped them around it seemed to work much better!
ALSO I had to adjust the travel on the mixer unit to get CH5 to work so all is fine now and I just have to wait for the wind to drop and the weather to improve... June then!!
Thanks for your assistance.
Old May 20, 2012, 05:29 PM
3drcparts is offline
Find More Posts by 3drcparts
inverted-i-fly
3drcparts's Avatar
United States, CA, Petaluma
Joined Mar 2011
for those with a dx8 how are you wiring this all?
3drcparts is offline Find More Posts by 3drcparts
Old May 20, 2012, 08:31 PM
inverted-i-fly
3drcparts's Avatar
Joined Mar 2011
never mind, figured it out
Old May 30, 2012, 09:29 AM
tcapps is online now
Find More Posts by tcapps
United Kingdom, England, Barnsley
Joined Apr 2006
Rms Trashed
HI all...well second flight with dg and i lauched at full power...she went straight to the ground, flipped over and destroyed the pylon into a milli pieceson
I can get the parts to repair it but it looks like being open heart surgery..has anybody had to do this yet...if so have you any tips on how to split and re join the fuzz
Cheers Boys
Terry
tcapps is online now Find More Posts by tcapps
Old May 30, 2012, 12:23 PM
eosglider is offline
Find More Posts by eosglider
Addicted to lift
eosglider's Avatar
United States, FL, Miami
Joined Jul 2010
Originally Posted by tcapps View Post
...any tips on how to split and re join the fuzz
Cheers Boys
Terry
Terry,
To split the fuse on my ASK-21Mi (very similar to this DG) I used a butter knife and took my time splitting it at the seam so glue pulls apart slowly. It's not that hard, just be careful when you get to the T-Tail area since the foam there is not very thick.
eosglider is offline Find More Posts by eosglider
Old May 30, 2012, 12:54 PM
Joined Apr 2006
Originally Posted by eosglider View Post
Terry,
Any tips on re gluing mate is gorrila glue ok .....
Old May 30, 2012, 01:47 PM
Addicted to lift
eosglider's Avatar
Joined Jul 2010
Yes, Gorilla glue is OK. That's what I used on my ASK-21Mi when reglueing.
Old May 30, 2012, 02:06 PM
inverted-i-fly
3drcparts's Avatar
Joined Mar 2011
I also had a crash yesterday, torn half of the rudder off and somehow ejected the weights up front, everything else is just fine. How should I re-hinge the rudder, tape/glue or CA hinges.
In all honesty I'm not sure I even want to repair it, thought I'd enjoy a glider, but it is alway the last one I bring out to fly anyways, maybe I just sell it as is.
Old May 31, 2012, 03:20 AM
takiss is offline
Find More Posts by takiss
Patras, Greece
Joined May 2007
Subscribed.
takiss is offline Find More Posts by takiss
Old May 31, 2012, 01:55 PM
Joined Apr 2006
launch method
Well boys do you have any tips on the best way to hand launch the dg to avoid it going straight to the floor and destroying its self again
do i need to program a launch mix with up elevator or can you just use less throttle
any tips boys
cheers Terry
Old May 31, 2012, 02:03 PM
Gerry__ is offline
Gerry__'s Avatar
Joined Jan 2005
any tips boys
cheers Terry
I give it enough throttle so I feel it pulling and then throw it at about 5-degrees nose up. No need to do any mixing.
Old Jun 01, 2012, 02:15 AM
ChrisJ800 is offline
Find More Posts by ChrisJ800
Tassie Electric, Heli, Glider
ChrisJ800's Avatar
Hobart, Australia
Joined Oct 2002
I launch mine on full throttle but do big throw angled upwards and put in full up mechanical trim, then centre trim when motor has cut. Subsequent motor climbs I dont use trim as power on my tired packs is less by then so just use up elevator as required.
ChrisJ800 is offline Find More Posts by ChrisJ800
Old Jun 01, 2012, 07:44 PM
320pilot is offline
Find More Posts by 320pilot
320pilot's Avatar
Joined Mar 2009
We launch my sons DG-1000 with one hand under the forward fuse, to prevent the nose from dropping down. I throw it as hard as I can, with the left hand forward. We launched at WOT. Still a bit hairy to launch. Watch this video, to see us launch..
DG 1000 Maiden Flight (7 min 15 sec)
320pilot is offline Find More Posts by 320pilot
Discussion Hobbycity's New Cessna 182 RTF 5Ch with Lighting & Flaps EPO anthodenn Parkflyers 1 Oct 22, 2008 02:09 PM
For Sale GWS 350c-b with props and ST models 350 with props wmrcer Aircraft - Electric - Power Systems (FS/W) 10 Dec 01, 2005 11:57 AM
FS: Todds Models Tiny RTF Al P Aircraft - Electric - Airplanes (FS/W) 4 Dec 11, 2002 12:38 PM
FS: NEW GWS ZERO RTF outfit with JR Computer Radio Etonic Aircraft - Electric - Airplanes (FS/W) 1 Nov 03, 2002 09:15 AM
Wanted! RTF HLG with bagged wing jimmy6819 Aircraft - Sailplanes (FS/W) 0 Oct 09, 2002 02:45 PM
