Old Jul 20, 2009, 10:20 PM
niner555 is offline
Find More Posts by niner555
niner555's Avatar
Memphis, TN
Joined Jul 2006
Loosing sync on a Turnigy SK Series 42-60 500Kv motor
I just received this motor (Turnigy SK Series 42-60 500Kv) and have been having some problems. At 3/4 throttle or above, I am getting terrible screeching and massive vibration from what appears to be a motor sync issue. Slowly bringing up the rpm's to this point, the motor/prop is butter smooth...hit about 3/4 throttle and the motor goes nuts.
Set-up:
8S, 2200mah
CC HV45 ESC
8.75 x 10 prop
I have tried 3 different prop adaptors just to make sure it wasn't a balance issue. The cut-down prop I am using has been run up to 13,600rpm with a gearbox set-up, so I know the prop has no balance issues.
I also tried one of my cheapy Suppo 70amp ESC's and it didn't help/change the problem either.
I have tried every imaginable combination of timing and frequency with both speed controls. While the vibration/sync issue varies in it's intensity with changes in the timing, nothing seems to cure the problem.
Anyone have any ideas what I can try at this point?
Matt
niner555 is offline Find More Posts by niner555
Old Jul 20, 2009, 11:28 PM
himeros is offline
Find More Posts by himeros
O. C. CA
Joined Jan 2005
Did you program the timing on the esc for this motor?
Himeros
himeros is offline Find More Posts by himeros
Old Jul 21, 2009, 06:05 AM
niner555 is offline
niner555's Avatar
Memphis, TN
Joined Jul 2006
Yes.....
"I have tried every imaginable combination of timing and frequency with both speed controls. While the vibration/sync issue varies in it's intensity with changes in the timing, nothing seems to cure the problem."
Matt
Himeros
Old Jul 21, 2009, 06:45 AM
Challenger 413 is offline
Find More Posts by Challenger 413
Challenger 413's Avatar
Dickinson, Tx.
Joined Sep 2004
Drop voltage down a cell?
Challenger413
Challenger 413 is offline Find More Posts by Challenger 413
Old Jul 21, 2009, 08:50 AM
bamboofan is offline
Find More Posts by bamboofan
indiana
Joined Nov 2007
Check the magnets.
bamboofan is offline Find More Posts by bamboofan
Question Has anybody tried the Turnigy SK series motors? IBCrazy Electric Motor Design and Construction 38 Mar 22, 2009 09:48 PM
Sold Turnigy SK series 35-36 910KV brati4 Aircraft - Electric - Power Systems (FS/W) 3 Feb 06, 2009 11:59 PM
Discussion Turnigy SK series motors Skycruiser Power Systems 7 Jan 16, 2009 03:23 PM
For Sale Turnigy SK series 35-36 910KV tarjas Aircraft - Electric - Power Systems (FS/W) 1 Nov 12, 2008 10:00 AM
Discussion New Turnigy SK series motors hrvojekl Power Systems 7 Jun 26, 2008 02:27 AM
