Old Jul 19, 2009, 03:17 PM
dunc2504 is offline
Find More Posts by dunc2504
I SEE NO SHIPS
dunc2504's Avatar
Somerset England
Joined Feb 2007
Build Log
Lady Allison II Steam Lauch
Hi Guys.
I am just about to start the planning and building of my latest steam launch.
The Lady Allison I was recentlysold to a good home for a very decent price.
So far I only have the TVR1A engine which I have just finished fetelling and am going to run in on lubed air , Just ordered the displacement oiler and steam regulator for her.I intend to fit another accentric to the shaft and run a crank driven boiler feed pump from this .
I am going to order a 3 1/2 inch by 6 inch horiontal boiler from Mac Steam to power her.
Basic hull is on order , so when I have the plant together I will start planning the layout allong similar lines (but different ) to Allison I .
I am going to include the working wheel and gear rudder concept from the original , plus a few more ideas I have been working on .
More pictures to follow as I progress
dunc2504
dunc2504 is offline Find More Posts by dunc2504
Old Jul 19, 2009, 03:28 PM
norgale is offline
Find More Posts by norgale
Retired for now
Bonita Springs,Fl.
Joined Sep 2007
Lady Allison is a beautiful model Dunc. Really sweet looking. The new engine looks great too. Pete
norgale is offline Find More Posts by norgale
Old Jul 19, 2009, 09:00 PM
Kmot is offline
Find More Posts by Kmot
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
I like shiny! You did a great polishing job on the new engine.
Kmot is offline Find More Posts by Kmot
Old Jul 19, 2009, 09:19 PM
woodybob is offline
Find More Posts by woodybob
WooHoo!
woodybob's Avatar
Lake Balboa, CA
Joined Jun 2007
What a beautiful boat.
woodybob is offline Find More Posts by woodybob
Old Jul 20, 2009, 04:37 PM
dunc2504 is offline
I SEE NO SHIPS
dunc2504's Avatar
Somerset England
Joined Feb 2007
Thanks Guys .
But the Lady Allison II will be better !
I learnt allot building the Mk I .
Dunc2504.
Old Jul 20, 2009, 05:32 PM
norgale is offline
Retired for now
Bonita Springs,Fl.
Joined Sep 2007
I remember the build on the Lady Allison Dunc. That was one fine piece of work. Pete
Old Jul 20, 2009, 07:26 PM
green-boat is offline
Find More Posts by green-boat
Boats on the brain!!
green-boat's Avatar
Arnold, Mo.
Joined Jul 2005
That looks nothing like the Allison engine I know of.
green-boat is offline Find More Posts by green-boat
Old Aug 15, 2009, 04:33 PM
dunc2504 is offline
I SEE NO SHIPS
dunc2504's Avatar
Somerset England
Joined Feb 2007
Made some progress on the steam plant at last ( been in Holland for 3 weeks working on a rig repair ).
Turned up some brass cylinder covers to replace the nasty flat alloy ones that kept leaking. The new ones have a step built in to seal the bore better. .
Got the steam manifold made up and lagged with white cotton string, I painted this with white latex paint to seal it from oil and dirt ( works well , you can just wipe it clean.)
Got the lubricator built into the steam manifold.
Steam regulator and hand boiler pump turned up , as did the water tank kit.
Going to shine up the tank and clad it in wood , as I will the boiler and condensor tank when I get them.
Ran the engine up on my little airbrush compressor for a couple of hours, and she runs really well on as little as 5psi now.
Will be building the plant on to a base when the boiler and other bits turn up.
ordered a shaft driven water pump today to keep the boiler topped in use.
Cannot wait to fit that !
Still not decided on the superstructure style yet , gonna wait till i have the steam plant in one piece and sitting in the hull , then wait for insperation
Dunc2504
Old Aug 15, 2009, 04:44 PM
Kmot is offline
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
Nice!
Old Aug 15, 2009, 11:31 PM
MILLERTIME is offline
Find More Posts by MILLERTIME
Taking care of the pond.
MILLERTIME's Avatar
United States, CA, Sanger
Joined Apr 2004
Very nice!
MILLERTIME is offline Find More Posts by MILLERTIME
Old Aug 31, 2009, 02:33 AM
dunc2504 is offline
I SEE NO SHIPS
dunc2504's Avatar
Somerset England
Joined Feb 2007
Hi Chaps!
Long time with no posts , but now I have made some progress with the steam plant for the Allison II.
Got the beutifull Macksteam boiler and gas tank , painted them with PJ1 engine paint and cooked them at 100 C for four hours to cure paint .
Clad them in wood allong with the condensor tank and fresh water tank , ran out of brass boiler banding ( which is why there are only 3 on the boiler more on order)
Made up a base to mount it all on from 4 mm alloy plate.
Decided to go for a textured sandblasted finish on the base instead of pollished alloy , as I think it will not show the oil so much , I like it!
Drilled and silver soldered the engine bearing blocks to fit oil cups for the bearings.
Still waiting for my crank driven boiler water pump to be delivered then this will be mounted on the crank behind the propshaft drive dog.
Started doing all the pipework till I ran out of copper tube , again more on order.
silver soldered turned brass brackets to the funnel for steam whistle and pressure releife blow off pipe.Turned up and soldered funnel finishers for top and bottom of funnel.
Fitted remote whistle valve between boiler and fresh water tank.
I will be using 3 channels for the steam plant . Forward/reverse , Steam regulator , Whistle.
Ordered my hull today . It is a 44 1/2 inch long , 8 inch beam Edwardian launch hull , which has a much nicer bow profile than the one I used for the Allison I.
More pictures as the project (slowly) progresses
Dunc2504
Old Aug 31, 2009, 07:11 AM
arrow5 is online now
Find More Posts by arrow5
can you land on that ?
Scottish Highlands
Joined Jan 2005
Great work. Where can we find latex paint (UK) ?
arrow5 is online now Find More Posts by arrow5
Old Aug 31, 2009, 09:28 AM
jhspring is offline
Find More Posts by jhspring
Oh no, not again!
jhspring's Avatar
United States, LA, Carencro
Joined Dec 2005
Holy cow, Dunc. That power plant is gorgeous! I have drool all over my keyboard just looking at it. Please keep the pics coming.
Regards,
Jeff
jhspring is offline Find More Posts by jhspring
Old Aug 31, 2009, 09:49 AM
Kmot is offline
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
Looks fantastic!
Old Aug 31, 2009, 11:08 AM
dunc2504 is offline
I SEE NO SHIPS
dunc2504's Avatar
Somerset England
Joined Feb 2007
Hi.
Thanks guys .
I got the latex paint from a company called 4D models ages ago when I was building the Hood.
They are on the interweb.
I have nearly spent as much on this steam plant and the hull so far as the Lady Allison I cost in total , so she should be a bit special in the end.
Dunc2504
Build Log Lady Margaret-Wooden Steam Drifter ajferkovich Scale Boats 44 Nov 13, 2010 10:33 AM
