Sep 16, 2001, 06:06 AM
Foster City, CA
Joined Sep 2001
Few advises:
- Glue to black rubber on the wheel, otherwise, they have a tendency to go apart on landing
- Put some scotch on the wings, where the 2 parts are glued, doing lile an X on the top, and the bottom of each wing. Makes it stronger
- In the hole where you'll put your servos, add some foam to lock the servo into the hole, otherwise, after few hard landing, they would just move around
- when putting some velcro, to stick the cockpit, I found it easier to lock it from the outside
Good luck and have fun. When you'll fly it, you may try to fly it, as much as possible without the motor, using the wind and thermic (yes, it does work).
On friday, my wingo, who usually stay 7 minutes in the air, with the regular 600 mAmp, 7 cells battery, stayed 16 minutes, and I even had to force him to land as he was going too high, the engine turned off...
