Old Jan 25, 2010, 11:36 PM
ESander is offline
Find More Posts by ESander
ESander's Avatar
United States, CA, San Jose
Joined Jan 2010
What are you using to measure the RPM of the fan, so the phase shift stay constant
ESander is offline Find More Posts by ESander
Old Jan 25, 2010, 11:50 PM
The Don is offline
Find More Posts by The Don
MA Indoor FreeFlight Columnist
Willoughby, Ohio
Joined Jan 2002
Combination of sound and I use a servo driver so can set to same value.
The Don is offline Find More Posts by The Don
Old Jan 26, 2010, 06:09 PM
Bob Blackburn is offline
Find More Posts by Bob Blackburn
Bob Blackburn's Avatar
UK, Greater Manchester, Manchester
Joined Jul 2004
I have on the bench a device for setting speed like a servo tester but it also has a stop start facility keeping the speed setting the same between stop and start.
Is there a requirement for me to make this available on my website?
Bob Blackburn is offline Find More Posts by Bob Blackburn
Old Feb 02, 2010, 10:23 PM
AIR SALLY is offline
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
hey don do you need the whole fan and motor to balance a rotor? have you tried balancing the bell on outrunner motors?
AIR SALLY is offline Find More Posts by AIR SALLY
Old Feb 02, 2010, 10:24 PM
The Don is offline
Willoughby, Ohio
Joined Jan 2002
Never tried just the bell.
Old Feb 13, 2010, 01:59 PM
foxflier is offline
Find More Posts by foxflier
Always optimistic
foxflier's Avatar
North of Houston, TX
Joined Feb 2005
I splurged and got me a balancer from Bob this week to play with. Just finished a 64mm for a F117 and it works great! Getting ready to do a couple of fans using Wickeds for my SR71.
Don or Bob, have you guys tried to do any balancing using Bob's unit on the XF fans? Would there be a way to balance those small rotors that don't have a nosecone?
foxflier is offline Find More Posts by foxflier
Old Feb 13, 2010, 02:18 PM
Joined Jul 2004
I am not familiar with the type of fan BUT I would suggest blu tack until you know where to add weight, Then replace the blu tack with cyno and accelerator.
then repeat the process until all the blu tack is replaced.
Don't forget if there is enough thickness of plastic on the heavy side you could grind some material off the heavy side allowing you to remove blu tack from the light side.
Old Feb 13, 2010, 03:03 PM
foxflier is offline
Always optimistic
foxflier's Avatar
Joined Feb 2005
Thanks Bob. Problem with the XF is there's really no nosecone to speak of as it's a small solid rotor. I'm assuming the only way to do it would be to grind some of the hub...
Old Feb 13, 2010, 07:07 PM
The Don is offline
Willoughby, Ohio
Joined Jan 2002
The XF is a hard of to try and balance because there is no place to add the weight. Any weight addded, even CA that I tried all come off. The same is true for the 3 blade SF/Eflite rotor and for the same reason. The best you can do is try to drill a hole in the hub to remove weight much like they do on the Squall rotors which are scaled up XF rotors.
Old Feb 16, 2010, 03:38 PM
foxflier is offline
Always optimistic
foxflier's Avatar
Joined Feb 2005
Thanks Don. That's what I figured. Would probably be easy to compromise the integrity of the rotor particularly at high revs.
Regards
Old Feb 20, 2010, 12:29 AM
Go4it is offline
Find More Posts by Go4it
Go4it's Avatar
United States, FL
Joined Mar 2004
EDF balance
Try using 5 min epoxy for weight. If you get it to heavy just dremel a little off until balanced. Works for me. I also use CA and have good luck with it. And to fine tune the balaning process, I use auto clear coat and lighly spray the bades in the correct area. Saves time not having to take the fan off to add weight but only after the fan is almost balanced do I do this.
Go4it is offline Find More Posts by Go4it
Old Feb 21, 2010, 09:15 PM
foxflier is offline
Always optimistic
foxflier's Avatar
Joined Feb 2005
Thanks. Good ideas!
Old Mar 21, 2010, 10:16 PM
CARL SCHIMNOWSKI is offline
Find More Posts by CARL SCHIMNOWSKI
Joined May 2007
Interesting thread. There is just one mention of balancing a 90mm , is it the same as a 70mm or different ie bigger everything
Carl
CARL SCHIMNOWSKI is offline Find More Posts by CARL SCHIMNOWSKI
Old Mar 22, 2010, 03:58 AM
Joined Jul 2004
Carl
Carl,
The principle is exactly the same and the standard unit does accept 90mm fans.
Old Mar 23, 2010, 12:59 PM
Joined May 2007
Thanks Bob
MF 480 rotor balancing Olivier Electric Ducted Fan Jet Talk 2 Sep 13, 2010 01:00 PM
Sub-Rotor balancing on Corona Orion_V Electric Heli Talk 11 Jun 27, 2003 09:46 PM
Corona Sub Rotor Balancing ??? johnitahoe Electric Heli Talk 2 May 26, 2002 06:42 PM
Balance GWS EDF-50 Rotor GoEFlight Electric Ducted Fan Jet Talk 0 Apr 02, 2002 10:08 PM
Rotor Balancing WKoltis Electric Heli Talk 4 Nov 02, 2001 12:05 PM
