Old Dec 10, 2009, 09:15 PM
FidlerEd is offline
Find More Posts by FidlerEd
Joined Aug 2005
Very interested in this. Can someone explain a little bit more how it works ?
FidlerEd is offline Find More Posts by FidlerEd
Old Dec 10, 2009, 09:45 PM
The Don is offline
Find More Posts by The Don
Park Pilot Mag. Jets Columnist
Willoughby, Ohio
Joined Jan 2002
Basically you spin the rotor up at a low rpm, about 1/4 throttle and you first find the heavy spot and record its location. You then intentionally add weight to a know location to find the "phase shift". Once you find these positions you then know where to add the weight to get the rotor to balance. You then add or subtract weight as needed to get it to balance correctly.
The Don is offline Find More Posts by The Don
Old Dec 16, 2009, 01:06 AM
setxws6 is offline
Find More Posts by setxws6
Hemi pilot
setxws6's Avatar
USA, TX, Lumberton
Joined Oct 2005
Don, what are you using as weight inside the fan housing? I can't quite tell from the pics.
setxws6 is offline Find More Posts by setxws6
Old Dec 19, 2009, 01:41 AM
Prof100 is online now
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
Yes, another inquiring mind wants to know as well.
Prof100 is online now Find More Posts by Prof100
Old Dec 19, 2009, 01:58 AM
The Don is offline
Willoughby, Ohio
Joined Jan 2002
Poster putty
http://www.duckbrand.com/Products/cr...ter-putty.aspx
Don
Old Dec 19, 2009, 02:03 AM
Prof100's Avatar
Joined Jul 2007
Originally Posted by The Don View Post
Thanks Don. You don't sleep either.
BTW, I finished up my Exceed RC FA18 with your BI 3600, 80 amp Pentium and Het fan. It should make it a pretty good flyer. I hope it doesn't rip the wings off .
Bill
Old Dec 19, 2009, 08:50 PM
setxws6 is offline
Hemi pilot
setxws6's Avatar
USA, TX, Lumberton
Joined Oct 2005
Bill
Let us know how it flys
Old Dec 19, 2009, 09:37 PM
Prof100's Avatar
Joined Jul 2007
Weather here in Canton, Michigan is not much different than Willoughby, Ohio where Don lives. Tis the builiding season. It will have to thaw a bit.
Old Dec 20, 2009, 12:19 AM
setxws6 is offline
Hemi pilot
setxws6's Avatar
USA, TX, Lumberton
Joined Oct 2005
I couldn't live up there with you guys. I don't like the humid Texas summer heat.....but at least winter time here in Texas is flying and driving weather still!
Old Dec 20, 2009, 12:28 AM
Prof100's Avatar
Joined Jul 2007
You do have the advantage of being able to fly in the winter, but I can fly until 10 PM at night during the long days of summer and not die of heat stroke.
Old Dec 22, 2009, 10:20 AM
setxws6 is offline
Hemi pilot
setxws6's Avatar
USA, TX, Lumberton
Joined Oct 2005
True
But you get used to it though, just drink plenty of fluids!
Old Dec 27, 2009, 10:40 PM
AIR SALLY is online now
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
Don i think im going to have you balance my wm400 and the wm300 rotors for me ...i'll pm you for details .your 64mm fans sound so good after you balance them .....i bet it lowrs the amps and add rpm too.
AIR SALLY is online now Find More Posts by AIR SALLY
Old Dec 27, 2009, 11:06 PM
The Don is offline
Willoughby, Ohio
Joined Jan 2002
Yes RPMs go up and amps do drop a little it really depends on how out of balance they are to start with but if you need a few things balanced let me know.
Old Dec 31, 2009, 12:22 AM
hyperdyne is offline
Find More Posts by hyperdyne
Doppler wrangler
hyperdyne's Avatar
Joined Sep 2007
I can vouch for Don's mad skillz! I ordered 2 of the 60mm fans w/ 4400+ motors w/ balancing and they are spot on! Better than I could do.
I throttled them up and not even a single scratch from blades rubbing. They sounded awesome. Great work Don!
hyperdyne is offline Find More Posts by hyperdyne
Old Dec 31, 2009, 08:58 AM
zach_dad is offline
Find More Posts by zach_dad
TEXAS
Joined Sep 2005
Will a prop balance on high earth magnets work as well?
zach_dad is offline Find More Posts by zach_dad
MF 480 rotor balancing Olivier Electric Ducted Fan Jet Talk 2 Sep 13, 2010 01:00 PM
Sub-Rotor balancing on Corona Orion_V Electric Heli Talk 11 Jun 27, 2003 09:46 PM
Corona Sub Rotor Balancing ??? johnitahoe Electric Heli Talk 2 May 26, 2002 06:42 PM
Balance GWS EDF-50 Rotor GoEFlight Electric Ducted Fan Jet Talk 0 Apr 02, 2002 10:08 PM
Rotor Balancing WKoltis Electric Heli Talk 4 Nov 02, 2001 12:05 PM
