Old Sep 17, 2009, 11:57 PM
Daren is online now
Find More Posts by Daren
Daren's Avatar
Los Alamos, NM, USofA
Joined Nov 2000
Weird. I think having that many magnets is good, especially with the fan blast blowing right on the splitter plate.
One can get used to it looking like a Voodoo, that is until one sees a Phantom.
Daren
Originally Posted by DanSavage
Thanks, Daren! Even though it looked right, I got so used to how it looked with out the splitter plate that when it and the hatch were mounted on the airplane, I thought the plane looked chunky in the back. Now, I've gotten used to it and it looks okay.
I had a weird experience while I was building the hatch. As I was sanding it to shape, I had to keep pushing it back into place and every time I did, it squeaked the sound of wood rubbing against wood.
I traced the sound to the front bulkhead of the hatch. So, I would sand the mating surfaces between the hatch and the fuselage bulkheads and it was still squeaking!
Then I realized the magnets were what was causing the two surfaces to be so tight, they squeaked. After this, I stopped sanding.
Dan
Daren is online now Find More Posts by Daren
Old Sep 18, 2009, 09:36 PM
DanSavage is offline
Find More Posts by DanSavage
It wasn't me...
DanSavage's Avatar
Trabuco Canyon, CA
Joined Nov 2000
Daren
We'll see when I run up the fan. The hatch/splitter plate comes off the model really easily. With the model upside-down, I just grab the front and pull up and it pops off. It goes back on easily, too. I just have to be careful when I put the front down because the four magnets really want to snap it into place. That's why I thought just one pair would be better.
And the Voodoo is a pretty cool looking airplane in its own right. It's got the coolest wing planform. It'd probably make a great-flying model.
Dan
DanSavage is offline Find More Posts by DanSavage
Old Sep 18, 2009, 11:30 PM
AIR SALLY is online now
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
it will act to pull the tail down and nose up ....the JHH F-4 has a very scale inverted cambered airfoil on there's but i think it may have some down thrust,too not sure i'll have to dig the plans out
Oh ..the build look great looking forward to how it all works out
AIR SALLY is online now Find More Posts by AIR SALLY
Old Sep 19, 2009, 12:20 AM
It wasn't me...
DanSavage's Avatar
Trabuco Canyon, CA
Joined Nov 2000
Thanks!
Yeah, the full-size designers use inverted airfoils on the stab to reduce trim drag. As an aside, the F-4's wing airfoil is a stab airfoil that I flipped over. I tried it on Daren's Beluga and it works great. Real smooth-flying, fast airfoil. I chose it because it had a deep enough belly way back with enough room for the retracts in the airliner wing planform. I liked how it flew so much, that it's now my favorite jet airfoil, which is why I used it on the F-4. I'll probably use it again, too.
When I was designing this model, I recalled reading from some source that models of the F-4 flew better with an inverted airfoil on the stab.
I do know that Daren's F-4, on which this one is based, used a flat-plate set to zero-degrees incidence and it was a great flying model.
So, I decided to try the inverted flat-bottom airfoil, but made the stab removable, just in case I need to replace it with a stab that has a symmetrical airfoil.
Old Sep 19, 2009, 11:01 AM
It wasn't me...
DanSavage's Avatar
Trabuco Canyon, CA
Joined Nov 2000
Can you describe what you mean when you use the term, 'down thrust'?
Old Oct 04, 2009, 11:42 PM
It wasn't me...
DanSavage's Avatar
Trabuco Canyon, CA
Joined Nov 2000
Yay! It's on its feet!
Although I haven't posted anything recently, I have stayed busy. The work I've been doing is all assembly and internal fitting type work.
The wings are glued on. The retract holes have been cut into the bottom of the fuselage and wings. I built the nose gear strut and bent the main gear struts and mounted the wheels. I did a final rigging on the nose gear steering.
The horizontal stab is aligned to the wing. The vertical stab is aligned and glued into place.
I slathered on some light spackle to build up the aft engine fairing. This will be built into the production kit. I also filled all the little gaps here and there.
I just need to sand off a little bit of spackle and then the model will be ready for the covering/finishing phase. Yay!
Old Oct 05, 2009, 09:08 AM
eatond is offline
Find More Posts by eatond
EDF Jet Jam 2017, June 15-18th
eatond's Avatar
United States, MO, St Charles
Joined Nov 2002
Hi Dan,
It looks very nice. Hurry up and slap some paint on her, I want to see this fly.
What paint scheme you going with?
Dan Eaton
eatond is offline Find More Posts by eatond
Old Oct 05, 2009, 09:40 AM
SteveC68 is offline
Find More Posts by SteveC68
Oh Yeah!
SteveC68's Avatar
League City, Texas
Joined Sep 2006
I think he means the exhaust nozzles are pointed down slightly. Since the engines were pretty much below the CG then the plane would tend to go nose up when you apply throttle. In the real deal the engines were tilted slightly down so that the thrust would counter the pitch up tendency.
SteveC68 is offline Find More Posts by SteveC68
Old Oct 05, 2009, 11:07 AM
Larry Dudeck is offline
Find More Posts by Larry Dudeck
Larry Dudeck's Avatar
Williamsville, NY, USA
Joined Sep 2000
"...But, yours and everyone else's kits will be correct..."
I've known for some time that I need to try a 90mm design.
I also knew I wanted an F4, even made some preliminary layouts.
I was thinking a decent kit would be nice for a change as opposed to rolling my own.
Then I started following this thread.
I think I've found the ideal solution to all three items with your excellent F4
Larry Dudeck is offline Find More Posts by Larry Dudeck
Old Oct 05, 2009, 10:10 PM
Daren is online now
Daren's Avatar
Joined Nov 2000
Oh man, how did I miss this?!!
Looks very nice, Dan. The fillet really adds to the look of the F-4. From here on out, it will keep looking better and better (not that it doesn't look phabulous now! ).
Daren
Old Oct 05, 2009, 10:17 PM
Daren is online now
Daren's Avatar
Joined Nov 2000
So is this up-thrust or down-thrust?
In reality, it's just the opposite from what you write. On my Beluga, the thrust line is well below the CG, but having the nacelles level or upwards would have introduced up-thrust.
Pointing the nacelles down gave the needed down-thrust to counter the natural tendency gain altitude under power. When the thrust is pointed through the CG as in the zero-length launch, or in this case, the F-4, it pushes the airplane whichever way the thrust is pointed.
I can't say for sure, but it may be that the up-thrust was introduced by pointing the nacelles down so that the full-sized F-4 behaved like a normal airplane; throttle controls altitude and pitch controls speed.
Daren
Old Oct 05, 2009, 10:19 PM
lavochkin is offline
Find More Posts by lavochkin
lavochkin's Avatar
Mokena,Illinois -United States
Joined Oct 2006
Damn Dan!!!! That really looks nice!! No Joke. Cant wait to see her fly.
Brg, Joe
lavochkin is offline Find More Posts by lavochkin
Old Oct 05, 2009, 10:35 PM
It wasn't me...
DanSavage's Avatar
Trabuco Canyon, CA
Joined Nov 2000
Originally Posted by eatond
Hi Dan,
Dan Eaton
Thanks, Dan.
Since I'm so close now, I'm going to start putting some time in on it during the evenings so I can get it finished.
How else would I finish it?
Old Oct 05, 2009, 10:40 PM
It wasn't me...
DanSavage's Avatar
Trabuco Canyon, CA
Joined Nov 2000
Yeah, it's pretty tricky when it comes to jets. With prop-driven airplanes, it's cut and dried. With jets, you're firing the thrust line through the length of the airplane and where the thrust line is in relation to the mass of components determines whether it's up or down thrust.
Old Oct 05, 2009, 10:45 PM
It wasn't me...
DanSavage's Avatar
Trabuco Canyon, CA
Joined Nov 2000
Thanks, Larry.
F-4 Phantom II for a first timer? aeroplancek Pusher Prop Jet Models 3 Dec 16, 2005 08:58 AM
For Sale Yellow Aircraft F-4 Phantom II - NIB skyhawk Aircraft - Fuel - Airplanes (FS/W) 6 Aug 23, 2005 07:00 PM
Parkflyer F-4 Phantom II Astrix Parkflyers 0 Jun 06, 2005 07:44 PM
Midi F-4 Phantom II construction jet_jer Electric Ducted Fan Jet Talk 34 May 05, 2003 03:58 PM
F-4 Phantom II - First look... Daren Electric Ducted Fan Jet Talk 139 Mar 18, 2002 12:27 PM
