Old Mar 07, 2012, 01:09 PM
jhanson74 is offline
Find More Posts by jhanson74
jhanson74's Avatar
Joined Feb 2012
I have this kit and am planning on starting on it as soon as I finish my JHH F-14 Tomcat. I plan on adding an airfoiled full-flying horizontal stab, an airfoiled vertical stab, split the ailerons in half to add scale flaps and ailerons, Robart landing gear covers and gear doors. Anybody out there who knows what kind of airfoils I need for the horizontal and vertical stabs? The full size bird has an inverted airfoil on the horizontal.
jhanson74 is offline Find More Posts by jhanson74
Old Mar 07, 2012, 04:34 PM
Daren is offline
Find More Posts by Daren
Daren's Avatar
Los Alamos, NM, USofA
Joined Nov 2000
I think the Reynolds numbers are so small it won't matter too much what airfoil is used. I used a thinned Clark-Y that Dan called out for on the horizontal stab and streamlined the vertical stab.
I believe the full-sized F-4 has a dropped (raised?) leading edge on the horizontal stab.
Daren
Daren is offline Find More Posts by Daren
Old Mar 07, 2012, 08:53 PM
DanSavage is offline
Find More Posts by DanSavage
It wasn't me...
DanSavage's Avatar
Trabuco Canyon, CA
Joined Nov 2000
Wow! That's quite a list of things to do. The model should look terrific when you're done. After building mine, I realized I would have been happier with the design with separate ailerons and flaps.
Keep in mind that when I was designing this model I made no effort to replicate the scale thickness of the full-size tail feathers. I did sand an inverted Clark-Y airfoil onto my horizontal stab, but as Daren suggests, the Reynold's numbers make this practically moot. I did streamline the vertical fin by sanding it to an airfoil profile.
Dan
DanSavage is offline Find More Posts by DanSavage
Old Mar 09, 2012, 11:27 AM
jhanson74's Avatar
Joined Feb 2012
Dan, you are absolutely right. I never thought about the Reynolds numbers. Either way, with all of the other additions to the kit and a VF-96 fighting falcons "Showtime 100" paint job, it should be pretty cool. If I have the time, maybe even some armament for static display.
Old Mar 09, 2012, 06:35 PM
It wasn't me...
DanSavage's Avatar
Trabuco Canyon, CA
Joined Nov 2000
I agree. With the mods you've got planned, and with that paint job it should look pretty cool when you're done.
Old May 08, 2012, 01:24 PM
mr_matt_II is offline
Find More Posts by mr_matt_II
power package?
Hi guys,
I would like to try a Tamjets system in this F-4, does anyone have any suggestions? I am a noob in case you did not guess it.
Matt
PS a plus would be a system that would also work in a Habu 32
mr_matt_II is offline Find More Posts by mr_matt_II
Old May 08, 2012, 04:35 PM
It wasn't me...
DanSavage's Avatar
Trabuco Canyon, CA
Joined Nov 2000
Originally Posted by mr_matt_II View Post
Hi guys,
Matt
Which Tam-fan were you thinking of using?
Since the Habu is designed for an 80mm fan, the only way to use the same power system in both would be to modify this one to accept an 80mm fan instead of a 90mm/3-1/2" fan.
Old May 08, 2012, 06:01 PM
AIR SALLY is offline
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
you cant beat Tams 90mm wemo rotored fan there sweet very fast and sound nice too.
AIR SALLY is offline Find More Posts by AIR SALLY
Old May 08, 2012, 06:33 PM
If that mod is not wise I would stick with 90 MM. Any recommendations for the 90mm/motor configuration?
I guess the trade off is the number of cells versus all up weight.
Old May 08, 2012, 09:21 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
also im having great luck with the Jet fan 90mm they really sound good and cost a lot less and are made in Germany . lots of fan choices out there .Teh Efflux 90mm fans are nice too .
Old May 09, 2012, 11:05 AM
It wasn't me...
DanSavage's Avatar
Trabuco Canyon, CA
Joined Nov 2000
I don't think you'd have any problems as long as you are careful to make the ducting fair smoothly to the fan.
Old May 09, 2012, 06:26 PM
Robert Belluomini is online now
Find More Posts by Robert Belluomini
EDF Jet Jam 2016, June 16 -19
Robert Belluomini's Avatar
United States, KY, Crestview Hills
Joined Dec 2000
Matt these are really smooth running fans they come built and balanced.
http://www.jepe.org/fan/fan.htm
Robert Belluomini is online now Find More Posts by Robert Belluomini
Old Jun 05, 2012, 10:43 AM
Bob Hunt is offline
Find More Posts by Bob Hunt
Mustang Fever
Joined Jan 2005
Well, I did it. Ordered one of these from Dan today. I'm going to do it up like the orange and gray drones on this site:
http://www.f-4.nl/navy1.html#
I've got a brand new RCLander 90mm aluminum unit that's supposed to develop 7 pounds of thrust on a 6S. I'll use that and install the eflite electric retracts. I've got a bunch of S3115 servos. Same torque as the HS82s, and much better centering and smoothness. (IMHO)
With that killer EDF, I should be able to cruise around all day at half throttle on a 6S 4000 pack. I may not need all that, so I think I'll do some testing using a 5S 3000 pack.
I was a Phantom Phixer (C's and D's) for 15 years in the Air Guard, and I just can't get the F-4 out of my system. I've had plenty of delta wing RC experience the last three years or so, and feel like I might be ready.
Bob Hunt is offline Find More Posts by Bob Hunt
Old Jun 05, 2012, 01:58 PM
It wasn't me...
DanSavage's Avatar
Trabuco Canyon, CA
Joined Nov 2000
I got the order, Bob. Thanks! I should be shipping the kit out first thing tomorrow morning.
It should have pretty sparkling performance with the power package you've selected.
Dan
Old Jun 05, 2012, 03:27 PM
Bob Hunt is offline
Mustang Fever
Joined Jan 2005
Dan:
Went downstairs and cleaned off my glass top real good, and printed out the first ten pages of the book.
Is it ok to post my build here?
F-4 Phantom II for a first timer? aeroplancek Pusher Prop Jet Models 3 Dec 16, 2005 08:58 AM
For Sale Yellow Aircraft F-4 Phantom II - NIB skyhawk Aircraft - Fuel - Airplanes (FS/W) 6 Aug 23, 2005 07:00 PM
Parkflyer F-4 Phantom II Astrix Parkflyers 0 Jun 06, 2005 07:44 PM
Midi F-4 Phantom II construction jet_jer Electric Ducted Fan Jet Talk 34 May 05, 2003 03:58 PM
F-4 Phantom II - First look... Daren Electric Ducted Fan Jet Talk 139 Mar 18, 2002 12:27 PM
