One thing for sure, the short kit will get you building much sooner, Phil.
Here's the mtr I'm using: http://lightflightrc.com/HTML/produc...-28-47-1.5.htm ESC: http://www.quantumhobby.com/ZTW_60A_...ztw60asbec.htm And a good 30-45C 5s 3000Mah pack. Amps run 56A @ 1075-1100W And this can be used up to 6s, but you will need a larger ESC. Rolled mylar exaust tube at 56mm, made slightly oval with glass exaust from Dan the "Don". One thing to note, some ARC motors are now coming with 4mm shafts. You may want to ask at Lightflight which ones they have available at the moment. The 6904 comes both 3.17 and 4mm. I can either send you the intake molds( they are not permenant molds, but covered in packing tape, these leave faint ridges in the ducts that have no effect on flow) or I can lay up a set for you, if you have never done this before. PM me and I'll give you a price, not expensive. Or you can use the stock ones Dan uses, and just resize the fan end to fit. Larry Dudeck did this on his 70mm version. My ducting leaves a 1/8" gap at the fan between the two ducts. This allows the fan to draw air through the fuselage for cooling(makes the fuselage a low pressure vessel) from NACA inlets in the nose. Fuzz |
Dan,
Thanks for the info. I have bookmarked this thread and I am working on reading through it. I thought you might have a thread on the F4, but I didn't find it the other night when I went looking for it. I am currently building a Goldberg Extra 300, when that is done I am seriously thinking about making this my next project. John. |
| Thread Tools | |
| F-4 Phantom II for a first timer? | aeroplancek | Pusher Prop Jet Models | 3 | Dec 16, 2005 08:58 AM |
| For Sale Yellow Aircraft F-4 Phantom II - NIB | skyhawk | Aircraft - Fuel - Airplanes (FS/W) | 6 | Aug 23, 2005 07:00 PM |
| Parkflyer F-4 Phantom II | Astrix | Parkflyers | 0 | Jun 06, 2005 07:44 PM |
| Midi F-4 Phantom II construction | jet_jer | Electric Ducted Fan Jet Talk | 34 | May 05, 2003 03:58 PM |
| F-4 Phantom II - First look... | Daren | Electric Ducted Fan Jet Talk | 139 | Mar 18, 2002 12:27 PM |
