Old Sep 09, 2009, 09:14 PM
DanSavage is offline
Find More Posts by DanSavage
It wasn't me...
DanSavage's Avatar
Trabuco Canyon, CA
Joined Nov 2000
Originally Posted by bruff
Wonderful!
Bob
Thanks, Bob.
DanSavage is offline Find More Posts by DanSavage
Old Sep 14, 2009, 09:24 PM
Steve C is offline
Find More Posts by Steve C
Carbon fiber is our friend
Steve C's Avatar
United States, CA, Lodi
Joined Feb 2001
Any progress Dan? Come on, it's been 5 whole days since the last pic. You flew it last weekend right?
Steve C
Steve C is offline Find More Posts by Steve C
Old Sep 15, 2009, 02:48 AM
It wasn't me...
DanSavage's Avatar
Trabuco Canyon, CA
Joined Nov 2000
Hi Steve,
Yes, as a matter of fact. Well, to the progress part. I'm still not at the flying part, yet.
I got the tail cone and splitter plate mostly finished. I still need to rig the elevator linkage and then cut the slots in the sides of the tail cone hatch.
After that, I'm not sure what else needs to be built. I think it's about time to final sand everything, then start mounting the wings and tail feathers.
Dan
Old Sep 15, 2009, 05:31 AM
Kevin Cox is offline
Find More Posts by Kevin Cox
EDF Jet Jam 2016, June 16-19
Kevin Cox's Avatar
St. Louis Intl, Missouri, United States
Joined Jan 1997
Looks good Dan.
I did mine the same way.
Kevin Cox is offline Find More Posts by Kevin Cox
Old Sep 15, 2009, 01:21 PM
Daren is offline
Find More Posts by Daren
Daren's Avatar
Los Alamos, NM, USofA
Joined Nov 2000
Looks cool, Dan. Having the splitter really adds to the look of the Phantom (don't ask how I know ).
Daren
Daren is offline Find More Posts by Daren
Old Sep 15, 2009, 02:44 PM
Steve C is offline
Steve C's Avatar
Joined Feb 2001
Yes, looks great! Got to have that hook otherwise it would be wierd.
Steve C
Old Sep 15, 2009, 03:32 PM
monkamarm2000 is offline
Find More Posts by monkamarm2000
smug in granny panties
monkamarm2000's Avatar
NorCal Silicon Valley
Joined Aug 2002
Steve's right! I dont have hook and i'm totally wierd!
nice Dan!!! reminds me, Ihad a thought I was too chicken or didnt have enough time to experiment with on yellow F-4. i had the thought why make pants outlet when maybe a splitter wall could be instlled permanant in plane, then a v notch in one pipe tail made the fit as it slid in. Thenit wouldnt have to be perfectly curved all the way in, as long as it acted infinite it could be curved in back but go to striaght knifed infiite wall inside wher it esay to enguage. course this could be exctly what you've done here but outside I suppose?
Barry
monkamarm2000 is offline Find More Posts by monkamarm2000
Old Sep 15, 2009, 08:33 PM
It wasn't me...
DanSavage's Avatar
Trabuco Canyon, CA
Joined Nov 2000
Originally Posted by Kevin Cox
Looks good Dan.
Thanks, Kevin,
That's good to know. Did you notice whether it had any effect on the thrust?
Old Sep 15, 2009, 08:42 PM
Kevin Cox's Avatar
Joined Jan 1997
No noticeable effect at all.
Old Sep 15, 2009, 08:45 PM
It wasn't me...
DanSavage's Avatar
Trabuco Canyon, CA
Joined Nov 2000
Daren
Thanks, Daren! Even though it looked right, I got so used to how it looked with out the splitter plate that when it and the hatch were mounted on the airplane, I thought the plane looked chunky in the back. Now, I've gotten used to it and it looks okay.
I had a weird experience while I was building the hatch. As I was sanding it to shape, I had to keep pushing it back into place and every time I did, it squeaked the sound of wood rubbing against wood.
I traced the sound to the front bulkhead of the hatch. So, I would sand the mating surfaces between the hatch and the fuselage bulkheads and it was still squeaking!
Then I realized the magnets were what was causing the two surfaces to be so tight, they squeaked. After this, I stopped sanding.
Dan
Old Sep 15, 2009, 09:13 PM
It wasn't me...
DanSavage's Avatar
Trabuco Canyon, CA
Joined Nov 2000
Perfect. One less thing to have to think about come test flight day.
I found your WM400 F-4 thread. Nice jet, BTW. Yours and mine use a lot of the same construction techniques. (See: F-4E build for the WM400)
I was curious how you did your tailpipe. It looks like ours are very similar, being tucked up under the tail boom.
Do you recall what your F-4's thrust line was set?
Old Sep 15, 2009, 09:17 PM
It wasn't me...
DanSavage's Avatar
Trabuco Canyon, CA
Joined Nov 2000
Steve C
Thanks!
When my wife saw the hook, she asked if it was to launch the model. I explained, that no, it was to catch the real aircraft landing on the carrier deck.
Old Sep 15, 2009, 09:24 PM
It wasn't me...
DanSavage's Avatar
Trabuco Canyon, CA
Joined Nov 2000
Barry
Me, too! What a co-inky-dink!
Interesting concept. Or, maybe just use the splitter wall to divide the flow into two separate tubes to make a true twin-outlet. I may try it in the future.
Yeah, more or less. I decided to use a squished single tailpipe mainly to avoid the thrust loss and complexity that comes with bifurcated tailpipes. I made the hatch/splitter plate removable so I could take the tailpipe in and out the back.
Old Sep 15, 2009, 09:30 PM
Kevin Cox's Avatar
Joined Jan 1997
I'm also a big fan of box with wings construction....but you knew that .
My thrust line was zero but I gave the stab a degree of negative incidence (trim to climb) but found it didn't need it
Old Sep 16, 2009, 09:10 PM
It wasn't me...
DanSavage's Avatar
Trabuco Canyon, CA
Joined Nov 2000
Oh, yeah!
Hmmm... That's good to know about the thrustline. Mine is also at zero. That's interesting about the stab incidence. I sanded mine into an inverted flat-bottom airfoil. It'll be interesting to see what, if any, effect it has on the handling.
F-4 Phantom II for a first timer? aeroplancek Pusher Prop Jet Models 3 Dec 16, 2005 08:58 AM
For Sale Yellow Aircraft F-4 Phantom II - NIB skyhawk Aircraft - Fuel - Airplanes (FS/W) 6 Aug 23, 2005 07:00 PM
Parkflyer F-4 Phantom II Astrix Parkflyers 0 Jun 06, 2005 07:44 PM
Midi F-4 Phantom II construction jet_jer Electric Ducted Fan Jet Talk 34 May 05, 2003 03:58 PM
F-4 Phantom II - First look... Daren Electric Ducted Fan Jet Talk 139 Mar 18, 2002 12:27 PM
