Old Dec 08, 2009, 09:44 PM
Daren is offline
Find More Posts by Daren
Daren's Avatar
Los Alamos, NM, USofA
Joined Nov 2000
Originally Posted by AirX View Post
Thanks Dan,
You and Daren have a lot of time with big foam airframes and I need some feedback on what you guys think.
Cheers,
Eric B.
Hi Eric,
Where is the the thread on the AN-72? I tried searching here and in the foamies forum, but I couldn't find anything.
Daren
Daren is offline Find More Posts by Daren
Old Dec 08, 2009, 10:10 PM
DanSavage is offline
Find More Posts by DanSavage
It wasn't me...
DanSavage's Avatar
Trabuco Canyon, CA
Joined Nov 2000
Originally Posted by Daren View Post
Hi Eric,
Daren
It's on his blog.
http://www.rcgroups.com/forums/showt...php?p=13767327
DanSavage is offline Find More Posts by DanSavage
Old Dec 09, 2009, 04:54 AM
Daren is offline
Daren's Avatar
Joined Nov 2000
Thanks.
Daren
Old Dec 14, 2009, 02:24 AM
It wasn't me...
DanSavage's Avatar
Trabuco Canyon, CA
Joined Nov 2000
I finished putting the F-4 together this and last weekend and I have had a chance to weigh it. It weighs in at 5 lbs. 14 oz. RTF.
This is about the same weight as the F-22. There's a lot more junk in this model. There's ailerons (2 servos), retracts and a working rudder, not to mention the magnetically attached fan and tail cone hatches. It also has a two-wheel nose strut and a (heavy) GI Joe pilot bust.
So, the final specs are:
Wing Area: 383 sq. in. (2.65 sq. ft.)
Weight: 94 oz.
Wing Loading: 35 oz./sq. ft.
The wing loading is a little higher than I usually like to have, but it's not unacceptable given the size of the model.
Next up is to fine-tune the controls, and balance the model so I can establish the battery location. Once that is done, I'll be able to measure static thrust and efflux. I should be able to get these tasks done this week so I can take it out to the flying field next weekend for some real beauty shots and taxi tests.
Old Dec 14, 2009, 09:22 PM
Daren is offline
Daren's Avatar
Joined Nov 2000
Howdy!
That's not bad. I think it will still fly without problems. I will be interested in seeing what the final thrust/efflux numbers are. And of course, the pretty pictures.
Daren
Old Dec 20, 2009, 08:27 PM
It wasn't me...
DanSavage's Avatar
Trabuco Canyon, CA
Joined Nov 2000
I was able to make it out to the flying field this weekend to take some beauty shots and to do some taxi tests.
I checked the efflux and static thrust before taking it to the flying field. I think I'll need to make a new tail pipe because this one is wanting to inflate inside the fuselage which is causing it to wrinkle up a little bit where it exits the nozzle. I'm not sure what effect it's having on the efflux and static thrust. I'll know more once I make a new one and install it this week.
Static thrust is 2 lbs. 9 oz. and the efflux is ~110mph. The model accelerated well and I think it would fly even with the slightly wrinkled tailpipe. I would feel better if it didn't wrinkle, so that's why I want to make a new tailpipe out of thicker plastic.
Anyway, here's the shots I got.
Dan
Old Dec 20, 2009, 08:36 PM
sheppard559 is offline
Find More Posts by sheppard559
Joined Mar 2008
IM jealous!-looks great!!!
sheppard559 is offline Find More Posts by sheppard559
Old Dec 21, 2009, 09:27 AM
Kevin Cox is offline
Find More Posts by Kevin Cox
EDF Jet Jam 2016, June 16-19
Kevin Cox's Avatar
St. Louis Intl, Missouri, United States
Joined Jan 1997
Very nice Dan. You make that Moneykote look like it is paint instead of film!
You need to loose the itty-bitty pilot, he's killing the look.
Kevin Cox is offline Find More Posts by Kevin Cox
Old Dec 21, 2009, 11:24 AM
Robert Belluomini is offline
Find More Posts by Robert Belluomini
EDF Jet Jam 2016, June 16 -19
Robert Belluomini's Avatar
United States, KY, Crestview Hills
Joined Dec 2000
Great work Dan! What flying field were the photos taken at?
Robert Belluomini is offline Find More Posts by Robert Belluomini
Old Dec 21, 2009, 12:41 PM
Ed Waldrep is offline
Find More Posts by Ed Waldrep
Ed Waldrep's Avatar
Las Vegas, NV
Joined Dec 1996
It looks great Dan!
Ed Waldrep is offline Find More Posts by Ed Waldrep
Old Dec 21, 2009, 04:21 PM
corsair nut is offline
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
you need to replace that hoaye blade with a midi blade. with those numbers, its barely gonig to fly.
corsair nut is offline Find More Posts by corsair nut
Old Dec 21, 2009, 05:11 PM
Daren is offline
Daren's Avatar
Joined Nov 2000
Looks great, Dan! Very pretty sitting on the tarmac. You should be very proud of yourself. I can't wait to build mine!
Corsair Nut: According to your estimates, my 11 lb. Beluga with 4 lbs. of thrust would barely fly too, but it was actually quite fast.
Beluga barely flying
Daren
Old Dec 21, 2009, 05:20 PM
tehachapi, CA
Joined Jan 2006
well thats great if your flying around in the pattern the whole time, but this is a fighter, they do more than fly in circles, im sure it will fly, but not like a real blue angel F-4, atleast until it gets a little more power. ive flown a few jets at these kind of power levels(thrust to weight ratio) and it may fly, just wont be exiting is all. 110mph eflux is only going to fly around 70mph
Old Dec 21, 2009, 06:05 PM
It wasn't me...
DanSavage's Avatar
Trabuco Canyon, CA
Joined Nov 2000
As they say, the proof of the pudding is in the tasting...
You have to remember that because of the steep pitch, the FlyFly fan is currently partially stalled when sitting still. As it gets going faster, there will not be as much of a drop-off in speed as with the flatter pitch found on the Midi rotor.
I'm also not sure how much power is being robbed by the ballooning of the tailpipe inside the fuselage. I'll test it again once I make a new tailpipe.
It's currently pulling about 41A/930w static.
Old Dec 21, 2009, 06:08 PM
It wasn't me...
DanSavage's Avatar
Trabuco Canyon, CA
Joined Nov 2000
Daren
Thanks!
F-4 Phantom II for a first timer? aeroplancek Pusher Prop Jet Models 3 Dec 16, 2005 08:58 AM
For Sale Yellow Aircraft F-4 Phantom II - NIB skyhawk Aircraft - Fuel - Airplanes (FS/W) 6 Aug 23, 2005 07:00 PM
Parkflyer F-4 Phantom II Astrix Parkflyers 0 Jun 06, 2005 07:44 PM
Midi F-4 Phantom II construction jet_jer Electric Ducted Fan Jet Talk 34 May 05, 2003 03:58 PM
F-4 Phantom II - First look... Daren Electric Ducted Fan Jet Talk 139 Mar 18, 2002 12:27 PM
