Old Jul 17, 2009, 12:53 PM
modfly is offline
Find More Posts by modfly
Doing it in the Lateral Axis
modfly's Avatar
USA, OH, Akron
Joined Dec 2006
Build Log
PZ Sukhoi SU-26m with 1 cell Brushless upgrades and RPM & Thrust tests
haha
Ok, I changed the title to reflect what will be this threads specialty.
I plan on adding info here not only on the Sukhoi airframe but its radio\rx\servo\ESC system as well. As usual with any of my threads, the info will be in depth with pictures and good technical discussions.
The planes will be available here Monday as they have shipped as of yesterday.
Interfacing external ESC's to the AR6400.. http://www.rcgroups.com/forums/showthread.php?t=1088008
CG test .. http://www.rcgroups.com/forums/showp...&postcount=570
having problems with the GWS adapters tightening up against the cowl? http://www.rcgroups.com/forums/showp...&postcount=522
Loss of power? check this first.. http://www.rcgroups.com/forums/showp...postcount=1234
Prop change has boosted the power of the Geared BL setup to 5.7 watts http://www.rcgroups.com/forums/showp...postcount=1226
A new method for ESC Programming using any DSM receiver.. http://www.rcgroups.com/forums/showp...postcount=1171
Thanks to tahlpaul
More good document info from Reme http://www.rcgroups.com/forums/showp...&postcount=153
Sending out an SOS as Sting says.. http://www.rcgroups.com/forums/showp...&postcount=229
3 blade prop on a Sukhoi! http://www.rcgroups.com/forums/showp...&postcount=273
Charger on the blink? easy fix here.. http://www.rcgroups.com/forums/showp...&postcount=276
Some stock part weight measurements http://www.rcgroups.com/forums/showp...&postcount=302
Early testing of the C03GB http://www.rcgroups.com/forums/showp...&postcount=393
dribble from Horizon makes a comment on the early testing of the C03GB http://www.rcgroups.com/forums/showp...&postcount=403
Sukhoi night flight http://www.rcgroups.com/forums/showp...&postcount=438
The first Sukhoi BL mod is posted... http://www.rcgroups.com/forums/showp...&postcount=500
C03GB prop shaft replacement solves a big problem http://www.rcgroups.com/forums/showp...&postcount=603
C03GB test finally a success when I discovered a timing problem with the ESC http://www.rcgroups.com/forums/showp...&postcount=713
Preparing to install the C03GB http://www.rcgroups.com/forums/showp...&postcount=747
C04GB BL setup installed in the Sukhoi http://www.rcgroups.com/forums/showp...&postcount=749
Stock motor thrust test http://www.rcgroups.com/forums/showp...&postcount=837
22 minute flight with a 350mah lipo http://www.rcgroups.com/forums/showp...&postcount=926
ESC programming technique.. http://www.rcgroups.com/forums/showp...&postcount=968
Finally got the prop to stop slipping on the 1 mm shaft by doing this http://www.rcgroups.com/forums/showp...postcount=1022
If you must go 1 cell BL DD, this looks like the best motor choice http://www.rcgroups.com/forums/showp...postcount=1029
Sukhoi with a prop brake for improved glide mod http://www.rcgroups.com/forums/showp...postcount=1129
prop adapter info for the the C03GB with 1mm PZ Ember2 shaft http://www.rcgroups.com/forums/showp...postcount=1226
Losing power on the stock GB\motor? check this http://www.rcgroups.com/forums/showp...postcount=1234
The GWS 5043 is added with good results and a tad better than stock performance with same current draw http://www.rcgroups.com/forums/showp...postcount=1293
Here are some specs for the C03GB, these are static numbers so the actually draw is a bit lower in the air http://www.rcgroups.com/forums/showp...postcount=1332
you need a 1mm to 4mm adapter for the C03GB and GWS 5043 prop, here they are http://www.rcgroups.com/forums/showp...postcount=1339
NEW DATA RPM and thrust tests http://www.rcgroups.com/forums/showp...postcount=3626
Simple prop balance procedure http://www.rcgroups.com/forums/showp...postcount=3632
Why do a 1cell BL upgrade and what are the benefits if any? Answer.. http://www.rcgroups.com/forums/showp...postcount=3635
Part numbers for stock PZ brushed motors http://www.rcgroups.com/forums/showp...postcount=3646
1 cell BL conversions
sketchaholic's 1cell BL DD version http://www.rcgroups.com/forums/showp...&postcount=509
modfly's 1cell BL GB version http://www.rcgroups.com/forums/showp...postcount=1000
Reme's 1cell V1 BL DD version. http://www.rcgroups.com/forums/showp...&postcount=957
tahlpaul's 1cell BL DD version. http://www.rcgroups.com/forums/showp...postcount=1158
QueeQueg's 1cell BL DD version. http://www.rcgroups.com/forums/showp...postcount=1014
IH8VTEC's 1cell BL DD version. http://www.rcgroups.com/forums/showp...postcount=2552
Mera'din's 1cell BL GB version. http://www.rcgroups.com/forums/showp...postcount=2977
Ensign Jimmy's 1cell BL GB 10mm BL inrunner http://www.rcgroups.com/forums/showt...0#post16604043[/QUOTE]
1 cell 10mm BL 1015 Gearbox mod http://www.rcgroups.com/forums/showp...postcount=3865
2cell BL conversions
AR6400(X) 2cell wiring diagram by Reme http://www.rcgroups.com/forums/showp...postcount=1103
Minirips2 2cell BL DD version. http://www.rcgroups.com/forums/showp...postcount=1100
Reme's 2cell BL DD version. http://www.rcgroups.com/forums/showp...postcount=1413
mcgoughman's 2cell BL DD http://www.rcgroups.com/forums/showp...postcount=1604
habitforming's 2cell BL DD http://www.rcgroups.com/forums/showp...postcount=1951
TMASTER's 2cell BL DD setup http://www.rcgroups.com/forums/showp...postcount=3351
After Market Parts
Light kit.. http://www.tinybritelights.com/
Hyperion 120 lipos http://www.allerc.com/product_info.p...oducts_id=4497
Link for the C03GB.. http://www.rotorfever.com/
Props and adapters from here.. http://www.radicalrc.com/shop/?shop=...2991215&cat=36
Connectors that fit the 3 pin AR6400 servo ports. http://www.bsdmicrorc.com/index.php?productID=907
The C03 BL\gearbox is now at Hobby King http://www.hobbyking.com/hobbyking/s...dProduct=10003
Ember2 prop shaft http://www.horizonhobby.com/Products...ProdID=PKZ3429
Sukhoi with a Gearbox and BL outrunner..
Sukhoi with BL motor inside view (0 min 20 sec)
AR6400 mode change (0 min 12 sec)
PZ UM Sukhoi with Tiny Brite LED lights (0 min 21 sec)
modfly is offline Find More Posts by modfly
Old Jul 17, 2009, 12:54 PM
Sl0flyer is offline
Find More Posts by Sl0flyer
Sl0flyer's Avatar
Traverse City, Michigan
Joined Nov 2008
Let the posting begin!!
Sl0flyer is offline Find More Posts by Sl0flyer
Old Jul 17, 2009, 12:55 PM
lightspeeddud is offline
Find More Posts by lightspeeddud
Up Up and Away!
lightspeeddud's Avatar
Joined May 2008
what is this
lightspeeddud is offline Find More Posts by lightspeeddud
Old Jul 17, 2009, 12:57 PM
modfly is offline
modfly's Avatar
USA, OH, Akron
Joined Dec 2006
Originally Posted by lightspeeddud
W T F is this?
what do you think it is dud? Looks like a sukhoi thread to me
Old Jul 17, 2009, 12:58 PM
Up Up and Away!
Joined May 2008
I called the admin gods, I hope all the threads will be locked up cause of you
Old Jul 17, 2009, 12:59 PM
modfly is offline
modfly's Avatar
USA, OH, Akron
Joined Dec 2006
Plenty of threads for everyone here. Natural selection will determine that ones that matter.
Old Jul 17, 2009, 01:01 PM
Up Up and Away!
Joined May 2008
why would did you want to opena useless thread up??????
just go and fly already
Old Jul 17, 2009, 01:04 PM
modfly is offline
modfly's Avatar
USA, OH, Akron
Joined Dec 2006
Well, I would but its kinda windy right now so I want to do this instead.
Old Jul 17, 2009, 01:05 PM
bighead93 is offline
Find More Posts by bighead93
Live to fly
bighead93's Avatar
Sacramento
Joined Apr 2005
haha
NOW THAT IS FUNNY!!!
bighead93 is offline Find More Posts by bighead93
Old Jul 17, 2009, 01:35 PM
thewildweasel is online now
Find More Posts by thewildweasel
Beware the Axis of Weasel.
thewildweasel's Avatar
Plymouth, Devon
Joined May 2007
W T F is this?
Are you allowed to say that? Enough people know what it means so it could in itself be constituted as gratuitous swearing....
thewildweasel is online now Find More Posts by thewildweasel
Old Jul 17, 2009, 01:41 PM
modfly is offline
modfly's Avatar
USA, OH, Akron
Joined Dec 2006
Its against the rules to use that saying but usually they don't do anything unless people complain.
this is why I hate rcgroups
you guys are so immature...... you take in things to seriously,
hurry someone make yet another thread
Gee, someone is excitable
Old Jul 17, 2009, 01:53 PM
Up Up and Away!
Joined May 2008
nah, dude, I guess you can have your own sukhoi thread. Just change the subject. I came up with the official stuff
Old Jul 17, 2009, 01:57 PM
modfly is offline
modfly's Avatar
USA, OH, Akron
Joined Dec 2006
And that was your contribution? wow, I'm not impressed.
Do you have a patent on the word Official? Oh, and thanks for letting me have a Sukhoi thread you being the "Sukhoi thread master" and all
Old Jul 17, 2009, 01:58 PM
Up Up and Away!
Joined May 2008
[QUOTE=modfly]
nah, dude, I guess you can have your own sukhoi thread. Just change the subject. I came up with the official stuff[/QUOTE]\
okay, I dont care anymore......
how do we solve this problem?
We got 3 official threads.
I got it, I need your pm
Old Jul 17, 2009, 02:07 PM
modfly is offline
modfly's Avatar
USA, OH, Akron
Joined Dec 2006
dud, its very simple. If you look at the thread titles, you will see they are quite different. They have a "specialty" and appeal to different peoples taste. This is not the game of "topic" monopoly. There can be many threads on the same topic but specialized in specific interest, savvy?
Cool New Mini FuntanaX from e-flite (official build thread/ flying thread!!) p51flyer 3D Flying 1735 May 19, 2015 06:02 PM
Discussion Hangar 9 Tango 40 Official Build Thread januszczak 3D / Fun Fly Fuel Planes 59 Feb 22, 2013 08:31 PM
Yippee! Official Parkzone Sukhoi Thread!!!(ITS RELEASED!) lightspeeddud Micro Ready-to-Fly 620 Aug 25, 2010 08:58 AM
Cool Official SCHC Thread driftinsequence Mini Helis 8625 Nov 18, 2007 05:41 AM
DC-9 Airliner for EDF-50BH - Official Build Thread Hawker Electric Ducted Fan Jet Talk 77 May 29, 2007 09:54 PM
