Old Jul 17, 2009, 09:13 AM
Smokescreen38 is offline
Find More Posts by Smokescreen38
Checking CG is for NERDS!
Smokescreen38's Avatar
Joined Jun 2005
The first OFFICIAL Parkzone Sukhoi Owners thread!!!! Thoughts, experiences
At long last, the Amazing Parkzone Sukhoi is arriving at hobby shops and showing up on the doorsteps of enthusiastic pilots.
Congrats to all of you guys who have them already! My LHS hasn't called yet...but I'm going to check to see if mine is in today!
So what do you guys think so far?
How does it compare to the previous Parkzone/Kyosho Etomic/Minimum releases?
Does it stack up to the hype?
What are you seeing for run times?
Is prop-breakage a common problem?
Smokescreen38 is offline Find More Posts by Smokescreen38
Old Jul 17, 2009, 09:41 AM
sheks is offline
Find More Posts by sheks
Joined Mar 2009
Hi,
Only flown a couple of times. So far loving it.
Cannot comment on run times yet as both flights have been cut short by weather (wind, then rain).
Had a couple of quite heavy "landings" - prop first into grass - the plane took it very well in it's stride.
I also have a Minium Flybaby and a Cesna - this Sukhoi is a completely different animal - fast and very agille - very precise. Also much better in slighty windy conditions - I think because it generally flies a lot faster.
I am very keen to experiment with battery placement. It is a long battery bay (75mm) which gives plenty of option for tuning C of G by moving the battery.
I also really like the box - as it hinges open now and you do not have to slide out the inner packaging.
They also supply a second prop - nice touch!
Sheks
My web site with a video of my Sukhoi:
http://boyswithtoys.ning.com/
sheks is offline Find More Posts by sheks
Old Jul 17, 2009, 10:15 AM
fnlrun is offline
Find More Posts by fnlrun
Capitalist
fnlrun's Avatar
United States, CA, Redding
Joined Sep 2008
It's like a ghost town in here. Only 3 posts----watches tumbleweed blow around-----
Hopefully my Sukhoi will be in today at the LHS.
fnlrun is offline Find More Posts by fnlrun
Old Jul 17, 2009, 10:23 AM
lightspeeddud is offline
Find More Posts by lightspeeddud
Up Up and Away!
lightspeeddud's Avatar
Joined May 2008
Official Parkzone Sukhoi Thread!!!(ITS RELEASED!)
Hey guys, thought I would make the sukhoi thread, its been a while really, but its worth it!
Since I made the thread for the vapor, why shouldnt I do it for the sukhoi?
Put all of your mods, reviews, observations etc here.
Anything sukhoi related? KEEP IT IN HERE!
some previous threads
THE MAIN OLD THREAD!
Official Parkzone Sukhoi PRE RELEASE Thread!!!
http://www.rcgroups.com/forums/showthread.php?t=1010609
Yippee! - ParkZone 4-Channel Ultra-Micro Sneak Peek
http://www.rcgroups.com/forums/showthread.php?t=963617
parkzone sukhoi ???
http://www.rcgroups.com/forums/showthread.php?t=991706
PZ Sukhoi live on web 2-26-09!
http://www.rcgroups.com/forums/showthread.php?t=1007798
Happy Sukhoi Flying!
lightspeeddud is offline Find More Posts by lightspeeddud
Old Jul 17, 2009, 10:29 AM
Up Up and Away!
Joined May 2008
I would recommend locking this thread up.
This is the OFFICAL thread I made.
http://www.rcgroups.com/forums/showthread.php?t=1081070
keep sukhoi stuff in there
Old Jul 17, 2009, 10:32 AM
Sl0flyer is offline
Find More Posts by Sl0flyer
Sl0flyer's Avatar
Traverse City, Michigan
Joined Nov 2008
Here is the ESC and motor that I'm ordering when its in stock..
2 gram brushless outrunner
1 gram 3amp brushless esc
This setup is 3 grams TOTAL The question is, will it have enough thrust to push the sukhoi past the 1:1 thrust ratio?
Does anyone know what the motor/gearbox weight is on the sukhoi, or even the vapor?
Sl0flyer is offline Find More Posts by Sl0flyer
Old Jul 17, 2009, 10:33 AM
helinut2 is offline
Find More Posts by helinut2
helinut2's Avatar
Fargo N.D. Land of Blizzards-Floods-Mosquito's & Tornado's
Joined Jul 2008
Great!! I'm crossing my fingers and hoping for today. Would be great to have for the weekend. Let the mods begin
helinut2 is offline Find More Posts by helinut2
Old Jul 17, 2009, 10:36 AM
fnlrun is offline
Capitalist
fnlrun's Avatar
Joined Sep 2008
this thread says official too. Lets lock your instead
Old Jul 17, 2009, 10:41 AM
sheks is offline
Joined Mar 2009
As this is "The Official" Thread, here are my very brief first comments:
Mine is bound to a DX7. Running a little EXPO on aileron.
Sheks
Old Jul 17, 2009, 10:45 AM
Up Up and Away!
Joined May 2008
my looks and feel better
Old Jul 17, 2009, 10:46 AM
fnlrun is offline
Capitalist
fnlrun's Avatar
Joined Sep 2008
ohhhhhhhhhhhhhhhh
I like it. I'm sold---jumps ship to the 4th official thread
Old Jul 17, 2009, 10:47 AM
Up Up and Away!
Joined May 2008
yea I saw your video, lets wake the CA boys, I cant wait!
Old Jul 17, 2009, 10:48 AM
fnlrun is offline
Capitalist
fnlrun's Avatar
Joined Sep 2008
I'm up here 2 hrs N. of Sacramento and were being told Tuesday by the LHS-both of them-- well see if they get it sooner.
Up Up and Away!
Joined May 2008
Originally Posted by fnlrun
ohhhhhhhhhhhhhhhh
yea I thought so lol
Ensign Jimmy is offline
Find More Posts by Ensign Jimmy
The building never ends!
Tucson, AZ
Joined Oct 2008
No. The 2 gram motor isn't going to produce enough thrust to get the Sukhoi over 1:1. Real-world test results seem to put the 2 gram outrunner at around 20 grams of thrust at nearly 2A current draw. And this is with a GWS 3020 prop, which isn't going to be large enough for the Sukhoi. The 6mm brushed motor + gearbox + prop from the current PZ micros weighs about four grams. The 1S 110 mAH battery weighs four grams. So the Sukhoi's AUW minus the power pack is under 25 grams. The brushless setup is going to need a heftier battery to supply the required current, since the PZ/E-Flite 110 mAH packs seem to have, at most, an 8 to 10C rating.
To swing a large enough prop, you will need to go with a larger motor with a lower KV rating. Search for 5 gram outrunners with a KV rating between 3400 to 4500. These will produce 45 to 48 grams of thrust at 1.5A current draw at the low end of the range, and over 60 grams at 2A current draw at the upper end of the range.
Ensign Jimmy is offline Find More Posts by Ensign Jimmy
Discussion Official Parkzone Ember Review Thread! obiwan22 Micro Ready-to-Fly 1559 Jul 20, 2015 10:46 PM
Discussion Official parkzone vapor review thread! lightspeeddud Micro Ready-to-Fly 1399 Jul 02, 2015 02:00 PM
Discussion Official Parkzone Vapor Mods thread !! glenn2626 Scratchbuilt Indoor and Micro Models 1653 Mar 23, 2015 10:30 PM
Discussion Official Parkzone Sukhoi PRE RELEASE Thread!!!(CLOSED) lightspeeddud Micro Ready-to-Fly 1873 Jul 17, 2009 10:25 AM
Discussion ParkZone Cub Owners Thread johndreid Parkflyers 200 Jul 31, 2008 01:43 AM
