Old Jul 17, 2009, 08:06 AM
daveswall is offline
Find More Posts by daveswall
pittsburgh pa
Joined Mar 2002
mahogany strip planking
Hello
I was wondering if any of you guys would know where i can buy mahogany strip planking.
I am going to start building a 1/4 scale of the cris craft 19 ft. runabout and don't know where i can purchase it all your help would be appreciated.
thank you dave
daveswall is offline Find More Posts by daveswall
Old Jul 17, 2009, 08:56 AM
patmat2350 is offline
Find More Posts by patmat2350
Vita ex Machinis
patmat2350's Avatar
Motor City
Joined Dec 2004
At almost 5 feet long in 1:4 scale, you'll be better off getting a table saw, thickness sander, and talking to a lumberyard instead of a hobby supplier...
patmat2350 is offline Find More Posts by patmat2350
Old Jul 17, 2009, 09:15 AM
woodybob is offline
Find More Posts by woodybob
WooHoo!
woodybob's Avatar
Lake Balboa, CA
Joined Jun 2007
Try this: Northeastern Scale Lumber
woodybob is offline Find More Posts by woodybob
Old Jul 17, 2009, 10:35 AM
norgale is offline
Find More Posts by norgale
Retired for now
Bonita Springs,Fl.
Joined Sep 2007
Model Expo and Hobbytyme have mahogany strips but usually not longer than 24 inches. Still that would be good for your project. I might suggest that you plank the boat with basswood first and then use mahogany for the outer layer.
Also as mentioned above you can check with lumber yards and cabinet shops to get a 1 x 6 of mahogany that you can pick out yourself. Look for straight grain and very few knots if any with uniform color. Then the shop can rip it for you to the sizes that you want. This could get a little pricy but it will give you great looking wood at the size you want to work with. Remember that mahogany is pretty brittle and cracks or snaps easily.
norgale is offline Find More Posts by norgale
Old Jul 17, 2009, 10:36 AM
Vince Hoffmann is offline
Find More Posts by Vince Hoffmann
Vince Hoffmann's Avatar
Hayward, CA
Joined Jan 2009
If you have a band saw, it's a lot less expensive to cut your own planks.
You can get Mahogony strips from Midwest if you want to go the precut route:
http://www.hobbylinc.com/htm/mid/mid4703.htm
Vince Hoffmann is offline Find More Posts by Vince Hoffmann
Old Jul 17, 2009, 10:48 AM
pittsburgh pa
Joined Mar 2002
thanks guys for the information. I have a band saw,have a sander, have a small table saw guess i have my work cut out for me. what i did i took all the peices from the 1/8 scale 19ft. cris craft and traced all the peices and took that to a copy shop and had them enlarged. so now i am getting all materials together. IT SHALL BE AWHILE BEFORE I START, but i'll have fun.
dave
Old Jul 17, 2009, 10:52 AM
Vita ex Machinis
patmat2350's Avatar
Motor City
Joined Dec 2004
Before cutting the first piece of wood, what are your plans for making the fittings? I've seen more than one hull get built, then abandoned when the builder realizes he can't carve suitable chromed fittings from wood... But I've also seen metal working artists who can carve these goodies-- hope you're willing to give it a try!
Old Jul 17, 2009, 11:14 AM
Hayward, CA
Joined Jan 2009
daveswall:
I'm preparing to cut 6' long x 1/4"x1" mahogony gunwales, toe rails and king planks for my big sailboat build, then I'll cut 3' to 4' long spanish cedar deck planks. I'll post pictures in the sailboat forum this weekend:
http://www.rcgroups.com/forums/showthread.php?t=1069842
Old Jul 17, 2009, 11:36 AM
pittsburgh pa
Joined Mar 2002
patmat
I turn my horns on a drill press. my last big boat i used a crome spinner from a plane and cut it in half for the navigational light for the bow and inserted lights I made all the clets, gas cap, steering wheel out of mahogany and alunimun made my own windsheld and used crome door gaurd from a car for trim. so i think i can go with the flow as it comes. If i knew how to post pictures i would show you guys. The 1/4 scale would be 57" long and 18" beam.
dave
Old Jul 17, 2009, 11:39 AM
pittsburgh pa
Joined Mar 2002
hey vince sounds good i hope all the cutting i have to do won't take to long.
dave
Old Jul 17, 2009, 01:05 PM
woodybob is offline
WooHoo!
woodybob's Avatar
Lake Balboa, CA
Joined Jun 2007
Originally Posted by daveswall
...If i knew how to post pictures i would show you guys. The 1/4 scale would be 57" long and 18" beam.
dave
How to POST PICTURES:
http://www.rcgroups.com/forums/showthread.php?t=610209
http://www.rcgroups.com/forums/showthread.php?t=545544
Old Jul 17, 2009, 01:18 PM
Kcal is offline
Find More Posts by Kcal
Joined Jul 2008
Hmmm jet-ski sized, and thoughts on a power plant? Or 1/4 sized adults (kids) to help you with trial runs?
Kcal is offline Find More Posts by Kcal
Old Jul 17, 2009, 02:51 PM
pittsburgh pa
Joined Mar 2002
strip planking
patmat I put the pictures under planking a new reply i screwed up but there showing
dave
Old Jul 17, 2009, 03:10 PM
pittsburgh pa
Joined Mar 2002
strip planking
here are some pictures of a boat that i built from an old handymans encyclopedia. The boat is a 1957 era.you can't tell can you. a company called Glen-L boat sales design.
Old Jul 17, 2009, 03:25 PM
norgale is offline
Retired for now
Bonita Springs,Fl.
Joined Sep 2007
Daveswall that looks great. If you can build that you can build anything. Nice project and it looks good too.. pete
Discussion Strip planking or insert planking? Jacques Flambeau Scale Kit/Scratch Built 5 Jun 14, 2007 04:09 PM
Strip planking - options Capt_Christo Dock Talk 3 Apr 10, 2005 06:16 PM
