Old Dec 08, 2011, 07:06 AM
DaDesign is offline
Find More Posts by DaDesign
ɹǝsn pǝɹǝʇsıƃǝɹ - inverted!
DaDesign's Avatar
USA, SC, Greer
Joined Jul 2008
Originally Posted by olddog View Post
Here is an update on the Aerobile.
Its all finished and ready for a maiden flight as soon as the weather permits and i get brave enough to launch it. The ground is too rough here for an ROG so i will have to hand launch it. Anyway here is the picture for you.
Uploaded with ImageShack.us
Should be interesting.
HEY OD!!!!
That is so kool looking! I like the wheels. I'll post the pictures in the picture gallery at the front of this thread.
I have read somewhere on RCG that if you had a field with tall soft grasses you can do a couple of hand launch glides to see if the CG was correct/close. I assume the tall soft grass would allow for a soft landing without any damage. If it glides good then if something goes wrong you would throttle back and glide to a landing. It really would be bad for damage to happen to such a beautiful plane. You did a great job on your build. Best of luck on your maiden and may you have many happy hours flying your Aerobile.
Dalton
DaDesign is offline Find More Posts by DaDesign
Old Dec 08, 2011, 07:10 AM
DaDesign is offline
DaDesign's Avatar
USA, SC, Greer
Joined Jul 2008
Originally Posted by hectix 333 View Post
Thanks a lot and will do
You're welcome, it was my pleasure.
Old Dec 08, 2011, 07:27 AM
olddog is offline
Find More Posts by olddog
olddog's Avatar
Heya thanks Dalton i think i might take it out and do a ROG in the frosty grass this morning and see if it lifts off and looks stable or not.
Sure is cold out there.......BRRRRRRRRRRRR
olddog is offline Find More Posts by olddog
Old Dec 08, 2011, 07:30 AM
DaDesign is offline
DaDesign's Avatar
USA, SC, Greer
Joined Jul 2008
Good Luck. I hope it goes well!
Old Dec 08, 2011, 01:19 PM
DaDesign is offline
DaDesign's Avatar
USA, SC, Greer
Joined Jul 2008
Ron and Bob,
Check this 3D model out.....
http://www.rcgroups.com/forums/showthread.php?t=1552162
Old Dec 08, 2011, 01:29 PM
rcjim11 is offline
Find More Posts by rcjim11
rcflyer
UK
Joined Jun 2010
Hey Dalton,
Pickies will come soon!
Do you have a suitable weight for the LW 43" ?
Jim
rcjim11 is offline Find More Posts by rcjim11
Old Dec 08, 2011, 01:50 PM
DaDesign is offline
DaDesign's Avatar
USA, SC, Greer
Joined Jul 2008
Originally Posted by rcjim11 View Post
Hey Dalton,
Jim
Great! I look forward to seeing them.
No, sorry, Just keep it light as possible. I did add way to much weight with the landing gear/undercarriage I designed for mine. I would suggest something much more simple. Like my Parkzone T28 has or something similar.
Old Dec 08, 2011, 02:49 PM
rcjim11 is offline
rcflyer
UK
Joined Jun 2010
If it does turn out on the heavy side I plan to use my 50g 1650kv motor with a 1500mah 3s LiPo and am hoping for SPEED . I have enough power but would it go considerably faster? Do you have a baseline for the speed of this thing?
Thanks for all of the help so far!
Jim
Old Dec 08, 2011, 03:43 PM
DaDesign is offline
DaDesign's Avatar
USA, SC, Greer
Joined Jul 2008
Jim
We clocked it with a hand held radar gun at 59-60 mph. However, this was in a dive at full throttle. I have no idea at level flight.
Old Dec 09, 2011, 01:54 AM
rcjim11 is offline
rcflyer
UK
Joined Jun 2010
Pretty fast then. Looking forward to it
Jim
Old Dec 10, 2011, 05:03 PM
helicow is offline
Find More Posts by helicow
Gravity gets me down.
helicow's Avatar
USA, FL, Brooksville
Originally Posted by DaDesign View Post
Ron and Bob,
That is pretty nice. Added to my might do in the future list.
helicow is offline Find More Posts by helicow
Old Dec 11, 2011, 10:46 AM
rcjim11 is offline
rcflyer
UK
Joined Jun 2010
I have managed to acquire some aluminium and have roughly cut it to shape. How exactly did you fit the wheels to the legs?
Jim
Old Dec 11, 2011, 04:53 PM
DaDesign is offline
DaDesign's Avatar
USA, SC, Greer
Joined Jul 2008
Jim
I used 2-56 X 3/4" Socket Head Screw with two 2-56 Nylon Insert Lock Nuts. Drill a small hole for the screw to go through and lock it in place with a lock nut then put the wheel on the screw and then add the next lock nut. Don't over tighten.
If you buy/order from GreatPlanes the stock numbers are....
GPMQ3004
GPMQ3340
Old Dec 11, 2011, 05:07 PM
DaOldGuy is offline
Find More Posts by DaOldGuy
Flying Half Pound and Down
DaOldGuy's Avatar
United States, PA, Bellefonte
Joined Dec 2007
Cheers Dalton,
You wouldn't have a good line on a clamp magnifing lamp product would you?
http://www.rcgroups.com/forums/showp...ostcount=17573
There are many out there but the last one I bought could not hold its self up.
DaOldGuy is offline Find More Posts by DaOldGuy
Old Dec 11, 2011, 08:37 PM
DaDesign is offline
DaDesign's Avatar
USA, SC, Greer
Joined Jul 2008
Originally Posted by DaOldGuy View Post
Cheers Dalton,
This looks like the one you had.....
http://www.globalindustrial.com/p/of...campaignId=T9L
Mini-HowTo Low cost XBee/GPS plane locator plans rich smith UAV - Unmanned Aerial Vehicles 5 Feb 04, 2009 02:57 PM
Easy way to make a quick, good looking jet Tumbler Electric Ducted Fan Jet Talk 54 Feb 08, 2005 05:26 PM
How to build a good looking pager motor plane! gbarc Scratchbuilt Indoor and Micro Models 9 Jul 04, 2004 06:09 PM
