Old Jul 16, 2009, 03:55 PM
Conehead is offline
Find More Posts by Conehead
Flutter-Bys are fun
Conehead's Avatar
United States, MI, Honor
Joined Dec 2005
SR-71 model, Easy Tiger model with retracts
I wonder if anyone knows anything about this model. While it looks great, after watching the video, I looks like it scoots and I have a friend who has this model who wants a test pilot.
I have flown some ducted fans, I am sort of thinking this plane may be well over my head.
http://easytigermodels.com/index.php...6654eb7c2b1698
Any information would be helpful.
I did a search, didn't find this model, maybe I goofed.
Conehead
Orrin Eldred
Honor, MI.
Conehead is offline Find More Posts by Conehead
Old Jul 16, 2009, 04:30 PM
fhhuber506771 is offline
Find More Posts by fhhuber506771
Deletedfor proving Nauga wrong
Joined Mar 2005
If you think a model may be too advanced for you... you are probably right.
Its better to "fail safe" and find a more experienced pilot to help with the test flying and trimming than to try flying an untrimmed model at the limits of your skill.
Once the model has been trimmed properly and is up in the air, any RC pilot who has soloed has a reasonable chance of flying just about any model as long as they don't stall it... but might have issues when it comes time to land.
A few flights to get used to it and you might begin wondering why you were hesitant to fly the model. But thats an illusion due to being used to the model.
ANYTHING that the pilot is not used to flying can be quite a challenge...
Several years ago a local Pattern competition flyer (best pilot in the club at the time... possibly still the best if we could get him back to flying again) who tended to place well at the NATS tried a powered sailplane I had... and initially he had problems flying it because it wasn't the style aircraft he was used to. It didn't take him long to "figure it out" but it was entertaining to watch him overcontrolling the plane almost like a beginner
fhhuber506771 is offline Find More Posts by fhhuber506771
Old Jul 16, 2009, 05:04 PM
Conehead is offline
Flutter-Bys are fun
Conehead's Avatar
Joined Dec 2005
fhh,
I agree with you. I am the only one in our club that has flown any ducted fans, so this fellow who owns the plane, wants me to test fly it. I was hoping that people here would have some opinion as to how it flies.
I don't plan to fly it and wreck it for him. If I think it is too much, I am not going to fly it.
I was hoping that someone has this same model, has flown it and would have some hints, ideas, pointers as to how it flies and what to look for, what the drawbacks of this model may have and that would help me make a good decision.
If it is way too zippy or scoots it way too fast for me, I won't fly it nor will I try to.
It is way too expensive to have to replace on my budget.
Thanks for the advise.
Conehead
Orrin Eldred
Honor, MI.
Old Jul 16, 2009, 06:12 PM
DEATHTRON is offline
Find More Posts by DEATHTRON
Dallas, TX
Joined May 2009
Theres a thread on this model in the foam edf section. Nitroplanes also distributes them as well as bananahobbies...
Zach
DEATHTRON is offline Find More Posts by DEATHTRON
Old Jul 16, 2009, 06:21 PM
jpflyer is online now
Find More Posts by jpflyer
USA, TX, Corpus Christi
Joined Oct 2001
Sr-71
My flying buddy has one of these from Banana Hobby. It flies great. The SR-71's retracts seem to be holding up, which was his biggest concern. He crashed however last Sunday when the impeller came off one of the motors in flight. He says it will fly again. The only thing I noticed was that it came in a little hot on landing. Not anything a good pilot couldn't handle, just keep your speed up a bit. It looks great in the air.
jpflyer is online now Find More Posts by jpflyer
Old Jul 16, 2009, 08:25 PM
carlsoti is offline
Find More Posts by carlsoti
hass-alfed and bass-ackwards
carlsoti's Avatar
United States, AZ, Chandler
Joined Jun 2008
Typically, a plane of these dimensions (long ans skinny)is quick on the aileron, but slow on the elevator.
carlsoti is offline Find More Posts by carlsoti
Old Jul 16, 2009, 08:38 PM
dLdV is offline
Find More Posts by dLdV
On the Edge of Space
dLdV's Avatar
Exit 4, South Jersey, USA
Joined Dec 2007
Bingo on the last post. Also, DO NOT empty your battery. If you cut power at normal speed its OK, glides OK. If you're flying slow on low bat and ESC's cutoff, nose goes straight up, plane comes straight down. Busted nose. One plus is its a great hand launch if your field is grass.
dLdV is offline Find More Posts by dLdV
Old Jul 16, 2009, 08:54 PM
Conehead is offline
Flutter-Bys are fun
Conehead's Avatar
Joined Dec 2005
Thanks so much everyone. Now I know what not to do. That is usually a great help.
I will let everyone know what happens.
Like I said, If I don't think I can fly it, I won't.
Conehead
Orrin Eldred
Honor, MI.
Old Jul 21, 2009, 09:23 AM
dLdV is offline
dLdV's Avatar
Joined Dec 2007
SR-71 Elevon Hinge and Clevis Weak
Been following all posts on Chinese foam Blackbirds.
Some posts noted the stock plastic clevises are brittle, easy to shear the pivot pin off. I confirmed that by test to destruction, they break right off with little side force. Best to replace with nylon or metal off the bat.
Couple other reports of rolling over on take off. I got lucky on mine and found the stock point hinges break thru the foam and or pull out real easy. I replaced those with flat hinges before flying as well.
So far this one has zero tendency to roll over except in side gusts, and that is easily handled.
Its not hard to fly, and it looks and sounds pretty darn good in the air.
Old Jul 22, 2009, 07:47 AM
kelberts is offline
Find More Posts by kelberts
Effumall
kelberts's Avatar
Joined Nov 2005
The airframe is available at BP Hobbies. It's made by Lanxiang. Full info in the foamy section.
kelberts is offline Find More Posts by kelberts
Old Aug 15, 2009, 11:10 PM
mach7rc is offline
Find More Posts by mach7rc
B Mac
mach7rc's Avatar
United States, LA, Lake Charles
Joined Aug 2009
I have the easytigermodels sr-71. I am trying to determine how much servo travel to maiden. Right now I have about 75% elevator and 80% aileron. Does anyone know if this is about right or does it require a change?
Brandon
mach7rc is offline Find More Posts by mach7rc
Old Aug 16, 2009, 09:24 AM
dLdV is offline
dLdV's Avatar
Joined Dec 2007
I have the LX-71, its basically the same model. I posted my setup with travel and DR/Expo settings at this thread http://www.rcgroups.com/forums/showt...=983978&page=3
on page 2 and 3. Mine is easy to fly with this setup. Hope I don't steer you wrong, let me know if this doesn't work out. I'll delete all of those posts if it doesn't work out. Good luck.
Old Aug 17, 2009, 08:51 AM
mach7rc is offline
B Mac
mach7rc's Avatar
Joined Aug 2009
Thank you for the valuable input. I will give that a try and see what happens from what everyone has said it does require a bit of up elevator to level her out. I will get maiden video up as soon as I can. Thx.
SR-71 for EDF 50 (Closer than we might think) Thomas B Electric Ducted Fan Jet Talk 187 Feb 22, 2011 10:56 PM
SR-71 anyone? steve neill Electric Ducted Fan Jet Talk 71 Oct 08, 2007 07:34 AM
Discussion SR-71 BlackBird RC Model from GWS? guapoman2000 GWS (Grand Wing Servo) 22 Nov 15, 2006 11:30 PM
SR Next Model thread - anyone saved it? Neil Stainton Electric Plane Talk 6 Oct 12, 2001 03:02 AM
Electrics that can outperform the SR-71? SchiessCo Electric Plane Talk 4 Jul 30, 2001 08:44 PM
