Old Jul 15, 2009, 05:01 AM
sebbe is offline
Find More Posts by sebbe
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
strange sound from FlySKy 2.4ghz module
Im hearing a high frequent sound, not loud at all but you can hear it if you listen carefully,, is that normal ?
sebbe is offline Find More Posts by sebbe
Old Jul 15, 2009, 05:48 AM
freechip is offline
Find More Posts by freechip
freechip's Avatar
Joined Aug 2008
When my wife and or kids turn off the SAT but leave the TV on, I know they left it on as soon as I enter the house BUT yet my wife and kids and every body else I know can't.
BUT at the same time when my wife talks to me, I can't hear a thing.
MY cheaper stock chargers make some noise also and I have learn to live with it.
You are just going to need to wait for someone that has the same module to post and let you know if his or hers does the same. In the mean time if you're range check are good, then don't worry about it.
freechip is offline Find More Posts by freechip
Old Jul 15, 2009, 03:50 PM
sebbe is offline
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
Maybee someone with a flysky module could hear if the sound should be there please.
Old Jul 15, 2009, 07:14 PM
XJet is offline
Find More Posts by XJet
The reviewer
XJet's Avatar
Tokoroa
Joined Mar 2004
There should be *no* sound from the FlySky module itself.
The sound you describe would more likely come from a switching regulator -- but the FlySky 9X radio doesn't use switching regulators.
Listen carefully and see if you can hear exactly where it's coming from. Could it be the small transducer the 9X uses to make its beeps? Perhaps there's some logic pulse leaking through to that transducer.
XJet is offline Find More Posts by XJet
Old Jul 16, 2009, 05:11 AM
sebbe is offline
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
Well, I dont have the 9X radio,,,, I have hacked a FlySKy 2,4ghz module in to a Graupner MX-12 radio.
Old Jul 16, 2009, 05:32 AM
XJet is offline
The reviewer
XJet's Avatar
Tokoroa
Joined Mar 2004
Ah, I wonder if the MX-12 uses a switching regulator and if (for some reason) it's now "singing" (perhaps due to excessive current draw)?
I take it that (in your picture) the red wire is 9.6V and not 6V?
Old Jul 16, 2009, 07:11 AM
sebbe is offline
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
Jepp, the red wire is batteryvoltage(8 nimh=9.6V), and the orange is ppm..'
Ive just connected a HobbyKing module( just got that one today) and this one 2 makes a sound and the red little diod is red.
So it cant be 2 flysky modules that are bad..
My PPM signal in is about 2.8 volt.
Wait, I will listen where ths sound comes from, but Im sure its from the module..
EDIT: yes the sound comes from module..
Old Jul 16, 2009, 07:25 AM
sebbe is offline
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
It appears the sound should be there,,, I just for the first time did bind all my 6ch hobbyking receivers, they all did bind within 1 second..
Now for the fun part, range check and flying..
so sweet..
Old Jul 16, 2009, 08:24 AM
sebbe is offline
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
update, the first range check looks good...
Old Jul 16, 2009, 11:07 AM
Julez is online now
Find More Posts by Julez
Proud to eat Kraut ;-)
Julez's Avatar
Germany
Joined Dec 2003
My old Futaba FC 18 also hums very slightly, and it has no switching regs.
I also remember several DX7 users reporting sounds.
I guess it has something to do with a 50Hz PPM framerate inside.
Julez is online now Find More Posts by Julez
Old Jul 16, 2009, 04:20 PM
sebbe is offline
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
Julez, did leave the radio and 1 receiver + 1 servo on fr 45 minutes,,,, absolutely still.
I thrust this..
Did even fly 3 times with this system in an Alfa p-47, so high an far away i could, no problem....
The resolution is really great, and dual antennas also,,,, im happy..
Question Where to buy a module FLYSKY 2,4ghz ? sebbe Radios 4 May 21, 2009 04:12 PM
Question Best 2.4GHz module for Futaba 9Z? kenmalecki Radios 44 Aug 02, 2008 01:57 AM
Question Which 2.4GHz module will be best for my 9Z? kenmalecki Radios 11 May 23, 2007 11:33 AM
