Old Jul 14, 2009, 01:05 AM
manuel v is online now
Find More Posts by manuel v
manuel v's Avatar
Mexico, BC, Mexicali
Joined Aug 2004
How to repair an electric motor.
Como reparar un motor electrico.
Electric motors are somewhat fragile. bends or breaks the shaft, the wire breaks, you are off the magnets, are damaged or ball bearing, and end burned and must be repaired.
It usually is not difficult.
The forum will put some tips and procedures for doing so and will be only for outruner motor.
Manuel V.
manuel v is online now Find More Posts by manuel v
Old Jul 14, 2009, 01:10 AM
manuel v's Avatar
Joined Aug 2004
The most common fault is a broken or bent arrow.
almost always a bad landing or a crash.
For now I do not have a motor with the broken or bent arrow. so I only put the procedure to remove an arrow, and later explain the difference to remove a bent or broken.
In the first case the most simple, just remove the small screw on the front of the bell and the arrow slides inwards to outwards.
Manuel v.
Old Jul 14, 2009, 01:13 AM
manuel v's Avatar
Joined Aug 2004
Most of the motor on the arrow to bring pressure and it is impossible to remove just remove the screws from the hood.
For these cases it is necessary to have a vise and with a few tools or guidelines for the implementation spells.
The idea is to move the arrow through the bell, without spoiling it. out as a beating or pushing in the wrong way can cause any harm in it. hurt from the magnets, bending the bell to make the hole bigger, able to prevent a new shaft.
Manuel V.
Old Jul 14, 2009, 01:18 AM
manuel v's Avatar
Joined Aug 2004
If it is to put a new arrow, then looking for a replacement. either buy the correct spare parts, using a piece of another similar motor,or making one.
for small motors, with arrows 3mm. You can use the CD rom.
If you use a CD rom guide. usually be very long. and this is the procedure for cutting.
Manuel v.
Old Jul 14, 2009, 01:24 AM
manuel v's Avatar
Joined Aug 2004
Now assembled the motor and put the C clip.
In this case the size of the arrow includes the measure of a thrust washer. before the C clip.
The Thrust washer is more little a
to generate friction with the ball bearing.
What a short copper tube 3mm in diameter inside.
Manuel v.
Old Jul 14, 2009, 01:27 AM
manuel v's Avatar
Joined Aug 2004
Using this method, this motor will put an longer shaft to make a mount adapter that propeller off the cowl.
Manuel V.
Old Jul 14, 2009, 01:28 AM
manuel v's Avatar
Joined Aug 2004
Removing Stator.
3 different ways.
Manuel v.
Old Jul 14, 2009, 01:37 AM
manuel v's Avatar
Joined Aug 2004
Option 2.
This is the method used for most motors.
To remove the stator, it is necessary to heat it, when it is stuck.
It can be done with soldering Iron, solderin gun, gun Paint remove,
To remove a stator of a Hacker, you must first remove the top clip of the stator.
To remove one of Eflite, must be heated for a long time since they are very, very stuck.
Some SK turnigy and KD, also bring a lot of rubber.
To remove the wires when they bring rubber. First with warm soldering iron.
Manuel v.
Old Jul 14, 2009, 01:38 AM
manuel v's Avatar
Joined Aug 2004
Other ways.
Warm up the engine as in mode 2. and when ready the stator, put some screws in the bottom of the engine and tighten the pressure by the stator.
you can use any piece of plywood or aluminum to prevent damage.
(The screws should be longer than those used to mount the engine.)
This method can be used when the stator has a crib and can not be removed.
Other and very easy.
check pictures.
Jack method for pres fit stators:
Post 21.
http://www.rcgroups.com/forums/showt...1768736&page=2
Manuel V.
Old Jul 14, 2009, 01:40 AM
manuel v's Avatar
Joined Aug 2004
Option 5. Jack method.
(This option was shown for the first time by Jackerbes and works well in engines are only assembled under pressure.)
It is commonly found in motors with very high stator or stators with very wide center. type pancakes motors.
Another method I found to work well recently is to remove the bearings and "blast it off" using the "PB Blaster technique" in the image.
I use WD-40.
Check first picture.
As you rewind, mount and solder terminals.
Some reworked Motors:
Hacker A2020L
2837 EDF
SK 4260
E-Flite 250
Atlas 2915
Scorpion 3020
KD-3628
GWS2205
Exceed 75m96
http://www.rcgroups.com/forums/showthread.php?t=1380133
EDF Motors.
http://www.rcgroups.com/forums/showthread.php?t=1185976
Rimfire 1.2
http://www.rcgroups.com/forums/showthread.php?t=1842975
Turnigy T4240 Black and red motor
http://www.rcgroups.com/forums/showthread.php?t=1416317
Turnigy EDF3040-480
http://www.rcgroups.com/forums/showthread.php?t=1413847
Turnigy SK 4240-750.
http://www.rcgroups.com/forums/showthread.php?t=1413624
Manuel V.
Old Jul 14, 2009, 01:47 AM
manuel v's Avatar
Joined Aug 2004
Motor clean.
No matter which place a fly. sooner or later the motor will have plenty of dirt particles in it. (I refer to outrun an motor.)
To clean, it is necessary to have a small hard brush or paintbrush, tape, and denatured alcohol .
Separates the bell of the stator.
And with a tape, tooth stick a skewer or a stick is clean inside. The tape collects all particles, even the metal.
Ends giving it a clean with alcohol. (optional)
Never put oil on the ball bearing.
one can put a drop of the shaft and then clean it.
oil only serves to trap dust, and the mixture weakens the ball bearing and shaft.
If necessary, clean the terminals with alcohol.
The acetone or liquid to clean off the nail can take off magnetos, spent finishing up the motor and stator epoxy.
The CA glue and the heat can damage the coated wire and produce short,
Another way to clean the motor is running water and washing with a brush. but need to dry it at 100% to prevent particular oxide before use.
This method is used to clean all electronic equipment, because water is the best and most economical of all solvents.
Help! How do I connect a prop to an electric motor? HeliGirl Beginner Training Area (Aircraft-Electric) 54 Oct 02, 2008 04:00 PM
How to identify an electric motor? Ward Power Systems 3 Apr 07, 2003 07:20 AM
How to buil an eletric motor? neophyte Scratchbuilt Indoor and Micro Models 2 Feb 21, 2003 05:03 AM
Information needed for adding an electric motor to my plane Biggles604 Sailplane Talk 1 Oct 24, 2002 02:39 PM
How to Repair an astro 40 BuyPlaneBill Beginner Training Area (Aircraft-Electric) 1 Jan 11, 2002 09:19 PM
