Old Jul 13, 2009, 06:47 PM
nxtdoor is offline
Find More Posts by nxtdoor
Tulsa Jones, Oklahoma, United States
Joined May 2002
Question
New Low IR Lipos Cells
I am trying to decide on batteries for a new plane and the performance of these new packs(Neu and Hyperion G3) makes me pause on what "s" configuration to use.
I have run the motor/prop combo (Neu 1512/1.5y/6.7 18.5 x12 RFM) with 2s 2200 TP Extremes in 6s series (was just a test, will be using higher mah) and it pulls 70amps and gives me 1200 watts output which is good for my Stratos E. I would expect the amp draw will decline a little when the prop unloads in the air.
I don't know how the TP Extremes (about a year old, very little cycles) compare in performance to the newer cells.
Any comments would be appreciated.
Jeff
nxtdoor is offline Find More Posts by nxtdoor
Old Jul 13, 2009, 07:00 PM
sneu is offline
Find More Posts by sneu
sneu's Avatar
United States, CA, San Diego
Joined Dec 1999
Our SP series are 40/70C and work great for silly power. They come in 2000,2600,3000 and 3700mah packs. http://www.neumotors.com/Site/Battery_Specs.html
Some people on this forum have been known to abuse the SP3700s at 400 amps
Steve Neu
sneu is offline Find More Posts by sneu
Old Jul 13, 2009, 07:46 PM
nxtdoor is offline
Joined May 2002
Thanks for the reply Steve. I am aware of the silly power available. What I want to know is will they up the amperage considerably compared to the TP Extremes from a year ago. I have read some people say they have to reduce the number of cells in series due to the increase in power from the newer cells. This is what I am trying to determine. I have a Phoenix 80 controller and want to try and stay around 80 amps max. The extremes at 6s were pulling 70 amps on the bench.
Jeff
Old Jul 14, 2009, 01:30 AM
sayno2glo is offline
Find More Posts by sayno2glo
I plan to take over world
sayno2glo's Avatar
Helsinki, Finland
Joined Jul 2002
Hi,
It depends how bad your batteries have become in a year. My one or two years old Polyquest 30C are so bad compared to new 35C G3 that I need 6s vs. 5s to make same power. I did a bentch test while ago. With old 30C batts I was at 800W and with the new 35C batts the same setup gave 1800W. That might be the most extreme difference ever but you can't really know until you test.
Even if the test show significant difference you can still preheat the old pack and choose larger prop and be in the same ball park.
sayno2glo is offline Find More Posts by sayno2glo
Old Jul 15, 2009, 01:49 PM
tjarko is online now
Find More Posts by tjarko
Eindhoven
Joined Jul 2007
Ri value for NEU3000SP cells ?
Steve do you have more info about these 40 C cells?
Discharge curves at 40C or Ri values?
Tjarko
tjarko is online now Find More Posts by tjarko
Old Jul 15, 2009, 05:41 PM
jjmouris is offline
Find More Posts by jjmouris
Needs to do 52 legs !!
jjmouris's Avatar
Verenigd Koninkrijk, Fareham
Joined Aug 2008
TP Extreme or Extreme V2 ?! Big difference!
I would say the new Neu 40C are equal to TP Pro Power P30 in terms of voltage / power for a given capacity.
But a CC 80 can probably take double it's rating in short bursts. Or 50% more in not so short bursts.
jjmouris is offline Find More Posts by jjmouris
Old Jul 15, 2009, 07:29 PM
sneu is offline
sneu's Avatar
Joined Dec 1999
On what do you base that bit of wisdom?
Steve
Old Jul 15, 2009, 07:57 PM
nxtdoor is offline
Joined May 2002
Steve, I tried another test with a warmed (to 95 degrees) 4s PQ3700 (at least a year old, very little use). The starting voltage was 16.8, pulled 75 amps with initial watts at 900 dropping to 850 after about 20 seconds with a loaded voltage of 12.5. How does that compare to one of your SP packs of similar size? Can I expect more performance?
Just ordered some of your 6mm connectors. The 13 ga. wires on the controller have to be changed!
Jeff
Old Jul 15, 2009, 09:10 PM
biskit is offline
Find More Posts by biskit
United States, AL
Joined Apr 2007
Measure the voltage of your packs and compare to the data below. Green is Pro Power 30, red is the 35c hyperion packs. Looks like the power increase you'll get boils down to basically what condition your existing packs are in.
See everydayflyer's data here: http://www.rcgroups.com/forums/attac...mentid=2622133
biskit is offline Find More Posts by biskit
Old Jul 16, 2009, 04:04 AM
jjmouris is offline
jjmouris's Avatar
Joined Aug 2008
Steve
By flying both, comparing the run time and looking at the data on the Unilog.
Old Jul 16, 2009, 08:33 AM
sneu is offline
sneu's Avatar
Joined Dec 1999
Really? When did you get some SP3700s?
Steve
Old Jul 16, 2009, 09:22 AM
jjmouris is offline
jjmouris's Avatar
Joined Aug 2008
Steve, i didn't. I am comparing whatever Eric had to mine as he flew mine. It was 2S and 3S joined to make 5S?
We also compared again the older 4100mah to the TP V2 3850mah and results showed a slightly higher power from the TP pack despite capacity difference.
In any case the thing that is more important to me is cycle life at constant performance. That is not going to be easy to compare at all.
Old Jul 16, 2009, 10:56 AM
sneu is offline
sneu's Avatar
Joined Dec 1999
I think that you would see that the SP3700s 40/70C are step up in power over the earlier cells. On the other hand with limiters what is also important is to have consistent performance from cycle to cycle.
Steve
Old Jul 16, 2009, 11:52 AM
George Shering is offline
Find More Posts by George Shering
Scotland
Joined May 2005
Steve
A big advantage of the latest cells is that you do not have to pre-heat them. The voltage seems to be the same at the beginning and end, with a slight rise in between. This, as Steve says, helps with consistency.
On the other hand the Germans control their motor run time by changing the pre-heat temperature. I don't think this could be done with the 2009 cells as the voltage is already falling at the end of the run.
My experience is with the Fullymax cells in the Overlander packs.
I have a feeling that most of the 2009 cells are from Fullymax judging by the sizes available????
George Shering is offline Find More Posts by George Shering
Old Jul 16, 2009, 01:39 PM
jjmouris is offline
jjmouris's Avatar
Joined Aug 2008
George, i was going to build another battery heater but instead i will be making my own hubs to put the blades out further or not, to adjust for the weather. This i think will be much more effective. It seems with the new battery's and their low IR, a small change in prop has big effects on current pulled. Where as in the past the battery needed to be hot to it would give constant power climb vs climb, now it does this anyway.
For Sale New 3s 3200 lipos low price. kriptonic Aircraft - Electric - Batteries & Chargers (FS/W) 2 Jul 25, 2007 08:12 AM
simple noob question on new lipos cells clearconcepts Batteries and Chargers 9 Dec 20, 2004 01:15 PM
FS: 16 New Sanyo 600AE Nicad Cells JohnM Aircraft - Electric - Airplanes (FS/W) 13 Dec 20, 2002 05:27 PM
8 New Sanyo 2100 nimh cells mickydee Aircraft - Electric - Airplanes (FS/W) 2 Sep 20, 2002 08:08 PM
new site on fuel cells member73 Parkflyers 2 Oct 30, 2001 03:13 PM
