Old Jul 12, 2009, 10:23 PM
Cerby is offline
Find More Posts by Cerby
Joined Jul 2009
Super Cub LP - Not Responding.
Hi! I'm new to the RC world, but not the electronics one. I have a couple of questions about my new Supercub LP which I've had out for about a dozen flights.
First: What is the 4 prong connector on the bottom of the LP for?
Second: I was out flying with a friend today, we both have LPs on different channels. I have crashed it twice on previous days including major tail damage. I'm used to it now, I was landing in a parking lot today, it was a decent landing, but hit a bump and tipped the plane forward a bit hard onto its nose. This is whats wrong:
No response at all, almost like the receiver is dead (I have tested the battery and transmitter, both are functioning as far normal as I can tell). I have taken the craft apart to check for clear damage - everything appears to be normal. Everything appears to be connected to a central control block/receiver. Is it best I simply replace this part or is it repairable? Or possible something else?
Thanks for help in advance
Cerby is offline Find More Posts by Cerby
Old Jul 12, 2009, 11:35 PM
Cerby is offline
Joined Jul 2009
Found it, a blown solder bridge - is this a common LP problem?
Old Jul 15, 2010, 12:11 AM
jakeinthebox is offline
Find More Posts by jakeinthebox
Jake-in-the-Box
Joined Jul 2010
I just experienced the same thing with my Super Cub LP and need to know where the solder break was to see if this was my issue as well. I looked everything over and cannot see any obvious problems.
jakeinthebox is offline Find More Posts by jakeinthebox
Old Jul 15, 2010, 12:26 AM
VROOMSTER is offline
Find More Posts by VROOMSTER
AMA #953123
VROOMSTER's Avatar
Eugene, ORYGUN
Joined Mar 2009
Sounds like you didn't get the throttle cut in time. I like to kill the power just as Im about to touch down so that doesn't happen. And yes, the stock RX/ESC brick is a known weak point with an otherwise great plane.
VROOMSTER is offline Find More Posts by VROOMSTER
Old Jul 15, 2010, 12:27 AM
flydiver is offline
Find More Posts by flydiver
flydiver's Avatar
United States, WA, Seattle
Joined Jan 2007
Since the cub went lipo the RX/ESC is very fragile. It is running 'on the edge' with a LOT more power but no upgrade. It only takes a second of prop stall with power on to fry it.
flydiver is offline Find More Posts by flydiver
Article HobbyZone Super Cub LP RTF on wheels and floats Review dee-grose Parkflyers 2184 Dec 17, 2014 06:59 PM
Discussion Super Cub LP? xelaxor Parkflyers 40 Dec 30, 2009 11:04 PM
Discussion Super Cub LP Receiver failure flyinfrog Beginner Training Area (Aircraft-Electric) 10 Jul 22, 2009 03:26 PM
Discussion Bored... of Super Cub LP gusmac Electric Plane Talk 16 Jun 22, 2009 09:47 AM
Sold Hobby Zone Super Cub RTF (not mini) lanex29 Aircraft - Electric - Airplanes (FS/W) 3 May 04, 2009 09:39 AM
