This thread is privately moderated by la528it, who may elect to delete unwanted replies.
Old Jul 12, 2009, 12:13 PM
la528it is offline
Find More Posts by la528it
la528it's Avatar
United States, UT, Salt Lake City
Joined Dec 2007
Cool
Hyperion^3
So I went a little hog wild lately and picked up some awesome hyperion products. Some lipos, a motor and a logger.
For what it is worth, Hyperion recently changed the dimensions on their website for the lipos.... I both measured and weighed every single lipo... and all were within .3mm and 2g of the posted dimensions!!!!!!!!!
The only exception was a 5500mah 3s pack that has 10g wiring, Because it's 3s, it has a wire running front to back, and mine juts out, making the pack wider than necessary. This is for a supertight application, so I may end up running the wire atop the cells... tbd
The motor seems quite strong. It shines where my axi 2826-8 was lacking. Yes, the hyperion is slightly heavier, but it also has a higher kv. So far, on 13x7 it pulled about 1200w on a 3s 3300 35/65c pack. I still need to find a faster prop, as this one is spitting out too much thrust.
More on the IR of these packs versus other manufacturers and the rdu to come....
la528it is offline Find More Posts by la528it
Old Jul 12, 2009, 03:09 PM
FASTBEN is offline
Find More Posts by FASTBEN
Cumulus Altimus
FASTBEN's Avatar
United States, TX, Keller
Joined Feb 2002
im using 13x9 on my 3025 Z on 4s fast..
ben
FASTBEN is offline Find More Posts by FASTBEN
Old Jul 12, 2009, 03:31 PM
la528it is offline
la528it's Avatar
Joined Dec 2007
ben
What are you pulling amp wise?
Old Jul 12, 2009, 07:05 PM
FASTBEN is offline
Cumulus Altimus
FASTBEN's Avatar
Joined Feb 2002
in 85 90....and not even hot when i land,i am using a 4s 2350 rhino 25c i have a g3 4s 3300 on its way 35c that should really bring this motor to life my 2m spirit (mibo) climes right at 90* to spec in 4sec.
ben
Old Jul 16, 2009, 12:30 PM
la528it is offline
la528it's Avatar
Joined Dec 2007
Well I repaired my neu motor... the pinion gear on the 5.2 drive came loose. A .9mm allan wrench from mcmaster carr and some green locktite later, and I was back in business (see pic below ):
P.S. I had to put tape over the top of the unit, because I have a fluorescent work light that causes the optical tach to consistantly read 3k... the rpm in the screen below were using the magnetic sensor on the rdu.... 3100watts, not bad for waking up the neighbors!
Sold Hyperion 3-Delight Clean & Cheap! COMBAT-WANG Aircraft - Electric - Airplanes (FS/W) 6 Jun 23, 2006 10:33 AM
Sold Hyperion 3-Delight Cheap! COMBAT-WANG Aircraft - Electric - Airplanes (FS/W) 15 Jun 05, 2006 10:03 PM
For Sale Hyperion 3-delight Rtf COMBAT-WANG Aircraft - Electric - Airplanes (FS/W) 1 May 22, 2006 06:18 PM
Sold Hyperion 3-DeLIGHT RTF built with extra parts (RTF) $250!!!! mups53 Aircraft - Electric - Airplanes (FS/W) 0 Apr 16, 2006 07:23 AM
Anyone using the Hyperion 3.7g servos for 3D? surfimp 3D Flying 4 Oct 04, 2005 06:12 PM
