Old Jul 12, 2009, 10:17 AM
shah is offline
Find More Posts by shah
Joined Dec 2008
Question
How to take apart a brushless motor?
Can anyone tell me or provide pointers to as to how to take a brushless motor apart, and its pitfalls?
shah is offline Find More Posts by shah
Old Jul 12, 2009, 10:59 AM
himeros is offline
Find More Posts by himeros
O. C. CA
Joined Jan 2005
Some are not make to come apart, for what reason do you want to take it apart?
H.
himeros is offline Find More Posts by himeros
Old Jul 12, 2009, 11:07 AM
flydiver is offline
Find More Posts by flydiver
flydiver's Avatar
United States, WA, Seattle
Joined Jan 2007
This is for a TowerPro but most of them are similar.
Problems:
1. Getting that #$#@@$ little e-clip off.
2. Losing the #$$@#$ e-clip.
3. There may be a tiny thrust washer that hangs up in the e-clip groove.
4. You need to pull HARD to overcome the magnetic attraction.
Assembly:
1. DO NOT let the stator SNAP back in > may damage bearings.
2. Getting the @#$@# e-clip back on if you still have it.
3. Finding an outlet for the e-clip you lost.
Some folks disassemble in a large plastic bag to keep it from getting lost.
While you are in there oil the bearings. They are frequently pretty dry, even when new if cheap. NO WD-40. 3-in-1 will work.
Edit: Oops-forgot the links:
How to Disassemble Tower Pro Brushless Bell Motor (4 min 4 sec)
http://www.bphobbies.com/pdf/bp/BPMotorDisassembly.pdf
flydiver is offline Find More Posts by flydiver
Old Jul 12, 2009, 11:53 AM
keyman923 is offline
Find More Posts by keyman923
Former Futaba employee
Joined Aug 2006
So true, stupid clip
keyman923 is offline Find More Posts by keyman923
Old Jul 12, 2009, 12:03 PM
Challenger 413 is offline
Find More Posts by Challenger 413
Challenger 413's Avatar
Dickinson, Tx.
Joined Sep 2004
Use the bag, Luke..
Challenger413
Challenger 413 is offline Find More Posts by Challenger 413
Old Jul 12, 2009, 04:33 PM
wilcoxfood is offline
Find More Posts by wilcoxfood
Joined Mar 2009
I just remove the two set screws on the magnet end and just push the shaft out the the mounting bracket end. Then seperate the two peices for inspection and if necesary, do my rewinding of the motor.
wilcoxfood is offline Find More Posts by wilcoxfood
Old Jul 12, 2009, 05:12 PM
shah is offline
Joined Dec 2008
Guys, thanks a lot, particularly flydiver. It was hilarious.
I actually needed to take HXT 16g motor from hobbycity.
http://www.hobbycity.com/hobbycity/s...idProduct=6311
Surprisingly the motor has the mount stuck on it. Even after getting the grub screws out, the mount does not come off. And the mount is such that it is all solid from the back side so the clip is not visible/accessible.
I have many motors, ironically the TowerPro bell motors are the only ones still surviving all the crashes. I have one more HXT motor (24g one) that died after one of the wires coming out of the motor broke. I can see the broken wire down at the stator but don't know how to fix it. I have a couple of more motors that have simiilar problem, like FC 2805. Those motors don't even start. They try to turn but it seems something inside is stopping them from spinning. I guess I will start by opening one of those.
Old Jul 12, 2009, 05:38 PM
Fourdan is offline
Find More Posts by Fourdan
Fourdan's Avatar
Antony (France)
Joined Sep 2003
Hi
A lot of "good" outrunners have wheel collar + set screw instead of bad quality circlip.
Easy (generally) to remove the rotor-shaft assembly.
Sometimes, one need to turn the shaft with abrasive paper to slip through the ball bearings inner rings.
Louis
Fourdan is offline Find More Posts by Fourdan
Old Jul 12, 2009, 08:36 PM
flydiver is offline
flydiver's Avatar
Joined Jan 2007
Broken wires on cheap motors (and expensive motors also) is all too common. Sometimes if you are good AND lucky you can clean off insulartion and re-solder. Usually the fix is re-wind or re-place.
Old Jul 12, 2009, 08:58 PM
shah is offline
Joined Dec 2008
I now have a broken wire on the 16g HXT motor just like the 24g HXT motor. Clearly this is a common problem with HXT motors I would think. It was probably about to break and that's what causing the cut off. I have noticed this before with other motors as well. When they have a loose connection it causes the jerks at startup or it shuts down in the middle. I don't think I would be able to remove the insulation as there is not enough space to work with. And I have no idea how to rewind. I guess I will have to search on youtube about this. Or does anyone have a pointer for me to such a video? I can always order another motor from Hobbycity but that would mean a 3 weeks wait.
Old Jul 12, 2009, 09:30 PM
flydiver is offline
flydiver's Avatar
Joined Jan 2007
This is a MASSIVE sticky for HUGE amounts of info.
[http://www.rcgroups.com/forums/showthread.php?t=240993]
Probably the easiest place to start is here:
GoBrushless.com.
Read one of the tutorials on winding the GBv or GBx.
Those are ABC winds for 9 stator poles and 12 magnets.
If you have 12 stator poles and 14 magnets that's a dLRK wind and a good tutorial is here:
http://www.rcgroups.com/forums/showthread.php?t=736580
Both of those motors are known for broken wire issues but are good candidates for rewinds.
How is the best way to take apart the BP21 motor? himeros Power Systems 3 May 28, 2005 12:27 PM
Question Does anyone know how to take a HIMAX2025 Brushless apart? mpwaite Power Systems 6 Apr 17, 2005 06:52 PM
How to take apart the HS-50? robert harik Hitec/Multiplex USA 1 May 17, 2004 12:01 PM
How to reverse a sensored brushless motor. davecee Power Systems 8 Jun 23, 2003 04:25 PM
how to take apart astro 020 brushless? BillH Electric Plane Talk 3 May 05, 2001 11:39 PM
