Old Jul 11, 2009, 10:20 AM
rhamz is offline
Find More Posts by rhamz
Norway
Joined Jul 2009
How to install twin motors
Im interested in setting up a twin engine aircraft on a AR6100.
Due too me being new to installing the electric components
my self i thought i could get some "RC for dummies" hints
I have several brushless engines, ESC and lipo batteries.
What i have read so far is that one battery is the smartest
way to go. But what im after is a wiring diagram for one battery connected
to two ESCs with one engine each, all controlled by one channel
on the Rx. If someone can guide me to a thread where a beginner like
me can understand what to do, or even better, draw me a simple
wiring diagram in paint
Thanks in advance.
Lars
rhamz is offline Find More Posts by rhamz
Old Jul 11, 2009, 11:41 AM
EricJ320 is offline
Find More Posts by EricJ320
EricJ320's Avatar
Knoxville, TN
Joined Dec 2005
Not that difficult.
Solder the battery leads on both ESC's to a single connector, or use a simple parallel lead to connect the two ESC's. Use a single battery to power both, or another parallel lead if you want to parallel two batteries.
As for the rx wire, it somewhat depends if your ESC's BEC can be run in parallel or not. I know Castle ESC's can, there are others I've read that can't. Use a servo y connector and link the two ESC's together and run the y connector into the throttle position on your rx. If you determine the BEC's can't be run in parallel, you will have to deactivate one of the BEC's by removing the center wire from the the connector, or use an external BEC.
Sorry for no diagram, but I hope the description is simple enough to understand without it.
Eric
EricJ320 is offline Find More Posts by EricJ320
Old Jul 11, 2009, 11:53 AM
Ron van Sommeren is offline
Find More Posts by Ron van Sommeren
homo ludens modellisticus
Ron van Sommeren's Avatar
Netherlands, GE, Nijmegen
Joined Feb 2001
Wiring diagrams (a sure bookmark candidate )
scriptasylum.com/rc_speed/_wiring.html
To meet the natives:
forum.modellflynytt.no/forumdisplay.php?f=63
forum.radiostyrt.no/vb/forumdisplay.php?f=22
Slightly less native, but more active:
www.svensktmodellflyg.se/forum1.asp?viewmode=0&CurrentMainTopic=2
www.rc-unionen.dk/nytforum/forum.asp?FORUM_ID=40
Med venlig hilsen, Ron
Ron van Sommeren is offline Find More Posts by Ron van Sommeren
Old Jul 11, 2009, 12:00 PM
Joined Feb 2001
Originally Posted by rhamz
... a beginner like me
For a rainy day.
* Presentation: de-mystifying Electric Flight
www.rcaircrafters.org/The%20Electric%20Show.pdf
* Brushless motor animations and simulations. Mostly outrunners but inrunners are just outrunners turned inside out.
www.rcgroups.com/forums/showthread.php?t=216928
* www.wattflyer.com/forums/forumdisplay.php?f=3
-> Everything You Wanted To Know About Electric Powered Flight
* www.ampaviators.com
-> Beginner Guide
* www.ezonemag.com
-> Faq
* Choosing a power setup
www.rcgroups.com/forums/showthread.php?t=739069
www.wattflyer.com/forums/showthread.php?t=27019
* Current, voltage, Watt, battery-types and -C-rating explained
www.rcgroups.com/forums/showthread.php?t=417868
* 'Dry' testing brushless motors after a mishap:
www.wattflyer.com/forums/showthread.php?t=35216
www.rcgroups.com/forums/showthread.php?t=240993
* Motor_internals_101, about poles, winds, delta, star
www.gobrushless.com
-> knowledge base
-> basic overview (1-5)
Old Jul 11, 2009, 12:48 PM
eflightray is online now
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Lars here's a connection diagram for twin brushless.
And a link to my twin brushless Mosquito thread, (there are loads of other twins in various forums, but the Foamies (Scratchbuilt) is a good place to search) -
Mosquito profile foamie
Good luck with your twin.
eflightray is online now Find More Posts by eflightray
Old Dec 02, 2009, 05:19 PM
lw_hughes is offline
Find More Posts by lw_hughes
Hals und Beinbruch !!!!
lw_hughes's Avatar
Joined Aug 2002
I am looking for some info on connecting 2 esc to a ar6400. I dont want to fry the rx with twice the input voltage. Any help would be great.
lw_hughes is offline Find More Posts by lw_hughes
how to connect a a gws IPS-D Twin motors tibofo GWS (Grand Wing Servo) 0 Apr 06, 2004 03:32 AM
Brushless twin motors - How to wire? rtideas Power Systems 1 Nov 10, 2002 08:19 PM
Twin Motors - How to wire? TheAddler Scale Kit/Scratch Built 5 May 29, 2002 02:29 AM
How To Install Different Motors in the Kyosho and Mini Fan Joe Elston Electric Plane Talk 4 May 31, 2001 10:40 AM
How to install different motors in fans Joe Elston Electric Ducted Fan Jet Talk 0 May 30, 2001 12:10 AM
