Not sure that this is the correct machine as the tail looks a little different but the man, as an accomplished flyer certainly is impressive. This deadstick crosswind landing defies belief. There is also one where he comes out of a loop and lands. Magic stuff.
There are a number of other clips on youtube if any one is interested.
John |
Germany, BW, Sankt Leon-Rot
Joined Oct 2006
It took me a few days to come back to built.
While I finished the square piece of the fuselage box, and the rear part, I cut and bent the wires for the udnercarriage as well as the struts. Hoping to get the top wing nicely alligned with the fuselage, I realized I should finish the wings first. The 2 main 16 SWG (or 1,5 mm as we would say) struts will be bent and glued to the fuselage box - So I think I finish the wings, get the saddle clamps cut and position the wing over the fuselage to that I can get things in the right position to bend and glue the struts. I was wondering for a while whether I should build ailerons, but as I do not want to disappoint Peter and also it saves me 2 servos and I can use a tiny 4 channel receiver - so a lot of convinving arguments to go without.The wings are very quickly built, even if I used PVA as I ran out of medium cyano. Just be careful as some ribs (around the dihedral brace) are of slight different shape around the spare (you see : good to use PVA as it gives you a few more minutes to realize the mistakes) I sanded 4 out of the 5 wing elements, and I should be back at late hours somewhere during next week. Btw: as it is only 2 servos, I thought I treat myself with HS55 servos - the ones I normally use are about 2/3 of the price. The local dealer is 1 EUR more expensive then the large stores on the web - but apparently you save 6 EUR for postage and packing.... O.K. - to be continued
| Thread Tools | |
| Build Log Peter Rake 43" FE8 prototype build | Pat Lynch | Scale Electric Planes | 359 | Oct 01, 2011 03:49 PM |
| Discussion Peter Rake Fournier RF-4 Prototype Build | tacchino | Scale Electric Planes | 133 | Aug 26, 2010 02:10 PM |
| Build Log Peter Rake's Pachyderm - A Martinsyde Elephant build | Gerry Markgraf | Scale Electric Planes | 150 | Jun 19, 2010 07:23 PM |
| Build Log Peter Rake Lublin R-XII Prototype Build | Dan Parson | Scale Electric Planes | 332 | May 16, 2010 09:38 AM |
| Discussion Peter Rake IPS Hergt Monoplane prototype build | jofrost | Scale Electric Planes | 82 | Jul 26, 2007 04:35 PM |
