| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||
#46 |
TeKrunner,
sorry I did not respond earlier but I have been out of town. The DEM information is used in mission simulation to warn you that you are to close to terrain (If i remember correctly you set what you want the limit to be). During flight it will also warn you that you are getting to close to terrain. Cort |
#47 |
Hey Cort,
Thanks for that info, I found it quite interesting. tekrunner |
#48 | |
Don't disturb the pilot
Cheers, Sander. |
#49 | |
Sander is correct, unless you have a GPS on the tracker you will always need to point the tracker north to calibrate. Chris |
#50 |
Last edited by brakar; Jul 28, 2009 at 06:35 PM. Reason: burp not needed, more or less idiotic... |
#51 | |
#52 | |
Sure, or I can just post it here. The tracking system is currently set up for Atto but we have provisions to make it work with other autopilots as well. It is capable of moving 50kg although that is crazy overkill. Our system weighs 25lbs with counterweights. The extra ability is to withstand high wind loadings. The tripod is a professional system with a single handed air assisted pole that can be raised and lowered to a height of 3m. Availability is almost immediately although there is at least a 2 week lead time due to ordering of parts. The price has not been set and is dependent of the components you choose for video and telemetry and the pan tilt gimbal you decide to go with. There are two options. It is not cheap!!!!! It’s professional. It may be a bit pre-mature just yet but if its an absolute necessity in a very short time we can chat about the time restraints you may have via e-mail or phone. Thank you, Chris |
#53 |
Hey guys what going on with this any updates?
#54 | |
dmgoedde
#55 | |
Got ya! Thanks for the clarification. |
#56 |
Dean
If you have to calibrate it by pointing it to the aircraft why does it have to set down pointing North. I set my tracker down and point in the general area I'll fly, it turns left and right 200 degrees. I adjust a pot that tells the tracker where north is. I basically just use that as the one time calibration by adjusting it to point to the aircraft. Kisssys |
#57 |
What is the IMU unit finally going to look like in terms of payload and control surface controls?
I remember there was going to be a daughter board with support for X many extra servos. Also, the included GCS will be same as the one included with the 1.8V? or is the new one "professional" included with the IMU. |
#58 | |
Dean is finalizing everything on the design. It will be a control unit and a separate IMU cube you can install anywhere. The first reason for this is we want you to be able to mount the IMU out of the way of wires and payload. Second reason is to give you the ability to buy just the IMU and integrate it into their own system. Third is in case you need to replace the IMU and do not want to dismantle your wiring in the bird. Plugging everything in and cleaning it up can be tedious. The current GCS is the one that will be offered with the IMU. The "professional" version will be sold as a separate product if one needs. Chris |
#59 |
will the control unit (support for how many controls) be purchase separately or included with the IMU.
I think you guys hit the nail on the head with ATTO 3.XX by separating both. Great idea! Please update us with a tentative release month and a ball park price if available. I already have saved the $2500 for it. |
#60 | |
I will talk to Dean on how many control outputs it has. I have a prototype and I do not want to make the wrong statement. There will be an expander board available. I will also talk with the guys so we can finalize a price. It would be fair to say it will be around the $3000.00 USD range. The control board comes with the system when you buy a full Autopilot. Chris Last edited by airmcn_3; Oct 01, 2009 at 06:50 PM. |
| Thread Tools | |
| Alert F-86 pre order list | TFLG | Inland Slope Rebels | 97 | May 30, 2007 11:10 AM |
| Castle Creations Open Discussion V3.0 | Patrick del Castillo | Castle Creations | 150 | Jan 02, 2007 08:54 AM |
| Discussion Shrike Pre-order List Is Now Closed | SkyKing RC | Slope | 0 | Nov 23, 2006 06:49 PM |
| Notice that the A-10 is now Avail for Pre-order from Online shops | Etonic | Parkflyers | 6 | Feb 22, 2003 11:50 AM |
| Pre-Order the GWS Zero Now. | gbagley | Aircraft - Electric - Airplanes (FS/W) | 0 | Mar 11, 2002 11:30 PM |
