Old Jul 09, 2009, 04:02 PM
ggunners is offline
Find More Posts by ggunners
Bit-Twiddler and Flyer
USA, VA, Chantilly
Joined Apr 2002
New HZ Super Cub LP for FMS
Hello all!
I have just completed a model of the HobbyZone Super Cub LP for FMS.
The HobbyZone Super Cub LP is the long awaited update for the original Super Cub.
Model Specs are:
Wing Span: 47.75 in / 1200mm
Overall Length: 32.5 in / 825mm
Flying Weight: 25.2 oz / 715g
Motor Size: 480 power with 3:1 gearbox
Prop: 9 x 6
Radio: Proportional 3-channel FM, R/E/T
Battery: 3S1P 11.1V 1350mAh 20C LiPo
Please try the model with FMS and let me know
how it flies or whether any adjustments are needed.
-- ggunners
P.S. Here are the other Super Cubs: Original, Mini, Tundra 4ch
ggunners is offline Find More Posts by ggunners
Old Jul 10, 2009, 10:20 AM
bigmcgiv is offline
Find More Posts by bigmcgiv
wilkesbarre pa
Joined Jul 2009
i want to download this plane but i cant get it to go into my esky
bigmcgiv is offline Find More Posts by bigmcgiv
Old Jul 10, 2009, 01:13 PM
ggunners is offline
USA, VA, Chantilly
Joined Apr 2002
First you should already have installed FMS 2 alpha 8.5. The older 2.7 version will not fly the newer models.
Then click on a link for an airplane. When it asks to save or open choose to "open" the file.
Then extract the contents of the .zip file to the C:\ Program Files\ FMS\ Model\ directory.
-- ggunners
Old Jul 10, 2009, 02:10 PM
bigmcgiv is offline
wilkesbarre pa
Joined Jul 2009
OK thats my problem where is the link to the 8.5 i have the 2.7 version
Old Jul 10, 2009, 04:31 PM
ggunners is offline
USA, VA, Chantilly
Joined Apr 2002
Same place you downloaded v 2.7.
http://n.ethz.ch/student/mmoeller/fms/down.html
There are some known issues with FMS 2.8.5 with WinXP if your computer does not have a serial COM port and with Vista missing the DirectX 9 .dll file. You can find fixes on the FMS Forum.
http://n.ethz.ch/student/mmoeller/fm...pic.php?t=4813
-- ggunners
Old Jul 27, 2009, 06:50 AM
Cubber1 is offline
Find More Posts by Cubber1
Cubber1's Avatar
Norway, Hordaland, Årstad
Joined May 2009
Thanks for the new model, it flies really nice ! Do you have experience with both models, and is it actually that much more powerful with Lipo ?
Anyway, thanks also for linking to those other cubs, didn't have the aileron one before. Ailerons sure seems nice when trying that one !
The standard cub seems the closest in flying characteristics, to my own Kyosho J-3 (same as parkzone J-3)...but very nice to have these other versions.
Cubber1 is offline Find More Posts by Cubber1
Old Jul 27, 2009, 11:53 AM
ggunners is offline
USA, VA, Chantilly
Joined Apr 2002
I fly my original SuperCub with 1350 mAh LiPo and the smaller prop and it flys extremely different from the stock prop and the NiMh batteries which have lower voltage and increased weight. Higher voltage means higher prop speeds, lighter weight means better watts/ounce. Consequently, it is like night and day. I was not a fan of the model until I converted to LiPo, now it is quite awesome.
Stock SC, straight and level or maybe even a drop in height leaving your hand and need to build speed before climbing. LP SC, climbs strong at a 30 degree angle when leaving your hand. Stock SC, no tight turns low to the ground as it falls from the sky. LP SC, tight full throttle turns with very little loss in altitude. Just a few differences.
I hope the new LP FMS model captures them.
-- ggunners
Old Jul 28, 2009, 05:29 PM
Cubber1 is offline
Cubber1's Avatar
Joined May 2009
From what you describe that sounds pretty accurate - power is like night and day on the two FMS-versions !
Discussion New 4Ch Super Cub ok for a beginner? freakybwoy Beginner Training Area (Aircraft-Electric) 13 Feb 05, 2009 09:03 AM
Video New HZ super cub with pants! lxelementxl Electric Plane Talk 14 Jul 18, 2008 12:58 AM
Question Using HZ Super Cub Gear for 2nd Plane msnyder Beginner Training Area (Aircraft-Electric) 9 Jun 07, 2007 01:00 AM
Yippee! New HZ Super Cub on the way Gnascher Parkflyers 9 Jan 25, 2007 08:46 AM
