Old Jul 09, 2009, 04:26 AM
davereap is offline
Find More Posts by davereap
davereap's Avatar
Ashford. Kent. England
Joined Feb 2005
Build Log
A simple build Plank with KFm4 section.. with WOW! factor.. Called it the "Nifty"
Rather than have the build spread out in the main KF thread, I decided to repost it all here
What was just a maybe idea built very quickly and flew so well I have to plug it like mad...dont miss out, its simple to build and WOW is the best way to describe how it goes...superb
edit wow its ugly as well
heres how it started
Ive just been looking at whats in the shops and came across this design in epp... My first thought was an easy KFm4 build, cant get much simpler 600 span 300 chord is the size and the pic tells the rest
The 600x300 is the 24" version... but the first Nifty built was a 32" version
davereap is offline Find More Posts by davereap
Old Jul 09, 2009, 04:37 AM
davereap is offline
davereap's Avatar
Joined Feb 2005
With a supply of 6mm depron I got cutting.
At my location small light planes are not the best, so I decided to go up a size ..from 600 span to 800.
800 is a good size and coresponds to the width of my sheets.. keep it simple .. the 32" span gave a 16" chord and an aspect ratio of 2..
Hence it designation as a KFm4-AR2-Plank
Cutting cant be easier all straight lines for the wing layers.. I decided to put the top and bottom KF steps at 45%, again keeping it simple..measurements in inches
Main/centre layer 32 x 16.. 1 off
outer layers 32 x 7 1/4.. 2 off
Spars Balsa 1/4x3/4 x 32.. 2 off.......shown in red pic3...do use balsa not depron..the balsa makes much stronger wing
Rough FUZ 3 x shape as drawing
wing tips 2 off, are near triangles 17" long x 6 1/4" high..but with a front squared edge 3/4 deep..check the picture first
EDIT there is a revised build .. It is easier and very simple..... directly laminate all the foam layers... and using pallet strapping instead of balsa spars, glue the strapping top and bottom of the wing making a strapping/foam/strapping sandwich...its a strong wing.... .. the rest is much the same..
If you want, for more strength, the main layer and its elevons can be doubled , then you can use a cloth hinge fitted between the layers..
Old Jul 09, 2009, 04:45 AM
davereap is offline
davereap's Avatar
Joined Feb 2005
Laminating.
marking up..
Put a line 1.5" from the front on both sides of the main panel and one side of each of the 2 layers/steps. this is where you will spread the uhu to laminate the layers together to form the leading edge...
On the two layers/steps also put a line 3/4 from the rear edge.. this is where the spar will be stuck
On the main panel put a line across at 7 1/4" ..this is the rear of the step position..put another line 3/4 in front of that one..repeat on the other side.
On the main panel cut off a 3" strip from the back for the elevons
Gluing
one side at a time...spread UHU por along the LE and the spar positions on the main panel..
Spread uhu along one side of one spar.
Spread uhu along one of the layers at LE and spar positions.
By now the spar coating and the main layer coatings will be dry, so on a flat surface push the spar in position, then rub it down hard to fix it.
Spread uhu on the top of the spar and wait for it to dry.
The top layer can now be fixed...with care position the layer first onto the spar, and rub down hard, now starting from the centre push the LE down to meet the main panel, work outwards, and firmly fix the two layers together..
Turn over and repeat...what youve got should look like the brown sections in the above picture
Old Jul 09, 2009, 04:46 AM
davereap is offline
davereap's Avatar
Joined Feb 2005
Take your 3 rough cut FUZ parts and laminate together.. then fix them nicely central and squre under the wing. uhu will do the job ok.
The square stick for the motor mount is epoxied centrally on to the top front on the fuz blocks..shown in red pic3 two posts back... now make sure you can fit the motor mount to the front of the stick. Fill at the sides of the stick with more depron then add a further pair of side cheeks to the fuz ....see pic 5
Put the motor in place and do some carving on the fuz to get the shape you want..pic1
Shape the LE of the wing to a nice symetrical profile..
Thats the main build done... glue on and shape the tip fins, fit the elevons, and importantly you should add reinforcing tape as and where shown in the pictures..
The tape reinforcing uses the 2" wide colored packing tape.. this adds strength and damage resistance to the model and I think its a must use...
Fit the radio gear, again as per the pics and you will be OK
Important edit
The COG location should be at 20% for the first flight, with about 3mm up on the elevons.. launch at moderate power and it will go hands off..power up trim out and enjoy.
My impression is the COG can go back slightly for improved performance..
as the cog goes back you might need to reduce the elevator movements.. and use loads of expo to keep it sweet..
Old Jul 09, 2009, 07:25 AM
gpw is offline
gpw
Find More Posts by gpw
gpw
“There’s no place like Foam”
gpw's Avatar
United States, LA, New Orleans
Joined Jul 2002
Love those Planks!!! .... We used to make them from Ace Foam Wings , with .049s... Not the most stable platform, but lots of FUN !!!!! The bigger the fins , the more it flies like a wheelbarrow... some experimentation is indicated...
gpw is offline Find More Posts by gpw
Old Jul 09, 2009, 07:28 AM
davereap is offline
davereap's Avatar
Joined Feb 2005
Try now with the KFm4 section..you will be amazed... guaranteed
The KFm4 section has made this wing so good I dont beleive it myself..
These are hands off stable yet highly manouverable the best of everything..
Good safe glide, fast rolls etc...
And best of all its as simple as they come..
EDIT VIDEOS REPOSTED HERE
This the 24" 3mm depron version
24 inch Nifty the KFm4 plank - 1 (3 min 30 sec)
24 inch Nifty the KFm4 plank video 2 (2 min 46 sec)
Old Jul 09, 2009, 07:34 AM
gpw is offline
gpw
gpw
gpw's Avatar
Joined Jul 2002
We most certainly will !!!! Thanks !!!
Old Jul 09, 2009, 08:04 AM
davereap is offline
davereap's Avatar
Joined Feb 2005
Gear and plane specs for the 32" version
2x 9gm servos
30A ESC ( bigger than actually needed )
corona 2.4Gb 4ch REC
1250 3 cell rhino lipo
9x5 gws prop
This motor.. http://www.overlander.co.uk/product....id=93&pid=2581
Which gives 24oz thrust at 150W approx..
The plane weighs in at 15 1/4oz AUW which gives a wing loading of 4.3oz sqft
results... five grins...oh boy does it go
New motor added.. The cheepo bell, the 2208-21.. use a cut down 9x5.. cut to 7.5x5 and 3 cells..gives another 2000 revs and about the same static thrusts..hovers on half power
Specs on a 24" are
2x5gm servos.... corona 4ch 2.4G rec
BW motor... 8x4 GWS prop
18A ESC... 1250 3 cell lipo
AUW...10.5oz area 2sqft
Old Jul 09, 2009, 11:16 AM
dekan is offline
Find More Posts by dekan
D'oh.. Dumb Left Thumb
dekan's Avatar
London, UK
Joined Nov 2006
Well done Dave... saves paying £25 or about $40US... Just what my FB is looking for...
He almost bought the Epp kit, but he's a bit "financially challenged" at the moment
Ok for the B&Q foam and lots parcel tape..
dekan is offline Find More Posts by dekan
Old Jul 09, 2009, 11:28 AM
High Flyin' is online now
Find More Posts by High Flyin'
Out the Window
High Flyin''s Avatar
United States, FL, Alachua
Joined Jul 2004
Dave....great looking design!
Since you have built several NutBalls, how does this one fly in comparison to the NutBall?
Are you using EPP on this one? How thick is the foam you are using?
Looking forward to the video!
Ray
High Flyin' is online now Find More Posts by High Flyin'
Old Jul 09, 2009, 11:34 AM
Dickeroo is online now
Find More Posts by Dickeroo
Dickeroo's Avatar
Joined Dec 2006
Good glide fast rolls etc...
I will get video as soon as the wind dies down
Dave... I'm grinning from ear to ear. It just amazes me how the KFm4 airfoil can offer so much with so little cost and time to build. And, provide the strength that the wing needs without adding additional support. It's almost too good to be true. Another terrific thing is that the KFm concept allows for a wide range of experimentation. And, that's part of the fun of RC flying. Congratulations on a great experiment.
Dickeroo is online now Find More Posts by Dickeroo
Old Jul 09, 2009, 12:47 PM
jclassic1 is offline
Find More Posts by jclassic1
jclassic1
New Houghton, Derbyshire, UK
Joined May 2006
Looking forward to a vidio on this one dave,it,s as easy as the nutball to build and by the sound of it just as much fun.Goes to the top of my list with the stinger by Bogard.Just happen to have a couple of 1200X800 grey depron sheet waiting to be cut.
John
jclassic1 is offline Find More Posts by jclassic1
Old Jul 09, 2009, 01:28 PM
davereap is offline
davereap's Avatar
Joined Feb 2005
high flyin'.. all 6mm depron foam.... comparison with the nutball...difficult, they are two very different planes and each will cover different aspects of flight better.. I would say have both, as they are complimentary... the best I can say is I felt totaly confident with the planks flight, right from the start, and this makes you able to push your limits... my only other plane ever to do this was the 38" KFm4 superfly clone, and the plank' flight is more like that one, than the nutball
dekan.. I am still visiting my B&Q but they wont get me any of their foam
The robotbirds kit is £25 plus post, so not too expensive, I will let you work out the cost of mine, but I suspect its less than £5
Dick.. what ever did we do before we got your airfoil... from GPW's post, earlier versions of similar planks were a bit on the unstable side... this one is just the opposite, going precisely where you want with no problem, slow and fast. Yet I can manouver it as tight as I want..unbelievably good
jclassic1.. much easier to build than the KFm4 Nutball ..all straight lines.. no dihedral to allow for.. everything just square
edit here is some more info
Old Jul 09, 2009, 01:53 PM
jclassic1
Joined May 2006
Dave ,I haven,t got any balsa for the spars so do you think that a strip of depron will do.I may have to add a carbon spar behind the top step.
John
Old Jul 09, 2009, 02:04 PM
davereap is offline
davereap's Avatar
Joined Feb 2005
I would say treat yourself to a 1/4" x3" hard balsa plank and cut the 3/4" strips from that..Its far cheaper than adding a CF spar ... do not use just depron, its too flexy and doesnt add the strength that you will get from the balsa.. A CF tube or rod will do the job, but 2 balsa spars will only cost 60p..Better to wait till youve got the balsa.. dave
heres a video ..the flight was made with the cog at 18%..you can see with the trim set for this cog power up causes a climb and eventually a loop... A second flight with the cog at 20% had the trim reduced and power up causing only a slight climb..At 20% its is still easy to fly but will loop or come round from a vertical bank so quick you will almost miss it.
This is the first video where the plank got its name Nifty.
The 32" 6mm depron version
A simple build KFm4-AR2-plank...The "Nifty" (5 min 20 sec)
If you have kids, build these with them Gordon Johnson Scratchbuilt Indoor and Micro Models 26 Jul 08, 2005 10:12 PM
Simple current measurement with cheap multimeter StaalBurger DIY Electronics 14 Dec 14, 2004 11:43 AM
Plank With "Clark-Y-ish" Airfoil? Buzz_Man Flying Wings 94 Sep 24, 2004 02:50 PM
Simple series P51 with baby bee LevelUphill Fuel Plane Talk 1 May 19, 2003 05:18 AM
Build Wingo with PVA instead of Epoxy ? JensJakob Foamies (Kits) 10 Jun 04, 2001 11:50 PM
