Old Apr 05, 2003, 02:58 PM
scottw is offline
Find More Posts by scottw
Joined Mar 2003
NEWBIE: The Zagi/Ele-Bee Prop falls off!!
Okay, Im new to flying and I am getting frustrated.
I have an Ele-bee.
I get the plane w/ 3 props. I take out to fly and I have about 40 seconds of total air time, with a total 4 throws 10 seconds each, and my prop breaks in half.
Not a problem, I got 2 more!! So, I stick it on and 4 throws later, 10 seconds each. Still on, not broke. Throw it again, prop comes off in the air. Down goes my Ele-bee like a brick. I locate the prop, put it back on, it comes off again. Find out, some of the plastic has been take off on onto the prop-motor.
I grab another one, same thing repeats itself.
I go to a local store and pay a inflated 3.59 PER PROP and take it out, 4 filghts later, toast.
1) I am new, so I am frustrated because I can't get any good air time to practice flying... having to replace the prop every 4 throws.
2) The engineering is really messed up. Why is a reverse flying prop only attached with friction? Makes NO SENSE to me what-so-over.
3) What can I do (short of gluing them on with super glue) to keep these things on.
4) What other solutions, better solutions, prop, motor would be a good solution... hopefully something that flies bricks really well cause mine is just that, a big square brick.
I get absolutely NO lift out of this thing, I throw it, it might go up 30 ft or so then the wind catches it and trashes it onto the ground.
I replaced my elevons w/ the plastic and since then, my 40 seconds of air time seems to be much more stable than my previous 100 seconds of air time w/ my previous 3 props.
Scott
scottw is offline Find More Posts by scottw
Old Apr 05, 2003, 05:49 PM
poobs is offline
Find More Posts by poobs
poobs's Avatar
oakdale, ny, usa
Joined Aug 2000
Is the motor turning the right way?
She should blow air toward the back of the plane.
poobs is offline Find More Posts by poobs
Old Apr 05, 2003, 05:59 PM
scottw is offline
Joined Mar 2003
Yes, it is right.
Old Apr 05, 2003, 06:00 PM
birdofprey is offline
Find More Posts by birdofprey
The Magician.
birdofprey's Avatar
Lucas, Kansas
Joined Nov 2002
Scott,
Pull the black spinner off of the prop and put it back on the prop from the other side.
this will help with the thrust issue (the lettering on the prop should face away from the plane/motor).
Make sure that when you press the prop on to the motor that you push it on all of the way (about 3/8 inch) and the problem with the prop comming off should go away. If the prop is not all of the way on the shaft it can spin the prop off.
The press fit of the prop works well, and I have only had problems with them comming off durring flight when they were not on all of the way, or the hub of the prop was cracked.
Justin
birdofprey is offline Find More Posts by birdofprey
Old Apr 05, 2003, 06:45 PM
turaboy is offline
Find More Posts by turaboy
turaboy's Avatar
USA, VA, Centreville
Joined Jan 2003
One way to keep the prop from coming off is shown on the YourZagi page. Go to this page and scroll down to "My propeller keeps falling off!"
I had some propeller issues in the past; since I have been drilling holes in the black rubber spinner, I haven't lost any!
Good luck and keep with it...
turaboy is offline Find More Posts by turaboy
Old Apr 05, 2003, 10:45 PM
Mike Taylor is offline
Find More Posts by Mike Taylor
Team 30 Micro EDF
Mike Taylor's Avatar
Camarillo, California
Joined Apr 2002
Wrap the prop shaft with some sewing thread, then hit the thread with some CA. The thread will increase the diameter of the shaft a litlle bit, and it will provide more friction, too.
Mike Taylor is offline Find More Posts by Mike Taylor
Old Apr 06, 2003, 11:18 AM
Basketcase is offline
Find More Posts by Basketcase
an earth bound misfit, I
Basketcase's Avatar
St. Pete, Florida
Joined Sep 2001
As Turaboy said drilling a hole in the end as outlined on the YourZagi page works great. Apparently it lets the air out so it doesn't push the prop off, either with the help of the torque or from the heat of the shaft expanding the air and popping it off.
You might want to check and maybe adjust your CG if it flies like a brick. If you have any altitude at all it should glide fine. If it doesn't something else is not right. Are the elevons trimmed to have a little bit of up?
BC
Basketcase is offline Find More Posts by Basketcase
Old Apr 06, 2003, 07:28 PM
webnetxpress is offline
Find More Posts by webnetxpress
Australia, ACT, Canberra
Joined Oct 2002
well, if you are really frustrated, go ahead and buy a prop adapter for the sp400 motor (2.3mm). buy yourself a nice prop - i use a 6x3 Tornado on mine (white in color, very flexible but thicker than the gunther props).
I also fly an ele-bee and have never lost a prop with this setup and the plane flies really nice.
So, you spend a few extra bucks (maybe $10 total) for this setup and now you will never loose another prop or break one.
ps- if you do buy another prop, the writing 99% of the time faces forward not to the rear like the gunther stock props.
pss- my ele-bee will glide with no power for 10-20 feet easy if i just throw it good and hard. check cg and make sure you have it right side up (don't ask how i know - but the ele-bee has the radio gear and servos on the bottom side - servo arms sticking through slots on top - and the canopy, battery, and esc/motor on the top side)!
webnetxpress is offline Find More Posts by webnetxpress
Old Apr 06, 2003, 09:34 PM
LuckyArmpit is offline
Find More Posts by LuckyArmpit
Rehab is for quitters
LuckyArmpit's Avatar
West Middlesex, PA, US
Joined Jun 2001
I have a FMA Razor. Its 2 years old. It has over 24 hours of flight time on original motor and original prop. A collet style prop adapter is what I use. I also use a MAS 5.5x4 prop. A little better than the gunthers your using. The only gunther I'm using is on a modded up Firebird XL and the prop is glued on. Those gunthers are notorious for flying off.
Dave...
LuckyArmpit is offline Find More Posts by LuckyArmpit
Max Amps when Prop Falls Off?! Red 61 Power Systems 10 May 04, 2005 11:02 AM
Ele Bee Prop direction and other ??? tomcor Foamies (Kits) 9 May 21, 2003 02:23 PM
Ele-Bee, Bricks, Flight Times & Newbie Help scottw Foamies (Kits) 56 Apr 27, 2003 02:35 AM
Ebay: Ele-Bee EPP Combat Zagi Wing Kit PDX Slope Pilot Aircraft - Electric - Airplanes (FS/W) 0 Aug 04, 2002 10:44 AM
Problems with your zagi prop comming off even with a bit of CA? Fix it here! kushal_22 Foamies (Kits) 4 May 11, 2002 11:32 PM
