Go Back   RC Groups > Aircraft - Exotic and Special Interest > Waterplanes
Old Jul 19, 2009, 09:56 AM   #31
kepa's Avatar
Originally Posted by Palmettoflyer
Your Drake will be very strong as the result. Just remember the Drake box fuselage is inherently strong too, so be careful about over doing it.
The additional strength in the formers allows larger cutouts as well, so I don't think I'll be adding (much) weight here.
The plans specified 3/32" balsa for the fuselage, didn't they (I'm not at home right now)? Well, here in metric world I had a choice between 2 and 3 mm (3/32" is 2.4 mm). I chose the thinner one for the sides and possibly for the top as well, and the bottom will be 3mm. Do you think that's strong enough or should I overbuild it all with the thicker balsa?
-kepa
kepa is offline Find More Posts by kepa   Reply With Quote
Old Jul 19, 2009, 04:30 PM   #32
kepa's Avatar
Please disregard my previous question. After measuring my sheet stock again I found that my "2mm" balsa sheets vary between 2.2 and 2.4 mm in thickness. I suspect it's the same stuff you get when you buy your 3/32" sheets...
-kepa
Old Jul 19, 2009, 05:14 PM   #33
Palmettoflyer's Avatar
I totally agree that the cutouts will offset the additional weight. I like to use 1/64” ply in a lot of key areas where a little doubler sheeting on balsa will help the longevity of the airplane.
By the way, your English is excellent. Have you always lived in Finland?
I work for a German company, so I live in the metric world by day and the English world by night.
Palmettoflyer is offline Find More Posts by Palmettoflyer   Reply With Quote
Old Jul 20, 2009, 05:00 AM   #34
Here are the pictures from my weekend work. Don't look too close at the nose block. Shaping balsa blocks isn't my best modeling skill although I think it turned out pretty good. Balsa blocks tend to show off the tiny variances between the symmetry of the two sides.
  • Name: Hatch Cover 1.JPG
  • Name: Nose Block 1.JPG
  • Name: Nose Block 2.JPG
  • Name: Nose Block 3.JPG
  • Name: Nose Block 4.JPG
  • Name: Nose Complete 1.JPG
  • Name: Nose Complete 2 .JPG
  • Name: Nose Complete 3.JPG
Old Jul 20, 2009, 05:03 AM   #35
Here are a few more for the H stab.
  • Name: H Stab 1.jpg
  • Name: H Stab 2.jpg
  • Name: H Stab 3.jpg
  • Name: Weekend Work.jpg
Description: Weekend Work Completed Weekend Work Completed 66.0 KB · Views: 47
  • Name: Front End.jpg
Description: Weekend Work Completed Weekend Work Completed 54.1 KB · Views: 78
Old Jul 20, 2009, 07:42 AM   #36
MaineFlyer
jpgilbert's Avatar
Looking good! It will be flying before you know it!
Joe
jpgilbert is offline Find More Posts by jpgilbert   Reply With Quote
Old Jul 28, 2009, 08:47 AM   #37
Both models progressing nicely - and there's nothing wrong with your building Palmetto nose block included. I think we all tend to over criticise our own work - fixating on the perceived faults and things we would have liked to do better when they will have absolutely no bearing on the way the model flies. Really we wouldn't have given it a second thought if you hadn't mentioned it.
Modelholic is offline Find More Posts by Modelholic   Reply With Quote
Old Jul 28, 2009, 09:32 PM   #38
Modelholic, I'm glad to see you are getting your Drake sorted out!
I am actually pleased with the way my Drake is turning out. Some models you can feel from the beginning are going to be good ones or bad ones. This IS going to be a good one for sure!
Life has been very busy since my last posts. Here are some update pictures of the V-stab. I chose to do the laminated outline version which turned out quite good. For the form I used a piece of office foam board (good ol' sturdy board). I traced inward of the cut line 3/16" and pinned it to another piece of foam board and my building table. Cut 3 strips of 1/16" balsa, soaked in Windex and a day later I had the outline. Today I filled in the bits and pieces. Next pieces will be the H stab outer vertical fins.
  • Name: IMG_6945.jpg
Description: Foam core template while glue is drying. Foam core template while glue is drying. 54.1 KB · Views: 48
  • Name: IMG_6948.jpg
Description: Removed the core but left it pinned in place for the inside construction. Removed the core but left it pinned in place for the inside construction. 42.1 KB · Views: 39
  • Name: IMG_6951.jpg
Description: Just working my way out from the center. Just working my way out from the center. 38.1 KB · Views: 44
  • Name: IMG_6955.jpg
Description: Yeah, that looks about right! Yeah, that looks about right! 39.9 KB · Views: 30
  • Name: IMG_6958.jpg
Description: Unpinned and begin the clean up. Unpinned and begin the clean up. 32.6 KB · Views: 46
  • Name: IMG_6961.jpg
Description: Sanded nice and smooth on both sides. Sanded nice and smooth on both sides. 95.7 KB · Views: 42
  • Name: IMG_6966.jpg
Description: Not a bad fit at all!  Now I need to get those cute little outside vertical fins done. Not a bad fit at all! Now I need to get those cute little outside vertical fins done. 82.1 KB · Views: 50
Old Jul 29, 2009, 03:34 AM   #39
If it flies - I want one!
Petem's Avatar
Lovely!
Looking great - I think laminated outlines are much more elegant, both structurally and aesthetically, than the alternatives.
Look forward to seeing it all come together,
PeteM
Petem is offline Find More Posts by Petem   Reply With Quote
Old Jul 30, 2009, 03:34 AM   #40
kepa's Avatar
Hi again,
Palmettoflyer, very nice tail indeed! And thanks for the compliment. I am a native Finn and have lived here all my life. We all learn English at school but most of us just don't use it and forget how to do it.
I too have been busy and away. I helped my sister and her husband move, and had to rest a bit afterwards. Now I'm back again, and will hopefully be building (if not posting) at least something every day.
-kepa
  • Name: IMG_0021-s.jpg
Description: Fuselage parts taking shape. Fuselage parts taking shape. 34.2 KB · Views: 30
  • Name: IMG_0022-s.jpg
Description: The formers are being formed, The formers are being formed, 47.8 KB · Views: 28
  • Name: IMG_0023-s.jpg
Description: and the bulkheads will lose most of their bulk. and the bulkheads will lose most of their bulk. 30.2 KB · Views: 42
Old Jul 30, 2009, 04:51 AM   #41
Your pieces are coming along nicely too. I'm as anxious to see your progress as much as I am enjoying my own build progress. Keep up the good work.
I learned to speak German as an adult and did not have the benefit of learning while still young to make it easy. RCGroups is a great forum not only for allowing us to share our model airplanes but also brings people together from all over the world. No where else can someone from Finland, Australia, Brazil, USA, and everywhere else come together so easily to share their ideas and pictures of their work.
I've started on my outside vertical fins last night. I'm going attempt to do the same laminated strip outline as the vertical stabilizer. Perhaps tonight I'll be able to glue it all up and take some pictures. I will be out of town again this weekend so progress might slow down again.
Old Jul 31, 2009, 05:16 AM   #42
Love the laminated work Palmetto. High strength for minimal weight (see next paragraph) and definite build kudos!
Just thought I would add a comment from my recent experience of the smaller Drake. The Drake has a very short tail moment and the weight of the motor is not that far forward of the CG. My battery is behind the nose block i.e as far forward as it could go. I thought I would try some brass tube and piano wire hinges for the rudder and elevator and was concerned by the apparent weight of my finished tail unit. Despite this I have still added a little lead to the tail. No doubt you will have some laxity in positioning your flight batteries for balance but you might be making the tail unit too light? That almost sounds like modelling heresy I know but I have been quite surprised - I had envisaged having to add weight to the nose for sure. Just an observation definitely no criticism intended - I'm really enjoying this thread.
Simon
Old Aug 01, 2009, 04:13 PM   #43
kepa's Avatar
Today I've been doing some more piecework for the fuselage. I cut and glued some sticks, finished work on the laminated formers and figured out a way to support my battery tray. The tray looks massive now but I'll cut some large holes in it. And if I can figure out the CoG before installing the tray, it can be cut shorter too.
-kepa
  • Name: IMG_0037-s.jpg
  • Name: IMG_0041-s.jpg
Description: All my balsa-plywood laminate parts together. All my balsa-plywood laminate parts together. 21.4 KB · Views: 32
  • Name: IMG_0044-s.jpg
Description: Supports for the battery tray. Supports for the battery tray. 37.0 KB · Views: 34
  • Name: IMG_0045-s.jpg
Description: Perhaps I should build miniature bridges instead? Perhaps I should build miniature bridges instead? 21.6 KB · Views: 23
  • Name: IMG_0032-s.jpg
Description: It's good to take a break every once in a while. It's good to take a break every once in a while. 35.8 KB · Views: 58
Old Aug 02, 2009, 02:22 AM   #44
Very nice keep the pics coming.
Old Aug 02, 2009, 09:46 AM   #45
Kepa,
looking great! glad to see you moving right along. I'm back again from the weekend travels and hope to get in some build time later this afternoon.
Modelholic,
Thanks for the CG concerns and tips. Well taken as I've had this issue many times. I've learned to keep a close eye on the CG as the build progresses. Once burned by a kit build that I could not get to balance well, I swore to not ever do that again. As early as possible I start the CG checking. Now, if I read your comments correctly, you stated you have your battery as far forward as possible and still want to add weight to the tail? Sounds like you need to move the battery backwards instead of adding tail weight?
Sold Photon II DLG with ailerons RTF rcdude01 Aircraft - Sailplanes (FS/W) 5 Dec 04, 2007 11:36 PM
Found Photon II DLG with ailerons rcdude01 Aircraft - Sailplanes (FS/W) 2 Apr 09, 2007 11:05 PM
Sold Miss - II electric, with motor & servos Dennis Everett Aircraft - Electric - Airplanes (FS/W) 9 Nov 09, 2006 11:33 AM
Beginner electric with ailerons jpn1999 Beginner Training Area (Aircraft-Electric) 23 Jan 27, 2005 12:44 AM
First electric with ailerons sm rec.models.rc.air 9 May 04, 2003 04:00 AM
Bored? Want to fight?
Join the RCGroups clan!
