| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||
#1 |
Drake II: electric, with ailerons
Hi all,
Last winter I decided I needed a waterplane for this summer. My ultimate goal will be to one day build one of Ivan Pettigrew's beautiful flying boats, but I'm not there yet. For a start, after electric-powered gliders, I thought I'd get my feet wet with a Drake II. Electric, because that's what I've been flying so far and because of the thought of calm silent summer evenings. And I'll build ailerons because I've been flying (at least) 4-channel birds since the beginning, and for the building experience. Anyway, here's a late start for this summer. But if I can't finish the build before, say, late November, I can test fly her off the snow instead. I decided to start with the tail feathers in order to get the building going again after a while. (How common is that, by the way? Where do you start your builds?) So, here are the central vertical stabilizer and the rudder. As you can see, I'm trying to build it light and decided to build up the surfaces instead of cutting them from sheet as the plans showed. The wood is 10x5 mm balsa and the glue used is Cascol 1809 polyurethane waterproof wood glue. Kepa (Aki Pursiainen) Last edited by kepa; Jul 08, 2009 at 05:49 PM. Reason: Added the glue type number and "central". |
#2 |
Great to see another Drake II being built. I just started the same project a few weeks ago. I started with the fuse construction as it looked like it would go quickly and the enthusiasm of the build would be key on building the big sheeted side fuse straight and not looking like a banana. I have been pleasantly surprised to see the fuse coming together without any trouble. The big sheets do create some compound curves when you put the formers on but nothing very difficult to manage. I can post a pic or two of my progress if you like? I don't normally post build threads as it takes me a long time to build with a busy life schedule.
I am thinking of doing the same as you on the stabilizers and try to drop some of the weight. Also, I think the main wing is overbuilt by the plans as well. Keep up the good work. Palmettoflyer |
#3 | ||||
http://www.rcgroups.com/forums/showthread.php?t=208512 Quote:
Anyway, here's my next small achievement: One of the smaller fins. I used 10x3 mm balsa for the structure, and some of the width will be sanded away. -kepa |
#4 |
Kepa, do yourself a kindness and go with ailerons.
#5 | |
I'm still building the tail parts. The last of the vertical fins is now curing. On the plans, of course, so I'll start the horizontal stab tomorrow. -kepa Last edited by kepa; Jul 09, 2009 at 03:33 PM. Reason: Added the part about building tail parts. |
#6 |
Here are the pictures of my progress so far. I'm a little bit further along than the pics show. I'm about 2/3rds finished with the sheeting on top and bottom. I am still feeling good about this build so far.
I have the same idea as you about the ailerons and their sizes. I will make mine either 1.5" or 2" to so there is some aileron control at lower speeds. Looking at the plan for the wing, I think some of the ribs could be left out and only use 1/16" thickness. Might not save a lot but a little here and there! One tip I would suggest is to cut the battery tray hole in the forward fuselage former before assembly. I cut the hole afterwards and it was a bit difficult. |
#7 |
few more pics...
#8 |
MaineFlyer
Hi Guys,
Great to see more Drake II's being built. One of my favorites. Will be watching this thread.Joe |
#9 |
Tail feathers almost ready
I didn't get to devote the entire weekend for building my Drake II as I had hoped, but I managed to take a few moments here and there to almost finish building the tail feathers. Of course there's still some wood to cut and sand away... I think they are both light and still stiff enough.
-kepa |
#10 |
Joe, Great to see you here. Your builds have been a big inspiration to me.
Are you still happy with the AXI 2808/20? I have the same motor and plan to use it as well. You probably also noticed I'm using your CF rod and tube technique for the outriggers. I plan to keep the sponsons completely adjustable and removable. Any tips you can add to our work would be appreciated.Kepa, Your tail pieces look great. I haven't decided yet if I will do exactly the same or use sheet stock. Maybe a mix of the two ideas. My fuselage is nearly finished except I ran out of 3/32" balsa and need to buy some more before I can continue on. Palmettoflyer |
#11 |
MaineFlyer
Thanks for the kind words!
I am very pleased with the Axi 2808/20. When used with three cells and the 3 bladed prop, it gives plenty of power for this model. Hard to beat the Axi but I have used BP Hobbies motors on my two foamy Drake IIs and my new Seamaster II with great success. I like the looks of the built up tail group. But the sheet method Ken Willard used works well also. I did reinforce the outer tail fins so they wouldn't warp. So far, so good. Many flights to date. Be nice to see how much weight it saves. My battery goes all the way forward for proper CG. I have removed the sploats and used my wheels just a few times. Have plenty of other land based planes. Also flown without them from snow. Flys well in both cases. Keep up the good work, guys, and will be watching for latest developments. Joe |
#12 |
Joe, One last question...(for now!)
How do you retain the outriggers in the tubes? I assume they are two pieces and slide in from each side. Is it just a friction fit or do you have some sort of retainer? Thanks, |
#13 | |
MaineFlyer
I used a small brass tab glued into the end of each spar and put a screw thru it into a small blind nut. The attached photo doesn't show it all. Hadn't drilled the hole yet. Don't have a better photo and and the plane is up where I camp during the summer. Joe |
#14 |
Interesting, I totaly understand. I had two thoughts. One, drill two small holes inside through the tube and CF rod. Then use a small wire to pin the CF to the aluminum tube. Other idea was to leave the CF rods long (whole length of the outrigger). Use the outrigger bars as spacers and somehow clamp the floats to the rods to hold it together. Something like a wheel collar in each float where the float attaches.
Make any sense? Your method looks easy and simple too. Thanks, |
#15 | |
MaineFlyer
Joe |
| Thread Tools | |
| Sold Photon II DLG with ailerons RTF | rcdude01 | Aircraft - Sailplanes (FS/W) | 5 | Dec 04, 2007 11:36 PM |
| Found Photon II DLG with ailerons | rcdude01 | Aircraft - Sailplanes (FS/W) | 2 | Apr 09, 2007 11:05 PM |
| Sold Miss - II electric, with motor & servos | Dennis Everett | Aircraft - Electric - Airplanes (FS/W) | 9 | Nov 09, 2006 11:33 AM |
| Beginner electric with ailerons | jpn1999 | Beginner Training Area (Aircraft-Electric) | 23 | Jan 27, 2005 12:44 AM |
| First electric with ailerons | sm | rec.models.rc.air | 9 | May 04, 2003 04:00 AM |
