Old Apr 05, 2003, 12:40 PM
Guinea_Pig is offline
Find More Posts by Guinea_Pig
Mwahahahaha
Guinea_Pig's Avatar
UK, newbury
Joined Dec 2002
Help with new power set up please!
Hi!
i have a 810 mm delta wing aircraft called the swift. It is powered by a geared 280 motor (i think 3:1 gear ratio) I am currently using a 7 cell 250mah nicad and a trickle charged 2 cell lithium ion (1200 mah i think) This plane flies ok but with a 280 the power is feeble to say the least. The nicads will fly it but not too long and the lithiums do but with barely any power! As you can imagine this leads to fairly boring flight and not very lon ones at that! Also this means if their is any wind the plane will struggle!
oh yes the props 8 - 6
what i am really asking is would:
a geared 400 (3:1)
10 - 8 Prop
12 - 22 amp ESC
and 7 cell 500 Nicads give more power
obviously with the added weight the plane should be far more stable in winds. This also gives my plane a more pico jet style set up.
sorry for rambling on.
if you have any other suggestions please make them
PS my plane weighs 300 grams ready to go and is made by modelsport!
Guinea_Pig is offline Find More Posts by Guinea_Pig
Old Apr 06, 2003, 03:20 AM
Fred Bronk is offline
Find More Posts by Fred Bronk
Our Daddy and Heli Junkie
Fred Bronk's Avatar
In Heli Wonderland
Joined Aug 1999
Yes, but look at 8 cells and 2.5:1 gearing.
But with the setup you have I would try 8x720 nimh cells (AAA's) and a 10-8 prop.
Fred Bronk is offline Find More Posts by Fred Bronk
Old Apr 06, 2003, 05:55 AM
Mwahahahaha
Guinea_Pig's Avatar
UK, newbury
Joined Dec 2002
Great!
thanks very much!
i have ordered my cells today! also these cells will be useful for my piccolo!
thanks very much!
i will try to post results if indeed everything goes through!
Help! Having a problem with BEC/ESC set-up please help! conceptmachining Electric Plane Talk 11 May 24, 2008 05:06 PM
Help with Brushless Glider set up Please. seagull2200 Electric Sailplanes 5 Oct 12, 2004 02:09 AM
help with buddy box set-up chris-miranda Radios 1 May 13, 2004 02:48 AM
help with front brake set-up JANSSENM Motorcycles 16 Apr 16, 2004 10:45 AM
Please help with brushless Hummingbird set up guillaume83 Micro Helis 25 Nov 17, 2003 08:21 AM
