Old Aug 03, 2009, 02:44 AM
Dreamcatcher is offline
Find More Posts by Dreamcatcher
Warbirds Lover
Dreamcatcher's Avatar
South of France
Last Sunday we started to paint The Red bull air race paint scheme but unfortunately i hadn't my Nikon with me.
The pearl grey and Dark blue are done and i started to paint a flamming effect (my first attempt) on the nose.
I Hope to be able to post some pictures soon.
I return to my computer to draw a Red bull decal set
Have a nice day
Bye
Pascal
Dreamcatcher is offline Find More Posts by Dreamcatcher
Old Aug 08, 2009, 04:00 PM
Warbirds Lover
South of France
Red Bull Air Race Paint Scheme
Hello friends,
I am happy to present you the first photos of our Funtana's 'Red Bull Air Race style' paint scheme.
Do you like it ?
This is only a "work in progress" : All colours used are water based.
The bottom of the airplane have been coated with a glossy pearl grey that makes the bird "shine" a lot when the sun light it ( i think this paint can be used to emulate an aluminium polished warbird !)
I still have to print a pair of big Red Bulls and to stick them on the wing's bottom.
When all the stickers will be on the plane, we will spray a coat of gloss water based varnish.
Bye
Pascal
Old Aug 08, 2009, 04:01 PM
Dtrimas is offline
Find More Posts by Dtrimas
Cool before it was cool
Dtrimas's Avatar
Chelsea,MI
Joined Jul 2008
Looks Great!
Dtrimas is offline Find More Posts by Dtrimas
Old Aug 08, 2009, 05:27 PM
kalleman is offline
Find More Posts by kalleman
Sverige, Västra Götalands Län, Trollhättan
Joined Oct 2006
That looks really nice. I have started cutting my own Funtana. Have alot of other projects going as well so progress will be slow, but it's started at least. Will post pictures when there is more to show for.
kalleman is offline Find More Posts by kalleman
Old Aug 08, 2009, 09:29 PM
matk is offline
Find More Posts by matk
I like EPP
matk's Avatar
Victoria BC Canada
Joined Sep 2005
Oh! she look so nice. too nce to fly even! I would hang and look at it for a while... great job.
Matk
matk is offline Find More Posts by matk
Old Aug 09, 2009, 01:57 AM
lance dalton is offline
Find More Posts by lance dalton
C.H.E.A.P.
lance dalton's Avatar
Chino Hills, CA.
Joined Nov 2004
Beautiful Job, Pascal.
Looks like she's ready for some pylons .
Lance
lance dalton is offline Find More Posts by lance dalton
Old Aug 10, 2009, 06:24 AM
kalleman is offline
Joined Oct 2006
Build started
I managed to get some build time yesterday. I adapted the plans for only using 6mm depron as build material. I have cut all the parts on my Phlatprinter and started assembly. The bottom of the fuselage is only taped on.
Old Aug 10, 2009, 11:28 AM
Warbirds Lover
South of France
Hi !
Thank you all for all your nice comments.
It is very gratifying for me to see that my work interests other persons.
Kalleman, i am very happy that you began to build my Funtana and very impatient to see all the modifications that you will brought to her, it's already very instructive
Can you speak us a bit more about this Phlatprinter please ?
I didn't know this device. Is It a kind of CNC 3D milling machine ?
How does it works ?
The built look good and the paint job seems to be started too
Keep on the good job and thanks for sharing with us
Pascal
Old Aug 10, 2009, 03:30 PM
kalleman is offline
Joined Oct 2006
Good that you like it Pascal! I will try to make your nice design honour. I have to confess though that the "paint job" is actually only colored packing tape. I use it to be able to bend the depron without snapping
The phlatprinter is a CNC machine specially designed to cut foam that is up to about 12mm thick (I use it only for 3mm and 6mm depron). I draw the plane I want to cut in Google SketchUp, lay out the pieces to fit the foam sheet and generate G-code (CNC machine code). Then load the G-code in the CNC program and hit print. After about 20 minutes (time is depending on the complexity and number of cuts being made) the parts for the Funtana was ready. If a part doesn't fit or needs to be changed, just go back to Sketchup, regenerate G-code and run it again.
It's a really cool way to cut planes instead of having to print plans and cut the parts by myself. And all parts are correct size down to about 0,5mm or so (which is much better than when I cut the foam from plans)
There is alot of info about the phlatprinter on www.phlatforum.com
Old Aug 10, 2009, 03:49 PM
Warbirds Lover
South of France
Thank you so much,
I will read some thread about this Phlatprinter
Good night !
Old Aug 13, 2009, 05:52 PM
Warbirds Lover
South of France
Good evening Friends,
Our Funtana is achieved !
I hope to be able to make a movie of a flight and some pictures this week-end, if the wind slows down.
Have a good night !
Old Aug 13, 2009, 11:40 PM
prunner is offline
Find More Posts by prunner
Prunner
prunner's Avatar
Auburn, KS
Joined Oct 2008
Really sharp looking and bet it's a blast to fly. Just curious what motor are you using.
prunner is offline Find More Posts by prunner
Old Aug 14, 2009, 02:19 AM
Warbirds Lover
South of France
Hi Prunner, welcome in this thread and thank you for your nice comment !
We use KD A2220-L brushless engine with a 10x4.7 SF propeller.
Here are some specs from KD :
Kv = 1102 rpm/V
Rm = 0.143 ohms
Io = 0.66A @ 5V, 0.78A @7V, 1.08A @ 12V
Recommended props:
10x5 APC-E (3 cells: 20A, 210W, 1050g thrust, 8800rpm)
11x5.5 APC-E (3 cells: 23A, 240W, 1200g thrust, 7900rpm)
We use to mount these engine as often as possible on our parkflyers because they are cheap (less than $17), very torque full and can pull up to 1200 Kg (our painted plane's - ready to flight is 0.610 Kg )
Best Regards
Pascal
Old Aug 17, 2009, 12:59 PM
Warbirds Lover
South of France
Some more pictures of Funtana's flight
A video have been made too.
I will post her as soon as possible
Bye !
Pascal
Old Aug 19, 2009, 01:34 AM
kalleman is offline
Joined Oct 2006
That looks really good! I have got caught up in other projects so my Funtana has been on hold for a while. But I see that I definitely need to pick it up again!
Building a plane from scratch karpar The Builders Workshop 8 Dec 26, 2004 08:55 AM
Gonna build a plane from scratch! KingOfTheHill Slope 5 May 20, 2004 07:21 PM
