Old Apr 05, 2003, 10:32 AM
tizken is offline
Find More Posts by tizken
Jackson, MI
Joined Apr 2002
rffs beeps 4 times then nothing
Just got my first rffs100 system yesterday at toledo and hooked up everything today. When first powered up it beeps 4 times then does nothing, I tried it once without the tx on and got glitching that stoped when the tx powered up. Tried it again and never got glitching. The coils are ok, 50.4 ohms or something like that and move when powered from an external source. I tried diffrent antenas, checked voltage at the board and tried it without the motor or without the coils. Is the 4 beeps an error mesage?
Tim
tizken is offline Find More Posts by tizken
Old Apr 05, 2003, 03:09 PM
Mike Taylor is offline
Find More Posts by Mike Taylor
Team 30 Micro EDF
Mike Taylor's Avatar
Camarillo, California
Joined Apr 2002
Turn the TX on, and then turn on th RX. It needs to find a signal when it powers up. The 4 beeps ID the software version (new PIC chip). The crystal and antenna are in snugly, correct?
Mike Taylor is offline Find More Posts by Mike Taylor
Old Apr 05, 2003, 04:17 PM
tizken is offline
Jackson, MI
Joined Apr 2002
Thats what I usually did, turn on tx, then plug in bat. I checked all the conections and they are all good. What I thought was strange was that I didn't get any glitching without a tx. Does the rffs wait for a low signal on the throtel channel before activating any of the chanels?
Old Apr 05, 2003, 05:38 PM
Gordon Johnson is offline
Find More Posts by Gordon Johnson
in persuit of low wing loading
Gordon Johnson's Avatar
Boston, Mass
Joined May 2001
Which brand transmitter are you using? Also, the throttle channel needs to be all the way at the low stop or the RFFS may think you have a different transmitter. Is any of this mentioned in the directions? I'm not sure the directions have been updated for the new software. You might check out the documentation section on smallrc.com. It's possible newer instructions are given there.
Gordon
Gordon Johnson is offline Find More Posts by Gordon Johnson
Old Apr 05, 2003, 06:08 PM
tizken is offline
Jackson, MI
Joined Apr 2002
I'm using a Futaba 8u, I tried seting the atv on throtle to 140% thinking that it wasen't seeing a low enough signal and that made no diffrence. I'm beging to thing that I just got a bad board out of the box. I looked at the crystal for channel 39 and it's got a diffrent rating(72.??) than a gws crystal but they both are for 39. I would think that if I had the wrong crystal I would get glitching though.
Old Apr 05, 2003, 08:54 PM
Boston, Mass
Joined May 2001
It's possible to have gotten a bad board, but I've never heard of this. I'd get hold of Dan Hurd when he gets back from the show on Monday. Do you have a different transmitter you could try?
Gordon
Old Apr 05, 2003, 10:58 PM
Keennon is offline
Find More Posts by Keennon
Keennon's Avatar
California
Joined Oct 2002
Tim- the four beeps is the power-up check. If you hear 4 beeps that means that the computer, power converter, coil amplifiers, and coils are working properly, which is normal. What it doesn't check is the motor controller and the radio section. Looks like your radio section is not working, or the channels are mixed up somehow. One wild suggestion, if you transmitter is an older AM style, I don't think it will work, even on the correct frequency.
The crystal will be a different frequency than for a GWS. The GWS and the RFFS use different intermediate (IF) frequencies so the GWS is 455 Khz offset, and the RFFS is 76Khz offset.
If you have a buddy with an RFFS, use his transmitter and receiver crystal in your RFFS board to test.
Once you have tried everything, send it back. They are delicate little guys and occasionally get damaged. If you need to contact Dynamics Unlimited, call on the phone, for DWE email or call.
-Matt Keennon (RFFS programmer)
Keennon is offline Find More Posts by Keennon
Discussion CP2......red flash 4 times then red/green bleugh1 Micro Helis 4 Jun 23, 2007 06:55 PM
Sold Logo 14 -Never crashed flown 4 times Robert-CSD Aircraft - Electric - Helis (FS/W) 18 Aug 31, 2005 08:52 PM
FS....complete SlowStick setup,flown about 4 times mike123 Aircraft - Electric - Airplanes (FS/W) 14 Jun 03, 2004 11:52 AM
Sugar battery has 4-times power of Li Takao Shimizu Batteries and Chargers 6 Feb 06, 2003 11:10 AM
rffs-100 4 channels? alexander Scratchbuilt Indoor and Micro Models 2 Apr 30, 2002 06:43 AM
