Old Apr 05, 2003, 10:20 AM
robw is offline
Find More Posts by robw
robw's Avatar
Detroit, Michigan
Joined Nov 2002
Question about Imeins tail LED setup
I have a question for Imeins, or anyone who has done his tail LED. I did it on my piccolo, and it workes great. I dont know to much about electronics, but was wondering how the slight increase in current draw from the LED would affect the Piccoboard gyro, because I had to reduce the gain after I soldered it on. just wondering if it could affect the gyro in a negitive way. although I dont seem to have a problem after I readjusted it.
robw is offline Find More Posts by robw
Old Apr 05, 2003, 05:52 PM
jeffs555 is offline
Find More Posts by jeffs555
"Simplify, then add lightness"
Raleigh,NC
Joined Nov 2000
Rob,
What LED did you use for the tail? I looked at Ingmar's circuit, and he doesn't show a series resistor on the tail LED, because he used a flashing LED with built in electronics. If you used a standard LED, without a built in resistor or electronics, it will probably draw too much current, and limit the voltage to the tail motor.
Jeff
jeffs555 is offline Find More Posts by jeffs555
Old Apr 05, 2003, 08:32 PM
robw is offline
robw's Avatar
Detroit, Michigan
Joined Nov 2002
I used a flashing Led, but It is only rated at 3volts, I dont know how much current/voltage goes to the tailmotor, but I did use a 100ohm resistor to bring it down to a level safe for the Led.
It's just my Piccoboard seems to be acting funny after I did this. I can't understand how it would screw anything up, it could be coincidence or just my imagination though I removed the Led, and its still acting weird.
here is a pic:
Old Apr 05, 2003, 10:21 PM
jeffs555 is offline
Raleigh,NC
Joined Nov 2000
Rob,
The way you wired it looks just fine, and I don't see any reason it should affect the gyro. Maybe your tail motor is starting to go. All the reports are that they don't last very long.
Jeff
Old Apr 06, 2003, 10:25 AM
docphi is offline
Find More Posts by docphi
Stupid gravity!
docphi's Avatar
Trinity, FL
Joined Jul 1999
Here's how I did mine...
http://www.rcgroups.com/forums/showt...&threadid=9078
docphi is offline Find More Posts by docphi
Old Apr 06, 2003, 09:03 PM
imeins is offline
Find More Posts by imeins
imeins's Avatar
Australia
Joined Nov 2002
Hi.. The LED I used is designed to operate from 3-10v without the need for a series resistor. Since the LED may receive up to 9 volts or so you could happily try values from about 680ohms and down and still get a reasonable amount of light out of it. Obviously the higher the value the lower the current and possible effect on anything else. With a 680R at 9 volts you limit the current to 13mA, (not taking into account the LED voltage drop). At 100R of course you end up with up to 90mA!!
Ingmar
imeins is offline Find More Posts by imeins
Old Apr 07, 2003, 11:05 AM
robw is offline
robw's Avatar
Detroit, Michigan
Joined Nov 2002
Hmm, I could not find an Led like the one you have, mine is rated 2.5-5 volts. I did change the resistor to a 220ohm, and it didn't affect the brightness, but anything more than that and it gets very dim.
Discussion Question About LS Purpil Peril Setup Issues cbhelo Power Systems 10 Jul 01, 2007 10:46 PM
Discussion Question about my EZ Star setup... lovespicyfood Power Systems 3 Jun 21, 2006 03:31 PM
Question Question about HB King tail rotor setup kenmalecki Micro Helis 6 Apr 05, 2006 07:11 PM
Discussion Question about Tail Rotor Setup kenmalecki Electric Heli Talk 0 Apr 04, 2006 08:23 PM
Stupid question about Blade tail Deezul Micro Helis 3 Oct 23, 2005 07:37 PM
