Old Jul 06, 2009, 11:42 AM
toesup is offline
Find More Posts by toesup
USA'd ex Brit
toesup's Avatar
Back.. In California
Joined Aug 2006
Build Log
Z Drives revisited
Many of you know of my dislike of the Graupner Z drives following my use of them in WW.. They are plastic construction and the design leaves a lot to be desired.
Seeing as I am in need of a pair of Z Drives for a 'Modern style Harbor Tug' I have designed and am currently building (yes, there will be a build thread ), I decided to see if i could design and build my own Z Drives.
I've long been a fan of Algie's work on his drives and his work on the DSV Seawell, so i spent some long hours studying his work...
http://www.rcgroups.com/forums/showthread.php?t=709484
http://www.rcgroups.com/forums/showthread.php?t=524835
I also came across a design for a Z drive by Cadmonkey over on RC Universe...
http://www.rcuniverse.com/forum/m_8463955/tm.htm
Then i discovered Milan's work on the Checkoslovakian MONAKO site..
http://translate.google.com/translat...istory_state0=
Milan was good enough to send me his CAD drawings.. but i thought they were over complicated and not easy to make.
.. and after a discussion with Tug Boat Andy, he discovered that the bottom end gears for the Graupner drives were available as spares. Thanks Andy, that saved me a lot of work!.
So armed with all three 'ideas'... together with some thoughts of my own, I designed my own drives and began to do some machining.
The Korts and Prop's came first..
http://www.rcgroups.com/forums/showthread.php?t=1025555
Wondered what those were for eh?..
I'm currently at the stage of machining the end cap's and have to machine the drives for the bearings for all of the shafts.
As yet, i have not decided what motor's to use to run the drives with.. but i do have a matched pair of Pittman's that might be able to take the strain..
toesup is offline Find More Posts by toesup
Old Jul 06, 2009, 11:44 AM
Aerominded is offline
Find More Posts by Aerominded
Monterey Bay California
Joined Feb 2004
Oooooooo....
Aerominded is offline Find More Posts by Aerominded
Old Jul 06, 2009, 06:33 PM
Boatfox is offline
Find More Posts by Boatfox
Give the dog a bone
Boatfox's Avatar
USA, NV, Las Vegas
Joined Aug 2005
Very nice....now stop being a tease and give us the play by play. Detailed MACRO pics are required as well...
I like...you taking orders?
Boatfox is offline Find More Posts by Boatfox
Old Jul 06, 2009, 10:01 PM
drakonis is offline
Find More Posts by drakonis
AMA 743519 Team Heliproz Pilot
drakonis's Avatar
United States, WA, Granite Falls
Joined Mar 2006
geez ralph, you really know how to make a guy sick.
very nice.
drakonis is offline Find More Posts by drakonis
Old Jul 06, 2009, 10:05 PM
tsenecal is offline
Find More Posts by tsenecal
Submarines, etc.
tsenecal's Avatar
Arvada, Colorado
Joined May 2005
toes,
what is/are the diameter of the props?
tsenecal is offline Find More Posts by tsenecal
Old Jul 06, 2009, 11:25 PM
toesup is offline
USA'd ex Brit
toesup's Avatar
Joined Aug 2006
You want a "drill hole 'A' and turn down to Dia. 'B'.... and cross drill 3/8.." type report..
I can take some more pics when i get a little more done..
Taking orders?... Can you afford my time Mr Boatfox?..
Originally Posted by tsenecal
toes,
The props, turned down are 2 1/2"
Old Jul 06, 2009, 11:31 PM
fooman2008 is offline
Find More Posts by fooman2008
United States, ID, Rexburg
Joined Sep 2008
sounds like TBW has a sideline making Z-drives!
Foo
fooman2008 is offline Find More Posts by fooman2008
Old Jul 06, 2009, 11:34 PM
toesup is offline
USA'd ex Brit
toesup's Avatar
Joined Aug 2006
No, its a Sherline lathe / milling machine.. and some design flair...
http://www.sherline.com/
Old Jul 06, 2009, 11:42 PM
Kmot is offline
Find More Posts by Kmot
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
Nice!
Kmot is offline Find More Posts by Kmot
Old Jul 07, 2009, 12:29 AM
Umi_Ryuzuki is offline
Find More Posts by Umi_Ryuzuki
Sea Dragon-Lover
Umi_Ryuzuki's Avatar
PDX, OR
Joined Dec 2002
Very nice,... Glad you finally found enough information to give you
the confidence to proceeed.
However, I think the graupner gears are acually part of the problem...
Umi_Ryuzuki is offline Find More Posts by Umi_Ryuzuki
Old Jul 07, 2009, 09:00 AM
woodybob is offline
Find More Posts by woodybob
WooHoo!
woodybob's Avatar
Lake Balboa, CA
Joined Jun 2007
Nice work.
woodybob is offline Find More Posts by woodybob
Old Jul 07, 2009, 01:57 PM
keith S is offline
Find More Posts by keith S
r/c ships and workboats
bellingham, wa
Joined May 2006
Cool prodject there Toes. Can't wait to see what you are really going to be putting them in!!
keith S is offline Find More Posts by keith S
Old Jul 07, 2009, 07:24 PM
toesup is offline
USA'd ex Brit
toesup's Avatar
Joined Aug 2006
Today's efforts have been to install the bearings in the end casing of the bottom housing and the bearings in the bottom of the vertical housing.
I've also cut the thread on the end of the bottom drive shaft so i can add the props. They need a nut behind the prop yet though.
I have managed to source some rubber 'O' rings for the top end of the vertical housing.. and am about to order up some gears for the top of the vertical drive shaft..
Just wondering..
Seeing as I'm planning on powering these Z drives with a pair of Pittman's (@ 4000rpm max) should i still be thinking in terms of a 3:1 reduction for the gearing from the motor to the top of the drive shaft, like the Graupner drive's have?...
.. and a closer view for Mr Boatfox..
Old Jul 07, 2009, 08:22 PM
col_426 is offline
Find More Posts by col_426
from downunder Downunder
col_426's Avatar
Hobart, Tasmania, Australia
Joined Feb 2008
You too, huh toes. I too have plans on doing something like this, but no proper design yet, so I'll be watching with interest! I'm planning on trying nylon gears from SPI in mine, I've got a lot of the parts together but I haven't started yet, gotta finish my Al Khubar tug build first.
Your drives are certainly looking good so far - mmmm, shiny brass...! What are you joining all the bits together with, for instance, bits like the bottom bulb and the outer vertical shaft? Also, are they Milan's plans behind your first pictures, or your modifications of his plans?
Phillip
col_426 is offline Find More Posts by col_426
Old Jul 07, 2009, 09:20 PM
Tugboat Andy is offline
Find More Posts by Tugboat Andy
Joined Apr 2007
Holy smokes, Toes! That looks incredible! You've been busy AS always watching with keen interest. I know how hard you have been working on this but you still make this look easy.
Umi - is that the 'gear stripping problem' you mention? I thought I read on a German site that the problem had been solved.
Tugboat Andy is offline Find More Posts by Tugboat Andy
Discussion Z DRIVES images Radek2 Scale Boats 45 Jul 05, 2009 11:29 PM
Question Z-drives. towboatjoe Dock Talk 26 Jan 23, 2009 11:44 AM
Discussion Z-drives Tugboat Andy Dock Talk 5 Nov 10, 2008 01:22 AM
Sold 2 NIB Z Drives, only taken out for pictures. Hydroman Boats (FS/W) 5 Apr 29, 2007 12:06 AM
Z Drives and Bow Thrusters algiecrook Scale Boats 3 Nov 18, 2005 03:53 PM
