Old Dec 09, 2010, 01:07 PM
Jimmy Hoffa is offline
Find More Posts by Jimmy Hoffa
Jimmy Hoffa's Avatar
Orlando, FL
Joined Jul 2004
Originally Posted by spacecase View Post
Yes the merits of balancing spinner and prop properly can't be stressed enough. Well unless you have a TruFlight magnetic balancer, absolute crap.
Are you saying that the TruFlight is no good or it's the only one that works well?
Jimmy Hoffa is offline Find More Posts by Jimmy Hoffa
Old Dec 09, 2010, 01:19 PM
spacecase is offline
Find More Posts by spacecase
Vermont
Joined Dec 2003
Just move the balancing shaft 90 deg on the truflight and wow your prop or spinner has a new heavy point, different ever time. And I did ream them properly. The dubro looks like it gets good reviews.
spacecase is offline Find More Posts by spacecase
Old Dec 09, 2010, 02:13 PM
old_dan is offline
Find More Posts by old_dan
Cognito, Ergo Imbibo
old_dan's Avatar
Morgan Hill, CA
Joined Sep 2007
I've been using OS-F plugs on the Saitos.
For grasschopper....I have a .65 on a World Models Frontier Senior. That is a copy version of the Sig Kadet Senior. The specs call for a .40, but I've seen everything on them up to an OS .91 FX two stroke. I think the .65 is just about perfect for that airplane.
Dan
old_dan is offline Find More Posts by old_dan
Old Dec 09, 2010, 05:17 PM
flyinghigh is offline
Find More Posts by flyinghigh
TDI Abuser
flyinghigh's Avatar
Joined Sep 2002
Originally Posted by grasschopper View Post
Im in bluefield va. and we fly every sunday at pikeview high school thats off of 77 in WV..havent flown in wytheville yet....BTW this morning at 4:00 am 0 degrees outside Lets go fire up a saito if it will start
Yeah it was 9-degrees here this morning . Funny my car (Diesel) cranked right up but this afternoon it got to 35 degrees and died 3 times .
I do not want any glow fuel on my hands this time of year . But do want to take the Saito's out .
flyinghigh is offline Find More Posts by flyinghigh
Old Dec 10, 2010, 06:33 AM
Orlando, FL
Joined Jul 2004
That does sound like a problem. I assume you have reversed the prop on the shaft and tried that. I would think a magnetic balancer with no contact points would be good.
Personally, I use a balancer I've had for 30 years with metal wheels, metal supports and a heavy aluminum base.
Old Dec 12, 2010, 03:49 PM
Cmarch is offline
Find More Posts by Cmarch
USA, MA, Boston
Joined May 2010
Saito 115 GK
Hi all, I have a saito 115 tat I was going to use in a H9 1/4 scale cub.. Specs call for a 120 or better I looked at the Saito 125 the specs on these 2 engines are almost identical...Any thoughts ? Thanks Carl
Cmarch is offline Find More Posts by Cmarch
Old Dec 12, 2010, 04:34 PM
mike early is offline
Find More Posts by mike early
mike early's Avatar
USA, KY, Ashland
Joined Oct 2007
I am sure it'd fly it. Will probably need some nose weight.
mike early is offline Find More Posts by mike early
Old Dec 12, 2010, 04:59 PM
Vermont
Joined Dec 2003
Ehh why does everyone want to add weight, just move the rx batt back and recalculate cg...
Old Dec 12, 2010, 05:11 PM
Orlando, FL
Joined Jul 2004
Better yet, just fly it and set the CG according to what works best, not what the specs call for.
Old Dec 12, 2010, 06:07 PM
Arceenut is offline
Find More Posts by Arceenut
Arceenut's Avatar
Canada, BC, Langley
Joined Nov 2007
Yep. That's a good plan but the specs are a good staring point. I like to think that at least the plane would be flyable with the CG at the spec point. I wouldn't want to try to maiden a plane without at least checking that the CG is near the specified point.
Arceenut is offline Find More Posts by Arceenut
Old Dec 12, 2010, 06:51 PM
mike early's Avatar
USA, KY, Ashland
Joined Oct 2007
The 115 is LIGHT. it's a 1/4 scale plane.
Tell us how it works out....
Old Dec 13, 2010, 07:41 AM
Cmarch is offline
USA, MA, Boston
Joined May 2010
I guess my point in all of this is ,will the engine fly the plane ?
Old Dec 13, 2010, 07:43 AM
mike early's Avatar
USA, KY, Ashland
Joined Oct 2007
Old Dec 13, 2010, 07:46 AM
Cmarch is offline
USA, MA, Boston
Joined May 2010
I guess my other concern was not having to load the nose up with a ton of weight ... I got a great deal on the motor so worse case ,I could just put it up for trade ???
mike early's Avatar
USA, KY, Ashland
Joined Oct 2007
use it. add weight as necessary. it's a Cub. No big deal.
Composites Forum on RC Groups? TGoodwin Composites Fabrication 9 Oct 01, 2004 03:49 AM
PLEASE KILL ACTIVE X on RC Groups. windsurfer Site Chat 7 Apr 19, 2004 02:16 PM
Help! Large font on RC Groups! Lenny970 Site Chat 4 Mar 20, 2004 10:52 PM
